Hi Guys,
I just brought some new Gabriel ultra shockies and I am looking to fit them this weekend. any hint's / tips for doing this. I'd say I'm pretty savvy with most things related to my cars, But I have never changed the suspension in one of my vehicles before, I have watched a few how to's and such but from a skyline PoV are there any things i need to be aware of?.
Cheers in advance.
https://www.sau.com.au/forums/topic/326833-suspension-change-r32-skyline-gts-t/
yeah its not too hard, make sure you use jack stands as the bottom bolts are usually really tight, and need alot of force to undo but apart from that is not really hard to see where everything needs to be undone once your under there and have a look.
when taking out the struts lift them out and over the hub, dont try to pull them out from the bottom. you may need to use a breaker bar to push the strut of the bottom bolt as it can be a bit tight even when you take off the nut.
when putting suspension back in, lightly do up top bolts first then do the bottom one.
also its alot easier if you get someone to help you put the struts back on as they'll need to push the hubs down so you can line up the bottom bolt, just get them to push hub down with their feet.
Edited by dr_hoon45
Hi Guys,
Cheers in advance.
Have you searched on these forums mate?
I've read some pretty in depth "How-to" threads with photo's for this job on here :D
    • @soviet_merlin Thanks mate!  Nothing too major but will hold me up for a while. I've got lymphomas to get taken off the back of my neck and the middle of my spine which always conjures scary thoughts!  It sounds worse than it is. Yeah great, conjuring more rabbit hole deepening , just what I need! 🤣
    • I'd argue the F50 kit I got is very good value. For ~2k I got the calipers (refurbed condition), adapters, pads, brake lines, rotors, and top hats. I think you'd be pretty hard to get Evo/GTR/350z brembos + the additional hardware for similar money. Used market for a pair of front calipers alone I've seen tend to run anywhere from $1500-2000 depending on condition.    That said, something like a GTR or 350z brembo is a lot easier to adapt to the Silvia.
    • Is there a significant price difference between the Evo/gtr/350z brembos vs the F50? Looks amazing.
    • I was actually being a tightarse at the time LOL... My OCD is tickling me into running a 2nd 8AN Teflon hose all the way down and removing the 2x OEM hardlines. My other side of my brain is telling me to run 2x hardlines front to back (also acts as a fuel cooler, so win win).
    • As I mentioned in an earlier post, I had some trouble with the Silvia's brakes dragging back in 2023. I managed to sort it out then, but the same problem came back to bite me late last year. Just take a look at the picture – I had a feeling the handbrake was acting up again, and I was right. Anyway, I'd been wanting to upgrade to bigger brakes for a while. Not that the Silvia's brakes were bad, but it was more of a "want" than a "need", you know? It was funny, though – at the time, I couldn't find any Evo Brembos, 350Z Brembos, or GTR Brembos for a decent price (of course, tons of them popped up online after I already bought my kit!). I ended up going with an F50 Brembo kit, which came with adapters, brake lines, 330mm rotors, and top hats. The F50 Brembo caliper was used in a few other cars too, like the FPV. I also decided this was the perfect opportunity to ditch the Silvia's ridiculous rear brakes and that awful handbrake (some of you were definitely right about that!). I picked up some R33 calipers and all the necessary bits – rear drums, backing plates, and new hardware to refurbish the calipers. Of course, it wouldn't be a project without a few hiccups. Turns out the brake master cylinder was playing up and basically (to put it simply) keeping the brakes engaged. I had it overhauled, and after some adjustments, everything was working again. The whole process took a while, as you can imagine. To top it off, the front right wheel bearings were shot and needed replacing too. This is a rare occasion where I'm posting an update while it's all still fresh! These pictures were taken just this afternoon.
