Hello all,
I need a 12v ignition wire to turn on my thermo-fan controller in the engine bay.
Can someone please point out where I can get a 12v ignition signal from? Somewhere on/near the relay/fuse box?
I also need a 12v Aircon signal wire in the engine bay (would prefer to have it somewhere close to the battery and not the actual wires near the compressor)
I have read that the relays in the fuse box are negative switching (ie. constant 12v and activate by grounding)
Any help would be greatly appreciated!!
Thanks
The lot of you are useless!
Turns out there is a constant 12v going through the fuse in the engine bay. Couldnt find a 12v ignition so had to wire into the drivers side and piggy back off one of the fuses near the foot well.
Hopefully someone will know the answer to this question;
I need a 12v ignition source which ISNT accessories. ie. Once the engine is started and running then I have 12v. Not during Accessories.
Im thinking the 12v source for the injectors? Or is that on during accessories?
Thanks
Put in a relay... run the signal wire to something inside the car if necessary for an ignition signal - and use it to switch the supply from the battery. Simple & clean. Hell, do it nice and tidy and put the relay inside the fuse box in the engine bay like the others to make it nice and factory-looking.
mm, prob is I dont know what unit requires 12v after engine start haha. Everything is usually powered when key switched to accessories. ie. fuel pump prime. Only thing i can think of is injector voltage, but not sure if thats provided power during accessories or once engine is cranked.
Alternator? I think. There should be something that you can tap into that only powers up once the car is running, to prevent the alternator from trying to charge while the starter motors doing it's thing. Don't mean to be vague but not %100. Or buy a cheap shift light and set it to 800 rpm with a relay running off t?
ah alternator that sounds like a good idea! Might trace back the wiring from the alternator and see if there is any easy place to splice into.
Thanks for that.
Thanks for that.
No worries, not trying to be a smart ass or assume anything, but I meant one of the thinner wires coming out of the reg, not your main battery wire as this will have battery voltage all the time. The wire that switches the alternator light on the dash is the one I'm thinking of.
tap into the main harness comming off the key switch then run it outside its not that hard, i wouldnt even think about splicing off the injectors!
if ur set on getting an ignition off ur alternator then ill tell u what to do, i dont recommend it but, most will have a main battery (obvious) and a plug with 2 or so wires, 1 will be warning light (dont splice into this) and the other will be an ignition feed. the warning light will have a negative there when the keys on (which light up the warning light on ur dash) then once its charging it turns into a positive which make 2 positives going to the gobe on the dash (which cancels out the light)
and this is how to wire it up to a relay - please dont just run them straight off the ignition feed otherwise u'll blow fuses left right n centre.
85 - ignition source (in ur case spliced off the alternator)
86- earth
87- to ur thermo positive wire(s)
30- straight to the battery (use an inline fuse @ the battery) a standard 30amp relay will be fine
this way when u turn ur key on to ignition the relay will energize sending power straight from the battery to the fans, turn the key off fans go off, this is how u wanted it wired up right?
    • Yes...but look at the numbers. There is a tiny tiny fraction of the number of Joules available, compared to what is used/needed. Just because things are "possible" doesn't make them meaningful.
    • Thanks for taking the time to post that ! If anything changes or happens please do update us.
    • Somehow Vertimass/Oak Ridge National Labs has figured out a catalyst that can convert ethanol into C9-C10 hydrocarbons in basically a single step without ending up with a bunch of ethylene or similar waste products: https://patents.google.com/patent/WO2023224867A1/en I still don't think anything like this will keep us from needing to transition to EVs regardless along with all kinds of other electrification, but things like this will go a long way towards alleviating the problem of how to electrify things like planes. Renewable diesel is seemingly an easier problem as well, Chevron is already running refineries for the stuff and the primary feedstock is tallow and other waste fats from agriculture.
    • Ok so I have sorted everything with my uniclutch and  i can offer up a bit of feedback and some things that might help others.    I found problems with factory damper line. Weird shit and had trouble with peddle adjustment    I used this https://au.gktech.com/products/r33-gts-t-skyline-braided-clutch-line?_pos=2&_sid=22b01b9b9&_ss=r Also when adjusting peddle leave a bit of play. You can get into a over stroke condition easy.. Make sure you can push the slave forward after adjusting to confirm fluid can return to master then you will need to pump it up heaps…..not sure why but that’s how it is.    last thing the splined adapter is machined perfectly. If your input shaft is old like mine was I would put a bit of valve grinding paste on it and stroke it like a 15 year old. Just to give it a tad more clearance and to better match it to the spline.    reason is on a near flat shift I have had situation where the peddle returns a millisecond after you lift from the clutch. No slip or anything but I reckon this is due to tolerance on the spline being way tighter than stock clutch and binding for a sec. I think this will go away but also my spline was old. Box is old so I guess I should have checked better. It’s a super neat fit.    it feels light as and holds awesome without any noise
    • My Fuga Hybrid is JDM, 2014 model but very similar to the V37 from the looks of things..same platform just physically larger and very comfortab;e
