One fantastic car. We are only selling due to no longer requiring a large family car.
This is a prime example of Nissan's snake in the grass Stagea. This is the series 2 version with the 'NEO' Motor. It features the R34 Skyline single turbo motor (RB25DET) coupled with All Wheel Drive! The engine makes 206kW 6400rpm, 333Nm 3200rpm - (figures quoted are factory at the flywheel). The car also features M-ATx E-AT Electronically-controlled four-speed automatic with overdrive and electronic lock-up torque converter and Tiptronic function controlled from either the gear shifter or the steering wheel paddles.
Power windows;
* Power mirrors (including a fold-in feature for parking in tight spaces);
* Driver's and Passenger's SRS airbags;
* Roof rails;
* Reclinable and fold-down (by use of a nifty handle in the luggage bay) rear seats, with a centre fold-down arm rest;
* Climate control air-conditioning;
* Front centre arm rest, which can be opened towards either the driver or passenger;
* Privacy glass (rear doors and rear luggage area)
* Dual electric sunroofs (front one is tilt and slide, rear is a slide-only);
* Electric, self-closing rear door (boot)...
* Electronic odometer and dual trip-meters;
* Various hooks and tie-down points in the luggage bay so your cargo doesn't go flying around;
* Tilt-adjustable steering column;
* 12v lighter socket in the rear luggage area;
* Leather steering wheel;
* Front fog lamps;
* Front, variable intermittent windscreen wipers;
* Rear window wiper;
* Front spoiler;
* UV-cutting glass (front doors and windscreen);
* Dual cup-holders in the dashboard;
* Keyless entry;
This car has also been fitted with an Australian Standard all black wiring 3 point immobilizer, required for insurance. Don't overlook this point as you cannot insure these cars without one of these fitted. This is valued at $1000.00. It also has a turbo timer so the car can run and cool down after the key has been removed. The fitted system also rolls up all open windows and closes all sunroofs when you press the central locking button. Car is in perfect condition, however it has a small ding in the front bumper on the drivers side (pictured) when someone reversed into it and failed to leave their details. They have also scratched the paint on the front bumper. There is a small scratch on the rear passenger side quarter panel, which has removed paint, but apart from that the car is perfect. Please feel free to contact me with any questions or to arrange a test drive. Interior pictures will be uploaded shortly. The car is currently getting the interior detailed.
Car is located on the Sunshine Coast in QLD.
$14,500
https://www.sau.com.au/forums/topic/326761-1999-s2-nissan-stagea-14500/
  • 2 months later...
    • Very nice - I also have a 92 GTST and hardly see any others around these days
    • When I need something else to edit, I use Movavi. A friend who does video editing on a daily basis recommended me) it's an easy video cutter to use for beginners
    • I need to edit some videos for work but I'm not good at all this. Which video editor can you recommend?
    • I think you're really missing the point. The spec is just the minimum spec that the fuel has to meet. The additive packages can, and do, go above that minimum if the fuel brand feels they need/want to. And so you get BP Ultimate or Shell Ultra (or whatever they call it) making promises to clean your engine better than the standard stuff....simply because they do actually put better additive packages in there. They do not waste special sauce on the plebian fuel if they can avoid it. I didn't say "energy density". I just said "density". That's right, the specific gravity (if you want to use a really shit old imperial description for mass per unit volume). The density being higher indicates a number of things, from reduces oxygen content, to increased numbers of double bonds or cyclic components. That then just happens to flow on to the calorific value on a volume basis being correspondingly higher. The calorific value on a mass basis barely changes, because almost all hydrocarbon materials have a very similar CV per kg. But whatever - the end result is that you do get a bit more energy per litre, which helps to offset some of the sting of the massive price bump over 91. I can go you one better than "I used to work at a fuel station". I had uni lecturers who worked at the Pt Stanvac refinery (at the time they were lecturing, as industry specialist lecturers) who were quite candid about the business. And granted, that was 30+ years ago, and you might note that I have stated above that I think the industry has since collected together near the bottom (quite like ISPs, when you think about it). Oh, did I mention that I am quite literally a combustion engineer? I'm designing (well, actually, trying to avoid designing and trying to make the junior engineer do it) a heavy fuel oil firing system for a cement plant in fricking Iraq, this week. Last week it was natural gas fired this-that. The week before it was LPG fired anode furnaces for a copper smelter (well, the burners for them, not the actual furnaces, which are just big dumb steel). I'm kinda all over fuels.
    • Well my freshly rebuilt RB25DET Neo went bang 1000kms in, completely fried big end bearing in cylinder 1 so bad my engine seized. No knocking or oil pressure issue prior to this happening, all happened within less than a second. Had Nitto oil pump, 8L baffled sump, head drain, oil restrictors, the lot put in to prevent me spinning a bearing like i did to need the rebuild. Mechanic that looked after the works has no idea what caused it. Reckoned it may have been bearing clearance wrong in cylinder 1 we have no idea. Machinist who did the work reckoned it was something on the mechanic. Anyway thats between them, i had no part in it, just paid the money Curiosity question, does the oil system on RB’s go sump > oil pump > filter > around engine? If so, if you had a leak on an oil filter relocation plate, say sump > oil pump > filter > LEAK > around engine would this cause a low oil pressure reading if the sensors was before the filter?   TIA
