Installed a pair goodridge braided brake lines
Did a full fluid flush with this stuff while i was there..
Parts from nissan arrived!
Part numbers are in the pic below for future reference;
Clutch master cylidner Piston kit to suit R32/33/34 GTR: 30611-05U25
Clutch booster R32/33/34 GTR: 30630-05U01
Pulled the plenum off again to fix the high idle (1250-1300rpm)
Clutchbooster/master assembly removed - bitch of a thing to remove, had to undo the brake pedal and pull the brake booster out to be able to remove the pingpingpingping of a thing
Booster fail
Breakdown of the parts inside
Master cylinder assembled
Bolted onto the new booster
Back to the idle problem..
You can see the air comming through the tiny gaps which is causing the high idle
Tomei to the rescue
Throttles installed
Currently idles at a solid 1000rpm with idle screw in half way - powerfc wont let me go below 1000rpm so need to tweak that down to 950 and she will be sweet!
I've also put the propshaft back in so no more rwd fun for me. =[
Next up on the to do list:
-front suspension - dumping the front roughly 1 inch lower and possibly the rear too just a tad
-ordering in a just jap catch can
-install my gear and handbrake boots
thanks mate :)
i went to my tuner yesterday arvo and he dropped the idle down to 950 however he had to tweak some settings in the the power fc and add some more fuel into the idle as it had a lean idle hunt.
Idles perfect now :)
Well i finally got my ass down to the drags.
Was aiming for high 11s but failed :( my launches should have hooked up better but thats the best i could do on the night
my two best best runs where 12.129 @ 109.6mph and 12.172 @ 112.35mph.
http://www.youtube.com/watch?v=z1Vm4cebsX4
http://www.youtube.com/watch?v=XL8tiZfohFg
Edited by snozzle
Nice man! looking the goods
I took mine to the drags on the weekend and managed a 12.6 with 1.9 60ft only (233rwkw)
Looking at the vids I think you could change gears a little quicker mainly going to 3rd and 4th and try avoiding limiter I found that helped me a lot on the day.
Also I had like 10 runs so lots of practise was great to get the times down.
GL with the 11s mate not far off!
Slower gear changes r good for the standard syncros, trying to ram them in at 9000rpm mainly into 3rd is going to result in a blown box quickly.
Even with my os giken set I still don't try n smash them in
  • 1 month later...
This car has gone through a great evolution since i owned it in Adelaide about 2 years ago now. Im glad to see you could put the money into it that i wanted to do but couldnt afford to do while having a mortgage.
I would love to drive it now that it has an extra 70 kw at the wheels from when i owned it. Keep up the good work :)
Update time:
2 weeks ago i got a yellow sticker on the car as I drove past a few cops setup near my workshop that were checking the contents of commercial vans/utes and even big trucks
and heres a pic of it as it went over the pits:
List of things i had to do..
Fit stock suspension
Fit 34R wheels with good tread
Remove HIDS
Remove LED park lights
Secure Pod filters with brackets
Fit child restraint brackets
Remov PowerFC hand controller
Fit a stock exhaust system with a stock(ish) cat
Remove tint as its too dark <---most painful part :rant:
And after all that it passed first go!
So instead of bolting back on my old do-luck exhaust i actually sold it as I was getting sick of how loud it was and I bought a 5zigen system last week from a local shop called Styled to Race in O'connor.
I must say, it is VERY quiet even with a decat which was what i was after but i didnt think it would be this quiet lol
Performance is still quite similar even though its a 3.14" system compared to my old 3.5" system which is excellent
and excuse the 4wd spec, rear end is still running standard shocks coz im too lazy to change them!
also, the ground clearance on the center muffler is kinda iffy.. im scared to dump it now lol
it seals the gap between the throttle plate and the throttle body bore when closed shut, when you clean them the seal thats there which isnt mentioned in the nissan manuals gets removed in some spots and causes an internal air leak on idle
it causes the engine to idle over 1000rpm depending on how bad the leak is even with the idle screw put all the way in. theres a pic in this thread that shows the air comming through which is where the extra air is comming in on idle causing it to idle high
Edited by snozzle
Nice thread dude, Even nicer car.
Thanks to you i have just realised why i have high idle! I recently cleaned my throttle boddies and must have same problem with air being let into the engine. f***ing throttle bodies, arghh.
Not looking forward to taking my bitch of a plenum off again!
    • who can tell me what this is and why my car talks to me? i think it's hilarious. it's on my r34 right above the drivers-side storage compartment. the characters under the wrench say "inspection". every 10 or 20 startups, a voice starts talking in japanese from some speaker in this area below the dashboard. it says a few sentences then shuts off. different from the ETC card reader voice that happens every time i start the car. I've never found the speaker, i've never been able to catch the voice and translate what it says, and i've never found a forum thread that tells me how to reset the warnings. the holes in between the symbols are NOT buttons you can press to reset the warnings. anyone else have this? has the demon lord from Hereditary infected my car?!
    • Would you ever vent this bonnet or will it be unnecessary?
    • Happy new years folks! Wishing you all a successful year of money pit ownership!  So the subframe bushes are out....   Ok, who else has done that job before??  What a C U Next Tuesday of a job that is!  Be glad to not do that again in a hurry! I think I explored every option available to chop the middle section of the bushes out, most of them unsuccessfully! I tried a holesaw, die grinder, normal drill bit, air chisel, etc, etc. The true success happened by accident when I'd decided to try a step drill I spotted on the bench on the way passed.  See, there are benefits to never cleaning up after yourself! It RIPPED through so so much better than the drill bit. It has to be the skinniest one available so its small enough to fit between the inner tube and outer casing but it made easy work of it.  First one i hammered the shit out of... New method- 20250102_185506.mp4   I did the other 5 in less time than I fluffed around with the first one. With the first couple I used the cut off saw (sawsall as the yanks love to call them) to cut a break in the outer casings. Even with that they're still a prick to hammer or air chisel out.  The last few i just went rambo with the air chisel without cutting them. I over cut one of the early ones so will hit the with the mig to fill the cut then sand it off smooth.  The carnage left over-   I've also been "nesting" ie, cleaning up my babies nursery,  ie cleaning the f**king pig sty of a shed. I've got that much shit laying around it's as cluttered as my head!  Getting things put away, in boxes, on shelves, hanging off walls, all to get some working space back again.  Hopefully that keeps me motivated....
    • AFAIK does the base map for Haltech even have the 4D compensation enabled? It's been a while but when I looked at it I remember it was actually using pure TPS as one load signal and MAP for another. Seemed workable but not ideal by any stretch. A lot of people have "make the event-itis" which leads to stuff like this happening.
    • https://www.youtube.com/watch?v=qHhWelSBppY
