Well, got quite abit of crap done today..
I did the final install of the manifold and wastegate, i also had to cable tie the aircon line toward the strut tower as it was too close to the manifold and also wrap it with some orange sleeving
heres some pics of how it sits at the moment, fitment of the turbo and all the lines are done:
it took me a couple of hours to adjust all the lines and hoses so that nothing at all is touching the manifold, the closest thing to it is around 5mm away and is wrapped in sleeving
Not long to go till i can take it for a quick spin.. still have to properly relocate the power steering reservoir, block off the bovs and bolt on the intercooler piping.
I take it Clinton is Kermit, looks good with the cover mounted like that, I tried mine like that but ended up going with it down cos of fouling issues,
No I am Clinton .... owner of DESAM8 R32GTR. ..... Front cover of Motive 10 and also featured in Performance Imports
As said before looking good OZ :)
Edited by EVILS13
Oh hi : ) my bad on that one, ur car is very nice
Man, this thing is awesome!
I see you have moved on from the fear of further police 'inspections'... Touch wood it doesnt happen again!
Did you lose any power going to the smaller diameter exhaust? Or need to retune it?
Anyway looking forward to seeing the results of the new install!!!
Ive actually sold the 3" 5zigen system that i bought new, i now have a 3.5" system on there now but the power difference between the two was very minimal!
Turbo setup is finally finished! The grin on my face after i took it for a spin around the block was priceless..... i am well happy with how it drives and not to mention how it sounds..
And ill just leave this here:
Next up is poncam install and its ready for a tune !
Pulled the engine covers off this morning, gave them a sand back with wet an dry and got them sprayed this arvo :)
Very happy with the depth of the colour too, im wondering how this colour would look on the rest of the car!
In that last shot at the bottom of the pic what is that speedflow 180deg fitting and line for? Just out of interest lol
Its the oil filter relocation. The white part is the oil filter. :)
SOOOOOOO much neater then twins....i sould of gone for a nicely sized single :S
interested to see what power you make @ what boost, and when full boost is made !
Me too! its actually quite responsive already, without a tune its making around 1bar on 4000rpm ! Thats as far as i want to rev the engine even though the knock hasnt gone over 20 so far.
Well car got tuned this morning.. it initially made 460hp on 18psi with the ebc set to 0%, that is the lowest boost my wastegate can run and then it made 485hp on 20psi.
It makes 1bar of boost at 4100rpm.. Full boost is at 4400rpm, pulls very hard even though its very wet today..
Drives smoother than ever! Feels like a new car smile.png Big thanks to the guys at Allstar !
how does it feel response wise compared to the previous twins?
any chance you could post up before and after dyno results
i duno if i missed it but what head work do u have done if any apart from the cams
    • who can tell me what this is and why my car talks to me? i think it's hilarious. it's on my r34 right above the drivers-side storage compartment. the characters under the wrench say "inspection". every 10 or 20 startups, a voice starts talking in japanese from some speaker in this area below the dashboard. it says a few sentences then shuts off. different from the ETC card reader voice that happens every time i start the car. I've never found the speaker, i've never been able to catch the voice and translate what it says, and i've never found a forum thread that tells me how to reset the warnings. the holes in between the symbols are NOT buttons you can press to reset the warnings. anyone else have this? has the demon lord from Hereditary infected my car?!
    • Would you ever vent this bonnet or will it be unnecessary?
    • Happy new years folks! Wishing you all a successful year of money pit ownership!  So the subframe bushes are out....   Ok, who else has done that job before??  What a C U Next Tuesday of a job that is!  Be glad to not do that again in a hurry! I think I explored every option available to chop the middle section of the bushes out, most of them unsuccessfully! I tried a holesaw, die grinder, normal drill bit, air chisel, etc, etc. The true success happened by accident when I'd decided to try a step drill I spotted on the bench on the way passed.  See, there are benefits to never cleaning up after yourself! It RIPPED through so so much better than the drill bit. It has to be the skinniest one available so its small enough to fit between the inner tube and outer casing but it made easy work of it.  First one i hammered the shit out of... New method- 20250102_185506.mp4   I did the other 5 in less time than I fluffed around with the first one. With the first couple I used the cut off saw (sawsall as the yanks love to call them) to cut a break in the outer casings. Even with that they're still a prick to hammer or air chisel out.  The last few i just went rambo with the air chisel without cutting them. I over cut one of the early ones so will hit the with the mig to fill the cut then sand it off smooth.  The carnage left over-   I've also been "nesting" ie, cleaning up my babies nursery,  ie cleaning the f**king pig sty of a shed. I've got that much shit laying around it's as cluttered as my head!  Getting things put away, in boxes, on shelves, hanging off walls, all to get some working space back again.  Hopefully that keeps me motivated....
    • AFAIK does the base map for Haltech even have the 4D compensation enabled? It's been a while but when I looked at it I remember it was actually using pure TPS as one load signal and MAP for another. Seemed workable but not ideal by any stretch. A lot of people have "make the event-itis" which leads to stuff like this happening.
    • https://www.youtube.com/watch?v=qHhWelSBppY
