any map that someone will have won't be the best to use on your car. it would be good enough to maybe drive to the tuners with, but i certainly wouldn't drive far on it, or even try flooring it. you really need to get it professionally tuned. someone else with all those same mods may give you a map that is fine for their car, but when put on your ecu may run like crap or ping like crazy.
https://www.sau.com.au/forums/topic/326880-rb25det-map/#findComment-5320368
Agreed.
What do you need it for? The only reason you should be asking for this is to get it moving so you can limp it to the tuners...
Here are the Injector settings, you won't be able to start the car if you don't have these:
RB25=370 / 850 = 0.435 * 100 = 43.529%
0.85 - 0.528 = 0.322msec
https://www.sau.com.au/forums/topic/326880-rb25det-map/#findComment-5320388
Need it to start the engine, som testing and drive to the tuner.
https://www.sau.com.au/forums/topic/326880-rb25det-map/#findComment-5322168
How safe is it to drive to modify your nistune after you fit larger injectors, change the injector setting in the map?
Is the map still going to be okay and safe to drive? (daily basis, under load - not just to a tuner)
I ask because I have a car with relatively minor mods, and I've recently purchased 480cc nismo injectors & nismo fuel pump (in preperation for 'bigger things') and I'm wondering if I fit these whether it's going to be safe to drive it with only an injector setting change to the nistune. I'm obviously going to get no benefit from it, but it feels a bit dumb just leaving the injectors sitting around until I can afford to take the car to a tuner and get it all done properly ...
https://www.sau.com.au/forums/topic/326880-rb25det-map/#findComment-5322183
    • Yeah that's true, but idk. Only a 6 month lifespan seems a little short. Oh also, is there a preferred way to send images? Like any sites? I'm used to just being able to upload them lol
    • Hey, like MBS206 mentioned; I dropped off my short block and rotating assembly Monday. With a quick verification, he believes he can clear it up with just a hone and new rings but he will confirm once the rotating assembly is out. If I were you, I would either go stroker or just replace the block if it does need to be bored over to next size. Block is cheaper then forged pistons.
    • live in the UK, and London has introduced a Low Emission Zone (LEZ) that requires individuals to pay £13 if their car doesn’t meet the required emissions standards.   The standard specifies that NOx emissions must be less than 0.08 g/km (i.e., the vehicle must meet Euro 4 standards or better, which generally results in NOx levels of around 0.08 grams per kilometer).   I reached out to Nissan UK, and they advised me to contact Nissan Japan directly. Does anyone have contact details for Nissan Japan or any certifications of conformity that show the emission details or NOx levels for the RB25DET engine?   Any guidance would be greatly appreciated.
    • these guys recommended to me and supplied custom 4 inch mufflers, couldn't be happier. They will spec a muffler to your preferred level of sound and know RB's well.  https://spmufflers.com.au/
    • Yeah this used to happen to me every year and a quick call would at least raise the agreed value back up / reduce the premium, but usually both.    That said for the first time on the renewal this year our agreed values went up or stayed the same over the fleet and the premium came down so that was a nice surprise.
