Installed a pair goodridge braided brake lines
Did a full fluid flush with this stuff while i was there..
Parts from nissan arrived!
Part numbers are in the pic below for future reference;
Clutch master cylidner Piston kit to suit R32/33/34 GTR: 30611-05U25
Clutch booster R32/33/34 GTR: 30630-05U01
Pulled the plenum off again to fix the high idle (1250-1300rpm)
Clutchbooster/master assembly removed - bitch of a thing to remove, had to undo the brake pedal and pull the brake booster out to be able to remove the pingpingpingping of a thing
Booster fail
Breakdown of the parts inside
Master cylinder assembled
Bolted onto the new booster
Back to the idle problem..
You can see the air comming through the tiny gaps which is causing the high idle
Tomei to the rescue
Throttles installed
Currently idles at a solid 1000rpm with idle screw in half way - powerfc wont let me go below 1000rpm so need to tweak that down to 950 and she will be sweet!
I've also put the propshaft back in so no more rwd fun for me. =[
Next up on the to do list:
-front suspension - dumping the front roughly 1 inch lower and possibly the rear too just a tad
-ordering in a just jap catch can
-install my gear and handbrake boots
thanks mate :)
i went to my tuner yesterday arvo and he dropped the idle down to 950 however he had to tweak some settings in the the power fc and add some more fuel into the idle as it had a lean idle hunt.
Idles perfect now :)
Well i finally got my ass down to the drags.
Was aiming for high 11s but failed :( my launches should have hooked up better but thats the best i could do on the night
my two best best runs where 12.129 @ 109.6mph and 12.172 @ 112.35mph.
http://www.youtube.com/watch?v=z1Vm4cebsX4
http://www.youtube.com/watch?v=XL8tiZfohFg
Edited by snozzle
Nice man! looking the goods
I took mine to the drags on the weekend and managed a 12.6 with 1.9 60ft only (233rwkw)
Looking at the vids I think you could change gears a little quicker mainly going to 3rd and 4th and try avoiding limiter I found that helped me a lot on the day.
Also I had like 10 runs so lots of practise was great to get the times down.
GL with the 11s mate not far off!
Slower gear changes r good for the standard syncros, trying to ram them in at 9000rpm mainly into 3rd is going to result in a blown box quickly.
Even with my os giken set I still don't try n smash them in
  • 1 month later...
This car has gone through a great evolution since i owned it in Adelaide about 2 years ago now. Im glad to see you could put the money into it that i wanted to do but couldnt afford to do while having a mortgage.
I would love to drive it now that it has an extra 70 kw at the wheels from when i owned it. Keep up the good work :)
Update time:
2 weeks ago i got a yellow sticker on the car as I drove past a few cops setup near my workshop that were checking the contents of commercial vans/utes and even big trucks
and heres a pic of it as it went over the pits:
List of things i had to do..
Fit stock suspension
Fit 34R wheels with good tread
Remove HIDS
Remove LED park lights
Secure Pod filters with brackets
Fit child restraint brackets
Remov PowerFC hand controller
Fit a stock exhaust system with a stock(ish) cat
Remove tint as its too dark <---most painful part :rant:
And after all that it passed first go!
So instead of bolting back on my old do-luck exhaust i actually sold it as I was getting sick of how loud it was and I bought a 5zigen system last week from a local shop called Styled to Race in O'connor.
I must say, it is VERY quiet even with a decat which was what i was after but i didnt think it would be this quiet lol
Performance is still quite similar even though its a 3.14" system compared to my old 3.5" system which is excellent
and excuse the 4wd spec, rear end is still running standard shocks coz im too lazy to change them!
also, the ground clearance on the center muffler is kinda iffy.. im scared to dump it now lol
it seals the gap between the throttle plate and the throttle body bore when closed shut, when you clean them the seal thats there which isnt mentioned in the nissan manuals gets removed in some spots and causes an internal air leak on idle
it causes the engine to idle over 1000rpm depending on how bad the leak is even with the idle screw put all the way in. theres a pic in this thread that shows the air comming through which is where the extra air is comming in on idle causing it to idle high
Edited by snozzle
Nice thread dude, Even nicer car.
Thanks to you i have just realised why i have high idle! I recently cleaned my throttle boddies and must have same problem with air being let into the engine. f***ing throttle bodies, arghh.
Not looking forward to taking my bitch of a plenum off again!
    • A little more work this week.  Fitted astra power steering pump in the boot with a lowe fabrication bracket. Gave the pump a good clean, fitted Anderson plug and high pressure fitting. With the intercooler being flipped under rad support factory headlights weren't going to work. Ordered a set of origin battle lights, they arrived so got them test fitted. Will require some fiddling to fit nice but was an easy quick option for now. And today we pulled out the manual Rb gearbox and test fitted a ZF 8HP50. It will fit with some casting tabs cut off and small tap of the tunnel with a hammer. Pick up the adapter plate Wednesday so hopefully all bolted in Friday and measure for tailshaft which will be a 2 piece. Been doing a lot of ecu, pdm and tcu loom design so when comes to wiring it in a few weeks will all go smoothly.
    • FYP. Sadly. Even bolt cutters wouldn't take 2 sec. But in the days of 18v angle grinders, nothing is safe.
    • One piece driveshaft I would recommend a dual CV setup otherwise stick to OEM. I have heard most one piece driveshafts cause excess vibration otherwise. The transmission grind I'm quite familiar with. You can try shockproof gear oil, otherwise you need a new transmission. The shifter is extremely simple on these cars. If you want pull apart the assembly and replace the plastic bushing but I doubt that fixes anything. The tail light issue is very common, unfortunately new tail lights are long discontinued. The trunk antenna going up always is because your radio doesn't have a true power antenna control, just remote amp power signal. There is a blank switch plate that you can pop out and install a switch for this or alternatively source a head unit that has proper antenna control. Throttle body sticking you have to disambiguate by disconnecting the cable and seeing if the linkages are the problem or something else. There is a procedure to adjust them, refreshing them is also somewhat involved if that's the issue. I have dealt with many of these issues. Old cars really are fractals of problems. The more you fix the more you discover there is to fix.
    • Welp, you've got a long list of experiences right there. I'd say you're on the right path.
    • That's correct, suits my requirements a bit better. Sure there are also numpties there, however it's generally a different vibe and more my kind of vibe.
