Ive been slowly collecting bits for my R34 while the MRS was using it, her new car is here at last so ive been bolting them all together.
I want to get into the one day tarmac rally, dutton type thing. There is one coming up in September and im very seriously considering entering as the car should be done by then, well by done i mean everything i have bolted on.
What im asking is if you guys with more experience can suggest anything else i need, or should do.
Spec's below:
1998 R34 Sedan
Manual
Full 3" exhaust
K&N Panel filter in stock airbox
Splitfire's
Possibly have a FMIC by then (planning to go a JJR stealth one)
18 x 9.5 +15's
HKS coilover's (not stiff at all)
Front Adj castor rods
Front Adj Camber
Rear Adj Camber
Rear Adj Traction arms
HICAS cancellor
Shimmed LSD
New rack bushes, tie rods etc (car has done a few kays, more preventitive)
Stock Brakes
Now before we do it im yet to get some good brake's, thinking of:
Slotted front and rear rotor's
Project Mu B spec pads (have used before and i liked them, they OK?)
Braided line's
BMC stopper
And for tyre's some 235/40 Semi's all round, thinking toyo R888's?
I have a Nistune ECU to go into it but might not have it tuned by then, dont think im gonna get near 180KM/h anyway.
Is there anything im missing? Or should this be OK?
Im only intersting in having fun, not winning. I also dont want to break the car.
Thanks.
yes the list is not complete.....you will need stickers!
don't worry they are entry level type events. make sure the tyres have good tread if it includes wet events, and don't run brake pads that need warmth to work. Almost every event is over in 60 seconds and nothing has time to get hot
How much extra power can i expect from the stickers...
Tyre wise will the toyo's be OK? What compound should i go? Or shud i go a good street based tyre like a KU36?
don't over think this. More important to have a reliable car that you're comfortable and familiar with than having mods to make it go faster. Looks like the mods you ahve should do nicely.
The 888's will be fine. the Ku36 are a semi slick (they're rated as a 140 treadwear, so should be in the same category as the 888's, but they'r eno match).
If you can get all the suspension and brake work done and properly set up, then spend the rest of the time driving the car as your daily. Overall you'll be faster in a car that you know intimately than you will in a more heavily modified car that you've only driven a few times.
When I used to take my daily driver to a track I got times much better than the level of modification of the car suggested I should ever achieve. Knowing the limits of your car is better than having higher limits, but having no idea where they are.
My 2c anyway.
Thanks for the input.
I agree with the familiarity factor, it does help for sure. We have owned the car for 5 year's now and its also my 2nd 34 4 door, so i do feel comfortable in it.
Ive mainly focused on suspension, and then brake's (when the bank balance recovers) as personally i think the car is pretty quick now, and making it more powerfull is a option for later once i am more experienced, have been out of the racing thing got 3 year's (house and babys allways get in the way :D )
Time to look for sponsors i think...
I've used both:
-R888 is a genuine semi with 100 treadwear, and strong construction designed primarily for motorsport use.
-KU36 is an ultra high performance street tyre. 180 treadwear, mush softer sidewall construction, and high void area tread pattern. designed primarily for street use with occasional track days. Needs high pressure for track use, and being so much harder compound has far less traction.
The R888 is not the best semi available, but will be far better than the KU36 for the short, standing start events that Dutton style rallies are made of.
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
