Andrew,
A good mate of mine up your way (his nick is 'third' on SAU) has been researching this exact topic recently! He has a '97 GT-R with a quite a few mods (311awkw SAS dyno) & at times runs 20+psi.
As you can imagine he's had a wide range of responses on the stock BOV topic. Jim from CRD seemed to think the stock BOV's weren't a problem even at mid 300kw levels (at wheels). We asked a few local Adelaide tuners & one of them said straight away that above 15psi & they "can" leak.
He is planning on doing a bench level pressure test to see exactly what psi his BOV's open, may have already done it?
No prob's mate. It 'may' take a little while for him to reply as he's not a frequent SAU user (posted twice in total) Tell you what, I'll give him a ring tonight & see what he's got to say.
Do they leak easily?
I'll be running upto 1.5  bar... Will the stock BOVs be okay? Or will they be leaking causing me to stress the turbos out unnecessarily to make 1.5 bar at the plenum?
Theyre crap, want to sell them to me or trade for Blitz DD setup? :):D
Being serious though, ive been told by many a shop they can hold decent amounts of boost without leaking (upwards of 1 bar). If you do take them off, send me a PM as ill be extremely interested in buying them. The Blitz ones are cool and all, but nothing compares to the woosh noise the stock ones make.
Hey, thanks heaps for the help guys!
Amaru: I'll probably end up replacing them with a single Trust Type-R BOV in a few months time... If I do, I'll send you a PM...
YRL05S: That would be great, but does your compressor have variable psi? If not, how will you know what pressure it takes before they open? Let me know how you go :)
  • 2 months later...
Merli,
I have used Blitz ones and they make the car run terrible. Boost isnt responsive and idle is horrible. On recommendation from HKS Japan, I have returned to the standard GTR ones. Even HKS do not recommend replacing the bov. Even if using a hks item.
Quote: "BOV changea.. noo good.." "Original good"
FYI: this was for a gtr running 2530's.
Whoa... this is an old thread! :D
Butthead: I'm not going back to stock BOVs, I have them on there at the moment, and I was worried that they would open prematurely and leak, causing my turbos to spin extra hard to make the 1.5-1.6 bar I want at the plenum... So I started this thread to see if I would need to change to a Trust Type-R or something like that... Seems like the stockies will work just fine!
Thanks N/A... Sounds like the stock bovs are going to stay! :(
Kamikaze: Not sure whether they're spring or diaphragm-type bovs... In fact I don't even know if there's a difference :)
Guest INASNT
we should ask leewah how they are as he still uses them on the 500rwkw plus gtr
the ice supra which has 400+rwkws runs these aswell aparently
niges supra is putting down 500rwkw with 2 bar boost now and still using stock GTR bovs just like Leewah, so i guess they aint that bad.
I got some in my car now as well and its holding 19psi and 280rwkw easily
    • To be fair passengers who aren't silly and have been in proper fast cars have often been pretty impressed once you hit 4th gear
    • I suppose that's true. Barring almost any situation, I'll never sell so what the market does is kind of irrelevant to me. It's possible I'd make most of my money back. That spreadsheet I mentioned? Maybe I could make back more than what the car's total costs thus far are, but the parts and all that is possibly a different story... Thanks for reading. It was certainly a good moment and just makes the ties to the car that much stronger. It's exciting that the option will be there to bring it over, however I have some plans with a shop that may end up keeping the car there longer, not sure. Coupled with the fact I want to move there and haven't solidified any path yet. So in a way, it feels like I'm in a limbo state that is uncertain; time will tell.
    • No worries, everything worked out in the end. I just wanted to make the point that it doesn't matter where it comes from (I.E Australia), it can be broken or improperly built. I would still purchase from these companies in the future. B2R - Not certain how that finished, this was on a car I wired a few things and street tuned. I know the owner ended up shipping the motor back to Australia for investigation. Hopefully some of it is covered under warranty.  Turbosmart - I always pressure test everything that goes on my car. It's a habit from my career in oil and gas. I run two 40mm's and both had major leaks from the actuator to exhaust portion through the shaft. I returned both, they shipped me back two and one was leaking and the other had a 38mm top (40mm gate with 38mm actuator cap, no idea how that happens). Eventually after a lot of back and forth I found myself with two non-leaking gates. I believe this happens a lot more then people would like to believe but you would never know if you don't pressure test them prior to installation. Crank Motorsport - Issued a full refund and let me keep the seat rails. I turned them into scrap metal for other projects. GKTech - Shipped me out a replacement and asked that I modify it as per my idea and that they would do the same for a future revision. ATP - Can just needed a large shim to bolt up properly.  Haltech - They started an actual proper Beta channel for firmware's a few months back and stopped using the general public for testing. I'm now much happier.  Speedtek - f**k Speedtek. I would love to watch them burn.
    • I've got a Turbosmart wastegate, ATP catch can, many GK Tech parts and Haltech everything. Everything's been perfect, sorry to hear your experience wasn't the same
