hi my names dan and i live in cornwall in the uk i found your forum on anouther forum you have loads off information on here thats not in the uk. i thought i would post up my project and see what you guys think
ive had my car for almost two years now and i think its time for a change alot of saving to be done as i want to go for 400bhp and a full body kit and respray i will probably do the engine first unless some thing lands on my lap at the right price lol heres afew pics of when i first got the car
gettin a wash
the car still looks more or less the same just afew scrapes on it now ahhhhh bloody cornish headges lol
https://www.sau.com.au/forums/topic/326881-my-litlle-project-r33-gtst/
looks good
thought of doing any little things here and there to make it just that bit better, like cleaning front lights( getting rid of yellow ) .painting the black plastics all of the car making them look new again
dash LED's
as time whent by i started sourcing a few parts
hks bov on a hard pipe i thought i would blank off the std recic
home made recerc blanking plate
i bought a secondhand apexi air filter
this is when a saw that i had a apexi afm B)
then i put in my head unit and crappy boost gauge just to keep a eye on things
ave put some dls mids and tweets in the front doors with a full skins kit
got a alpine 12" sub and amp in boot only 350 watts got given a blown up 1500w alpine amp will cost me 120 to get it fixed then will have to find some speekers so i can have some bad ass bass
some more goodies to put on
hks ajustable actuator
hid lights
one thing that used to wind m up was that my interior light would turn off as soon as the door shut
so i fugued out this light stays on for ten secs after my door has been shut
ran a wire up from this to the map reading light and connected the two LEDs left over from my dash conversion
this is what it looks like at night a nice subtle light
in the day
with the other light on
this is only temp at the mo will mount the LEDs in there properly on the week end
me other mod a festoon 31mm 4 led light for the light in the middle of the car
in and working
well bright now with the defuser back on
both light together
clocks minus the plastic cover
you have to take the rev bit out and take the mmg gauge off
new dials going on
i put all the faces on the dials then realized i didn't have anything to stick the new faces down with so it was off to the shops minus a dash and clocks that was a bit weired lol right then got no pics of it going in because it was getting dark so ive got the dials in and wired up will be off in a moe to put it all back together this is how they look
right a few more bits done
got these changing all the bulbs behind the clocks to LEDs
the difference between the whits LEDs and the yellow stock clock bulbs
did this mod as well so the dipped head lights stay on when the main beam is on
got this oil cooler to fit soon and a gtr style grill
    • Knowing how slow their other compressors are that connect to the cars battery, you'd want to hope it's one hell of a slow leak!
    • So why can’t the front pipe just be listed as custom make? why does everything have to have a brand name to it? or if you have bought the car like this and have no idea about anything at all or no knowledge what so ever of parts how are you supposed to inform them of what it is you have exactly?
    • Yep, I'd be interested to hear how it works out in the end.
    • Because all parts that are put into your papers usually are assigned a badging if they did not come with one. So other people can just check that badging to tell if it is the parts your papes outline. But my pipe has NOTHING on it whatsoever. No idea why this even passed as a Mines pipe to begin with. I see this going two ways: -nobody cares and it's a non-issue, but that is unlikely -the pipe will just have to be assigned a bagding, for sake of argument, a Mines logo, and the papers corrected accordingly If it interests you I will post what the actual solution ended up being. All I care about is that it has to sound equal length and nobody can screw me later on because of a pipe being illegal.
    • The fasteners to the pipe are not subject to TÜV I guess, if we really start putting nuts and bolts through technical tests I'm going to hang the people responsible and then myself. Usually on a modern-ish EU normed car, you would just replace the pipe. Because if you start hacking away at it and welding new pieces on the cops will definitely find a reason to tow your car. That is just how it is sadly. On old cars and imports with no clear "standard" stuff like that won't matter too much. Most cops or inspectors probably won't even really know what they are looking at. But there is experts for this stuff even among cops, and some of them know the rules to a T and even have extensive knowledge about many vehicles. For "just a pipe" to be legal it usually is included in a set of parts, like a complete intake kit or a full exhaust. For example my exhaust needs to pass a noise test, meaning they have a standardized test track with a set of instructions and they run the car through there 3x for an average noise value that is 75dB(a) at point x of the test track. If it's above that, fail. For a turbo setup to be put in your papers you have to do dyno runs, emissions testing etc. So quite costly
