I grabbed these because they were cheap and they are Endless copies. Never really planned on using them, just curious to take a closer look at them.
They came out around the same time as the HKS/Endless jobbies. They appear to be identical to the VTTR 6 pot setup, Central 20 Setups so seems there are plenty of people re-badging the same brakes out of the same factory. Though i doubt they are from teh same factory as Endless as the quality does not appear to be comparable
These are an ex demo set that have been on display, I grabbed them because I was curious to see how good a setup they were for the money. My mechanic looked them over and said they are decent enough and comparable to the G4/D2 things. Being a copy of the Endless calipers pads etc shoudlbe easy.
They come with calipers, mounts, lines, pads and 2 pce rotors which i understand are 332x 30. They could be 330x30mmmcant say as I have not measured them up. They are suitable for R32/33 GSTts and S13/14 and 300ZX. Unused, not even bolted to a car and still in packaging
Will see if I can arrange someone to take pics of the setup for me
Asking $1650 + delivery. $1,600 if you can do pick up
https://www.sau.com.au/forums/topic/326788-kts-6-pot-brake-setup/
  • 1 month later...
Will be posting pics any day....after having a close look at them they seem like good things. Caliper and rotor assemly seem nice and light and well made. I am now thinking about actually using them as they look easily comparable to the G4 etc setups comign out of Asia somewhere, and I can see why VTTR and Central 20 etc are using them. I am guessing they are Taiwanese and originally made by VTTR.
The ones I have for sale are silver (caliper) with slotted rotors, with lines, mounts and pads. Bolt on
  • 3 weeks later...
    • I’d love to find some where that can recover the dashes to look brand new and original. Mine has a very slight bubble, nothing compared to come I’ve seen though
    • $170K. I asked one of the guys there as a joke if that price was just for the passenger seat as it was where the price sheet was... he tried really hard to crack a smile 😄 He also mentioned that every single part of the car was inspected and either restored or replaced with a new or as new part, or made from scratch. The interior was incredible, every inch like a new car.
    • Time for a modernisation, throw out the AFM, stock O2s, ECU into the e-waste bin. Rip out the cable throttle, IACV, pedal, etc. into the scrap metal bin. DBW, e-throttle, modern ECU, CANbus wideband, and the thing will drive better than when it left the factory.
    • I agree, don't go trusting those trims. As I said, first step is to put the logger away, and do the basics in diagnosis.   I spend plenty of time with data loggers. I also spend plenty of time teaching "technicians" why they need to stop using their data loggers, and learn real diagnostics.   The amount of data logs I play with would probably blow most people away. I don't just use it to diagnose. I log raw CAN data too, as a nice chunk of my job is reverse engineering what automotive manufacturers are doing.
    • I'm aware, but unless you're actually seeing the voltage the ECU is seeing and you're able to verify the sensors are actually working I find it hard to just trust STFT/LTFT. I will say, logging the ECU comes naturally to me because it's one of the lowest effort methods of diagnosis and I do similar things in my day job all the time. Staring at 20+ charts looking for something that isn't quite right isn't for everyone. NDS1 allows you to log almost everything so that's normally what I do and then sort out the data later.
