i think the first one it by far the best :)
now u must tell me how to do :):rofl:
Lol no way, it's about as cool as a fake bov
am curious, can you only get flames going without a catalyct converter?
That or very rich tune, or like the op, a flamethrower kit.
https://www.sau.com.au/forums/topic/326879-flame-on/#findComment-5322173
No cat, rich tune, atmo venting bov.
I used to get bigger/more predictable flames when under load, made tunnel runs amusing :rolleyes:
hahahha went on one the other nite with a vs ss chasing me so i slowed rite down and let the flame kit backfire... it was so loud omg.. hahhaa he soon backed off. :cool:
https://www.sau.com.au/forums/topic/326879-flame-on/#findComment-5322601
    • The cam I am actually putting in (a few posts up) is actually smaller than my current one. At least duration/overlap wise. All the chop stuff I hear just sounds like an engine running badly, because it is. I then envision driving it around in 1st gear and being massively sad about it bucking to the beat of said chop. There is an idle video of someone with a similar cam floating around the internet, but mine is a custom cam (so is his) so it'll never be the same, plus the fact exhausts are entirely different. What I want to do is put some bullet mufflers/race mufflers in to replace a couple sections straight pipes that currently replace the two extra cats that I don't need. But this is even further down the line!
    • I can tell you now, when the bracket that the little hydraulic ram attaches to snaps, with a subframe, and V8 from an AMG C63 on it, it sounds like someone letting shotgun off right beside you. It leaves your ears ringing, and a huge thankfulness that you never ever put a body part under something heavy that's only supported by a hydraulic lift...
    • Still not a guarantee fix. I used a high quality butyl-mastiq (the black goo that's not really silicone nor polyurethane, same stuff they use from the factory that just spreads out like melty cheese), and I still get lots of water on both sides of the trunk when raining or washing the car. I also suspect the factory spoiler rubber gasket might not be sealing well, so I'm thinking of adding a thin layer of grey silicone around the bolt holes on both sides and see if that's where it also leaks from. The biggest issue is that these cars don't come with a drain hole on each side like other coupes and hatchbacks.
