  • Replies 47
hey guys i work for a company that tints cars, privacy glass is all legal as long as the car came out standard from factory although the front two windows wont have privacy glass so its gets matched with 20% (or 20 grade) tint which is illegal, the darkest legal tint is 35% then 20% that illegal then goes down more and more 5% is limo tint cant see in pretty much, same goes with mirror tint its illegal, its not the factor that cops cant see u do stuff in ur car a lot of car crashes do happen with illegal tint imagine driving at night with 5% (limo tint) at night u cant see in and cant see out i no this for a fact
hope this clears it all up for ya's
Cheers man! Now I can sleep at night knowing my privacy glass is legal :P
But just wondering, how would they be able to tell if it's privacy glass? And not just fine you for thinking it's tint?
LOL @ THREAT. The dude had to stick the p plate on the out side.. :P LOL
When I was on my P's, I had to do the same... 5% on the rear... looks great, but reversing at night can be a little tricky :)
hahah it was gangster... i sold it though. pretty sure the new owner took off the tint though cause i heard it pissed him off lol.
i admit it was alright to see during day with the mirror tint. at night you 100% def couldnt see anything around you unless the area was lit up. i do think it is bit dangerous at night but i always drove with the front windows bit down just so i could see outta my mirrors.
  • 4 weeks later...
I donno i seen that new tnt stuff that gettng really popular,
The Mirror tint?
Its getting big in melb now, speshly in dandenong,
its basicly like one way windows. can only see out not in,
i donno how people get away with it.
    • Hows your intake piping? Are you still running stock? Having in the stock AFM position would mean, if the BOV was shut/venting out, it'd create the almost stalling kind of effect right // "the rich pulse behaviour" due to MAF thinking air is flowing ? But this would be better than having the bov in the stock position + MAF on/just before cross over piping right?
    • Essentially, yes. Although I wouldn't put the AFM on the crossover pipe. I'd want to put it into what amounts to the correct size tube, which is more easily done in the intercooler pipework. I bought a mount tube for card stile AFM that replaces the stock AFM - although being a cheap AliExpress knockoff, it had not flange and I had to make and weld my own. But it is the same length and diameter as the stock RB AFM, goes on my airbox, etc etc. I don't have a sick enough rig to warrant anything different, and the swap will take 5 minutes (when I finally get around to it and the injectors & the dyno tune).
    • So to summarise, the best thing to do is to move recirc to between turbo and IC, and maf on the crossover pipe. Meaning I'd need a recirc flange, drill a hole in the piping on turbo outlet area. And drill hole on crossover to fit/weld maf sensor? Either that or put the MAF on the turbo inlet right?  Is an aftermarket recirc/blowoff valve recommended? Do currently have family in Japan so could probably bring something back with maybe a cheeky lil SuperAutobacs run?
    • Yep, so far most have said that it looks like corrosion on the wall from piston not moving. Which then has probably damaged the oil rings and caused those vertical marks. The longest the engine was still after the rebuild, was the winter of 2018 - 2019, plus the boat trip to Japan. When I shipped the car, it had normal gas in the tank but before that winter pause, it had E85 in tank.  In any case, even if either one of those was the cause, it happened close to 6 years ago and the car has been driven something like 30 000kms after the fact. Again, apart from the plugs and the dip stick, there is nothing in the way the car runs that would indicate what has been going on in the engine. I am going to consult a shop and ask their opinion, what would be the best approach. I do have some access to a garage I could use to diagnose further myself, but time is very restrictive. Might end up buying another engine that could be used while this one is being remedied. Without pulling the head, it will be impossible to find out if it needs another bore, but here's to hoping a hone would suffice.  Goddamnit, I would really have preferred this not happening.
