How much boost do you run? I'd be too concerned about the joiner blowong off the back of the afm. There is no lip on the afm to help hold it on. Ive also heard that Z32 afm's can be abit funny when used in a blow through system.
It's a fairly common practice relocating an AFM to cold-side piping when upgrading turbos, especially for those who prefer not to/can't use an ECU like a d-jetro or an EMS 8860 which do away with the AFM and run a MAP sensor.
Haven't heard of many cases where the joiner has blown off the AFM, but I suppose it does make it susceptible given it clamps onto a flat surface.
Edit: Also, to the OP, is this a high mount setup or on a low mount?
Edited by d1_drifter
For a flat surface. Drill say four small holes and put in self tappers. This gives total resistance to the hose blowing off. When the clamp comes up against the heads of the s/ts it cant move. Easy and cheap.
When setting the front facing plenum all the flat surface joins blew off. Why wont this SOB go???? LOL
Where is the bov in that engine bay??? Can anyone confirm the z32 not working in a blow through. Or will stock be fine for 16-18psi?
thats Simon-R32's drift car LINK to Build Thread. and being a track car having a bov probably isn't something he is worried about.
the maf will work blow through, it just depends on how you set it up, i've just heard that the Z32 can be a bit sensitive as to where you place it. couple of things to keep in mind are, the afm housing isn't designed to take pressure, and unless you have a good oil catch can setup you maf will need constant cleaning and the oil contamination may even reduce its life. i have seen a method where the hotwire was removed from the plastic housing and mounted into a steel i/c pipe which would help with the pressure and joiners blowing off.
a couple other options if you really want to keep a larger size inlet is to get a Q45 afm, they are 90mm which is just under 4". or track down a ford lightning maf which is also 90mm i believe, and is compatible with nistune.
but reducing the turbo inlet down to 3" is fine and will save you alot of trouble. i have my GT35 setup like this runnning 16psi (soon to be more) and without an issue, GT35 also has a 4" inlet. personally i wouldn't worry about it, 3" pipe will be easier in the low mount position, its very tight for space down there once all the i/c piping is in.
Edited by QWK32
I got a 4" to 3" silicone reducer and made up a S/S inlet pipe. Just welded in some nipples for the oil breather and bov return. Then used another silicine joiner to connect the steel pipe to the afm.
I did the same with a alloy bend and retained the stock airbox and airflow meter location. Keeps things nice and quiet. A few people have complained how loud the antisurge 4" inlet can be with no airbox and a pod used instead.
sorry if this is getting repetative but i want to be sure im doing to right thing as i need my car everyday so off the road time needs to be minimal. does everyone agrees gt3076r with .82 rear/oem bolt pattern, 4"-3" reducer off turbo then alloy/steele pipe to afm, 2" elbow into stock i/c piping??
only concern i have is will my car run on 14psi as it sits or do i need to do the fuel pump and nistune before i can drive it?
.82 rear housing does not come in an OEM 6 bolt pattern to the dump pipe. It is 5 bolt, so custom dump pipe
Need a 2" to 2.5" silicone reducing bend onto intercooler pipe. You will need to replace the cooler pipe as well to clear the 3" inch inlet pipe.
I could keep going, but I won't because fitting a gt3076r IW .82 is not straight forward and EVERYTHING need to be modified to get it to fit. Allow alot more than one day to fit if you do not have everything ready before hand.
I am running 14.5psi with mine making 245rwkw, so you will need the support mods to suit
What EXACT turbo do you have and what fitting parts do you have as well?
    • Thanks, I removed the fuse and the relay from the car and made my own circuit with them to test them with a test bulb.  I will look for the wiring diagram and go from there.
    • Jdm DC2R is also nice for a FF car compared to the regular hatches of the time.
    • Now that the break-in period for both clutch and transmission is nearly over I'd like to give some tips before I forget about everything that happened, also for anyone searching up how to do this job in the future: You will need at least 6 ton jack stands at full extension. I would go as far as to say maybe consider 12 ton jack stands because the height of the transmission + the Harbor Freight hydraulic platform-style transmission jack was enough that it was an absolute PITA getting the transmission out from under the car and back in. The top edge of the bellhousing wants to contact the subframe and oil pan and if you're doing this on the floor forget about trying to lift this transmission off the ground and onto a transmission jack from under the car. Also do not try to use a scissor jack transmission lift. You have to rotate the damn thing in-place on the transmission jack which is hard enough with an adjustable platform and a transmission cradle that will mostly keep the transmission from rolling off the jack but on a scissor lift with a tiny non-adjustable platform? Forget it. Use penetrating oil on the driveshaft bolts. I highly recommend getting a thin 6 point combination (box end + open end) wrench for both the rear driveshaft and front driveshaft and a wrench extension. These bolts are on tight with very little space to work with and those two things together made a massive difference. Even a high torque impact wrench is just the wrong tool for the job here and didn't do what I needed it to do. If your starter bolts aren't seized in place for whatever reason you can in fact snake in a 3/8 inch ratchet + 6 point standard chrome socket up in there and "just" remove the bolts for the starter. Or at least I could. It is entirely by feel, you can barely fit it in, you can barely turn the stupid ratchet, but it is possible. Pull the front pipe/downpipe before you attempt to remove the transmission. In theory you don't have to, in practice just do it.  When pulling the transmission on the way out you don't have to undo all the bolts holding the rear driveshaft to the chassis like the center support bearing and the rear tunnel reinforcement bar but putting the transmission back in I highly recommend doing this because it will let you raise the transmission without constantly dealing with the driveshaft interfering in one way or another. I undid the bottom of the engine mount but I honestly don't know that it helped anything. If you do this make sure you put a towel on the back of the valve cover to keep the engine from smashing all the pipes on the firewall. Once the transmission has been pulled back far enough to clear the dowels you need to twist it in place clockwise if you're sitting behind the transmission. This will rotate the starter down towards the ground. The starter bump seems like it might clear if you twist the transmission the other way but it definitely won't. I have scraped the shit out of my transmission tunnel trying so learn from my mistake. You will need a center punch and an appropriate size drill bit and screw to pull the rear main seal. Then use vice grips and preferably a slide hammer attachment for those vice grips to yank the seal out. Do not let the drill or screw contact any part of the crank and clean the engine carefully after removing the seal to avoid getting metal fragments into the engine. I used a Slide Hammer and Bearing Puller Set, 5 Piece from Harbor Freight to pull the old pilot bearing. The "wet paper towel" trick sucked and just got dirty clutch water everywhere. Buy the tool or borrow it from a friend and save yourself the pain. It comes right out. Mine was very worn compared to the new one and it was starting to show cracks. Soak it in engine oil for a day in case yours has lost all of the oil to the plastic bag it comes in. You may be tempted to get the Nismo aftermarket pilot bearing but local mechanics have told me that they fail prematurely and if they do fail they do far more damage than a failed OEM pilot bushing. I mentioned this before but the Super Coppermix Twin clutch friction disks are in fact directional. The subtle coning of the fingers in both cases should be facing towards the center of the hub. So the coning on the rearmost disk closest to the pressure plate should go towards the engine, and the one closest to the flywheel should be flipped the other way. Otherwise when you torque down the pressure plate it will be warped and if you attempt to drive it like this it will make a very nasty grinding noise. Also, there is in fact an orientation to the washers for the pressure plate if you don't want to damage the anodizing. Rounded side of the washer faces the pressure plate. The flat side faces the bolt head. Pulling the transmission from the transfer case you need to be extremely careful with the shift cover plate. This part is discontinued. Try your best to avoid damaging the mating surfaces or breaking the pry points. I used a dead blow rubber hammer after removing the bolts to smack it sideways to slide it off the RTV the previous mechanic applied. I recommend using gasket dressing on the OEM paper gasket to try and keep the ATF from leaking out of that surface which seems to be a perpetual problem. Undoing the shifter rod end is an absolute PITA. Get a set of roll pin punches. Those are mandatory for this. Also I strongly, strongly recommend getting a palm nailer that will fit your roll pin punch. Also, put a clean (emphasis on clean) towel wrapped around the back end of the roll pin to keep it from shooting into the transfer case so you can spend a good hour or two with a magnet on a stick getting it out. Do not damage the shifter rod end either because those are discontinued as well. Do not use aftermarket flywheel bolts. Or if you do, make sure they are exactly the same dimensions as OEM before you go to install them. I have seen people mention that they got the wrong bolts and it meant having to do the job again. High torque impact wrench makes removal easy. I used some combination of a pry bar and flathead screwdriver to keep the flywheel from turning but consider just buying a proper flywheel lock instead. Just buy the OS Giken clutch alignment tool from RHDJapan. I hated the plastic alignment tool and you will never be confident this thing will work as intended. Don't forget to install the Nismo provided clutch fork boot. Otherwise it will make unearthly noises when you press the clutch pedal as it says on the little installation sheet in Japanese. Also, on both initial disassembly and assembly you must follow torque sequence for the pressure plate bolts. For some reason the Nismo directions tell you to put in the smaller 3 bolts last. I would not do this. Fully insert and thread those bolts to the end first, then tighten the other larger pressure plate bolts according to torque sequence. Then at the end you can also torque these 3 smaller bolts. Doing it the other way can cause these bolts to bind and the whole thing won't fit as it should. Hope this helps someone out there.
