Hi all,
Got some fibreglass eyelids for my 34 and have had insane amounts of difficulty painting them;
1.Sanded them down, wiped clean with wax & grease remover, applied grey acrylic primer which sticks perfect.
2.Apply black acrylic gloss spraypaint and as soon as the paint hits the surface it appears to 'bubble' and seperate
3.When looking at the surface dried the whole surface has an orange peel look and some parts have small bubbles
I have now tried doing this probably 10x or more and have had no luck, have tried wiping with metho rather than wax and grease remover, have tried in different temperatures, have tried placing the can in hot water to warm paint, have heated up the back of the eyelids with a hairdryer to warm the surface before hand etc.. I have also taken the surface right back to fibreglass with thinners and tried all over but no luck..
I cannot workout what the variable is that allows the primer to stick fine and not the paint (all the products are acrylic).. Everything I've researched indicates a contaminate but I've had no luck. Also tried 3 different brands of paint, even tried sanding the black bubbly paint back in hopes of hitting it with clear to bring back a smooth gloss but then the clear does the same thing!!
Please please any advise is appreciated I'm going mad for something I thought would be straight forward.
cheers,
Steve
https://www.sau.com.au/forums/topic/326753-trouble-painting-eyelids/
how long are you waiting between primer and top coats? are you wiping them with wax and grease remover between primer coats and top coats? are you sanding the primer before applying the top coat?
Yeh you should be spraying the base coat paint before the primer actually dries. The thing with primer is it soaks into the material, so you have to put quite a lot of primer on until you can clearly see that it isn't being absorbed anymore. And then you want to spray the base coat before the primer dries so that they chemically bond. You shouldn't need to sand unless you are fixing something like a run, or the layer has gone completely hard and the layers need to be physically bonded rather than chemically.
Your problem sounds like either silicon or the paints are attacking each other which is pretty common when you use wax & grease remover. I advise you start again. Completely remove everything with paint thinner, get rid of everything on it until you can see the base layer. Now do a REALLY good job of cleaning it, and even lightly scuff it with 600 grit sand paper. You need to make sure there is absolutely no thinners left on it. Now spray the primer again, doing what I said so you can see that it is no longer being absorbed into the eyelids. Primer is pretty forgiving, you can use a lot of it. Once you are happy with your primer coats, apply the base coat paint just before the primer is touch dry. This will allow the primer and the paint to chemically bond to each other. Do the same thing with your clear coat if you are using any.
Feel free to check out my album of things I have painted http://www.facebook.com/?ref=home#!/al...d16373c642972e1
Edited by Hanaldo
Due to the number of times I've done this and tried to eliminate the variable causing the problem. I have done the top coat within maybe half an hour (touch dry) of the primer coat. I also initially tried sanding the primer coat, using wax & grease remover then doing a top coat but both have returned the same result.
thanks for your reply =)
Hey Mate,
Really appreciate you taking the time to give all this advice. I will go grab some thinners from Bunnings (and more paint i've nearly run out =< ) strip it back to the fibreglass and start over.. You mentioned not using wax & grease remover are you saying to just clean it with thinners and wait for it to dry then do primer>top>clear without sanding in between?
Also you mentioned the top coat and clear coat before they are dry so should it all pretty much be one process?? (ie: primer coats every few minutes apart followed by black followed by clear)
thanks again.
Hey Mate,
thanks again.
Don't let thinners dry on the fibreglass, will cause the problem all over again. You gotta make sure you really clean all the thinners off. Plenty of water, and a fairly good rub down with 600 grit will get rid of it all.
Yes, should all be pretty much one process if possible, don't sand between coats unless you get a run and you need to let the paint dry to sand it off. If you get the layer perfect, move onto the next layer before it dries. So you spray the primer, will probably take about 5 coats before it stops soaking in, and then spray the black, then the clear. You want to let the layer underneath set a little bit but not go dry before you spray the next layer, if you get that lol? Probably won't even take 5 minutes.
A good way of doing it is if you are spraying the eyelids on some newspaper, use the oversprayed paint on the newspaper as an indicator of when to do the next coat. When it is a little bit sticky still, but not wet, that is when you want to spray the next coat. Just before touch dry.
    • It's the adhesive holding the ceramic wheel to the shaft the fails on 90% of them.
    • Foreign debris, physical shock, boost leak, could be anything honestly. The danger in taking all the timing out of a tune/hitting the R&R corner is that even if the engine doesn't detonate your turbo is taking a lot of abuse from high EGT. Also, even if nothing goes wrong it is a journal bearing that is spinning at 100k RPM on boost. Eventually it goes through enough cold start/pressure cycles to wear it out.
    • I kinda accidentally saw this, and was interested, but It actually seems to replaces the whole center computer, using the existing screen and buttons. AND it may only be for a G37 and not compatible with a Japanese 370. So its not for me, but someone else may be interested to look into it. Its about $680USD. If I am understanding it right, it basically replaces/installs and android pc that integrates with the existing screen. But I could be wrong. https://gromaudio.com/vline/ The video I first saw was the following, with very little and unclear details.     Even if your not interested in the system, the video on their site was pretty comforting in showing how simple the whole centre comes out
    • hfygrte52 what side you looking for? Do you care what color car it's off? Found a white LH side on here: https://skylinespares.com.au/product/nissan-skyline-r33-coupe-rear-tail-light/   Aussie parts place but will ship to USA. Maybe get it before there's a tarrif on 25yo shit box parts
    • I’m with Shannon’s for all 5 of our cars. Agreed values seem fair, premium price is okay. ($210 ish a month, all comprehensive).  Have claimed once with them for a not at fault claim with another car where my car had no damage. Was one call after the incident and an email after. Deemed not at fault so premium didn’t go up either.    I have called up and spoken with people who are not familiar with certain cars and didn’t agree with me on value or let their personal vehicle preferences effect the call. But called back later and got someone else who was more agreeable.
