Well, got quite abit of crap done today..
I did the final install of the manifold and wastegate, i also had to cable tie the aircon line toward the strut tower as it was too close to the manifold and also wrap it with some orange sleeving
heres some pics of how it sits at the moment, fitment of the turbo and all the lines are done:
it took me a couple of hours to adjust all the lines and hoses so that nothing at all is touching the manifold, the closest thing to it is around 5mm away and is wrapped in sleeving
Not long to go till i can take it for a quick spin.. still have to properly relocate the power steering reservoir, block off the bovs and bolt on the intercooler piping.
I take it Clinton is Kermit, looks good with the cover mounted like that, I tried mine like that but ended up going with it down cos of fouling issues,
No I am Clinton .... owner of DESAM8 R32GTR. ..... Front cover of Motive 10 and also featured in Performance Imports
As said before looking good OZ :)
Edited by EVILS13
Oh hi : ) my bad on that one, ur car is very nice
Man, this thing is awesome!
I see you have moved on from the fear of further police 'inspections'... Touch wood it doesnt happen again!
Did you lose any power going to the smaller diameter exhaust? Or need to retune it?
Anyway looking forward to seeing the results of the new install!!!
Ive actually sold the 3" 5zigen system that i bought new, i now have a 3.5" system on there now but the power difference between the two was very minimal!
Turbo setup is finally finished! The grin on my face after i took it for a spin around the block was priceless..... i am well happy with how it drives and not to mention how it sounds..
And ill just leave this here:
Next up is poncam install and its ready for a tune !
Pulled the engine covers off this morning, gave them a sand back with wet an dry and got them sprayed this arvo :)
Very happy with the depth of the colour too, im wondering how this colour would look on the rest of the car!
In that last shot at the bottom of the pic what is that speedflow 180deg fitting and line for? Just out of interest lol
Its the oil filter relocation. The white part is the oil filter. :)
SOOOOOOO much neater then twins....i sould of gone for a nicely sized single :S
interested to see what power you make @ what boost, and when full boost is made !
Me too! its actually quite responsive already, without a tune its making around 1bar on 4000rpm ! Thats as far as i want to rev the engine even though the knock hasnt gone over 20 so far.
Well car got tuned this morning.. it initially made 460hp on 18psi with the ebc set to 0%, that is the lowest boost my wastegate can run and then it made 485hp on 20psi.
It makes 1bar of boost at 4100rpm.. Full boost is at 4400rpm, pulls very hard even though its very wet today..
Drives smoother than ever! Feels like a new car smile.png Big thanks to the guys at Allstar !
how does it feel response wise compared to the previous twins?
any chance you could post up before and after dyno results
i duno if i missed it but what head work do u have done if any apart from the cams
    • Hey lads, reviving an old thread.  As an update, since the last time replied to this thread, ive done mostly suspension. Havent touched the motor except for maintenance. Though upon changing spark plugs, found out i had splitfires pre-installed! Updates: - Got me some stock airbox top cover and snorkel to fit onto the original intake. Should be free of defects - Bought a set of R34 GT-T brakes (not installed yet, going to rebuild + respray in champion blue + white 'Nissan' text) - Bought the last set of bilsteins from @Sydneykid and had them installed. Has been making some sounds on the rear but hopefully should be sorted out after this New Year break. - Regreased front caster rod bushings (poly bushes..) - Rear upper camber arms - Whiteline sway bars (BNF27Z 22mm + BNR11XXZ 24mm).  The rear sway bars are a bit short (ive read 50mm else where) but was still able to get them in.  Anyhows, I reckon suspension is sorted now. Maybe replace bushes (do have a set of front upper control arms from SK not installed yet) but should be okay for now. From now, I'm wanting to start working on the motor, drivetrain etc etc. Still debating on the order to go on and what to buy etc but: - ECU ( Haltech or Link ( Link states that it dont support A/T or AWD functions... Can anyone attest to this? ) - Highflow turbo ( ATR43ss2 ) - Intercooler ( Not decided yet, but cant find many good afoordable ones. Toshi says to opt for crossflow Japanese. Bit difficult this one, unless I get a returnflow Blitz from JJ? ) - Injectors ( Any recommendations ? I do have a nismo FPR ( Thanks SK ) ) - Seats - Tune by either Toshi or DVS To be fair, I did consider just keeping the stock turbo and nistuning it. Sat in a mates stock N, that had something like 200kw, and I reckon that felt more than enough. Maybe I should just go this route ahhaha. Too many choices.... Planning a trip down south, so wanting to just clean things up and make sure it gets to and from in one piece. Anything else specifically I should do before ? Cheers lads
    • Must be for the car’s lucky charm 🤷🏽‍♂️ She runs fine, but it just seems to take about 1L less. Maybe I’ll have the oil sump dropped at some point to check if there is anything
    • Hmmm interesting. Mine is the exact same and clearly the right one.  The mystery of the engine oil being full after 3.5-4L continues
