ok , to cut a long story short , after a recent and very basic service , our s2 Stagea has started playing up. Initially after the service it was working just fine, running smooth as anything, After a few days it started to misfire, I was not driving the car at the time but basically it was reported that the car was juddering, this only happened about 1.5 days after the service.
The only things done on the service was plugs , oil , oil filter , so pretty basic, something I have done many times before. After my partner Loretta started complaining of the car playing up I took the coil packs out , sprayed electrical contact cleaner on everything , re assembled and checked.
The car definately feels its running on 5 cyl. I am either thinking its the coilpack loom/harness that is at fault ( because a few of the plugs dont feel like they click into the tops of the coilpacks ) , as a temporary fix I cable tied all the coilpack connectors to the top of the coilpacks, so I am pretty sure its not a loose connector there.
I need the following
a) borrow a known working good set of RB25DET NEO coilpacks, payment in beer/cooked goodies
b) find somewhere that I can get a good deal on some Splitfire coilpacks delivered to WA by Thursday at the latest.
c) Borrow/Buy a known good coilpack harness/loom , so I can eliminate the loom as being a problem.
Guys and gals , I am seriously in the sh1t here cause I need the car running reliably preferably before the weekend as we were supposed to be going on a trip down South , could it possibly be worse timing?
I can be contacted via mobile on 041-991-6324
Sounds really similar to a problem my mate's s2 had - fixed by cleaning the AFM out with contact cleaner.
I dont think thats it hey, cause last night I got home and took the car for a boot around the block and could not fault it, so just to be sure I took the coilpacks out ( didnt touch afm at all ) , had a look and re-assembled, and the car actually got WORSE.
So in my mind I disturbed 1 part ( coilpacks and coilpack harness) and the problem got worse, this would indicate its probably a failing coilpack.
do you agree?
exactly the same scenario here. Some times it would drive perfectly and if it started to run rough, giving it a bootful of throttle would fix it once it got over about 4000rpm. Thought it was coilpacks, replaced them and the car ran better when it was running but gradually got worse and worse. Put the AFM from my Stag in it and it ran perfectly.
do you agree?
Hey Shaun, I do have a working set spare.
I am putting a new set in mine when the engine is completed this coming week. Sorry don't have a harness. But do have lots of other bits. Did you check the plugs?
    • Also had a look at the Nissan JP website looks like the 400r has a slightly shorter ratio than than the regular V37 3.133 VS 2.937 which from a guy who has driven both 3.69 vs 4.11 ratios in the S15 is bugger all. Seems that the AUTO Z runs the same ratio as the 400R but can't find any info as to if its an open or LSD? More often than not the auto LSD is open
    • Do not replace the power steering lines with this stuff. If it's anything like the Chase Bays stuff it will leak and be worse than stock. The reason why the reservoir is on the LH/passenger side of the car is because that's just where the reservoir was most convenient to fit. Don't overthink this stuff. The intake/cold side of the engine is pretty busy on these cars. And again, the hardpipe is designed to be a janky power steering cooler. In theory you can replace it with a real power steering cooler but that's really only for track use where boiling the fluid is a distinct possibility. Start with the low pressure lines feeding the pump from the reservoir. Make sure there isn't a bunch of junk in the reservoir filter. Be careful to not get ATF all over the engine bay. I hate dealing with ATF spills, you can clean it up and the slightest crevice will still release more oil that can still drip over time. You also want to inspect for leaks before you make a mess and can't tell what happened. Most likely you have a leak somewhere that is allowing fluid out and air in. Failing that it's allowing air in but not fluid out. Only place I can really see that happening is on the low pressure side because the pump will pull a slight vacuum to draw fluid in. Everything after the pump is high pressure or lower pressure, approaching atmospheric by the time it returns to the reservoir.
    • I did a skidpan night at SMSP this week, it was much cheaper than $350. But yeah, you need to slap an LSD in that thing.  I put an OS Giken in the 370Z and it's f**king MARVELOUS even compared to Nissan's viscous LSD. So you're saying it's free now that it's a housing estate? 😂
    • Nah, the car seems to run exactly as it did prior, in saying this it does "seem" to be better down low, like more eager to rev, but that may be 100% placebo effect from intake noise But, I'm not worried about it at all, in the end it is a fairly low compression NA engine that has a well shrouded intake,  if it is getting hotter IAT I cannot notice anything negative performance wise from the seat of my pants thrashing it about on the street or sitting in traffic, so meh, car now now makes induction noise so I'm happy
    • Do you have an IAT sensor? It's worth checking it to see. You may be suprised how little gap you actually need to flood your engine with hot air. (I tape up my airbox for a reason) :p
