hi my names dan and i live in cornwall in the uk i found your forum on anouther forum you have loads off information on here thats not in the uk. i thought i would post up my project and see what you guys think
ive had my car for almost two years now and i think its time for a change alot of saving to be done as i want to go for 400bhp and a full body kit and respray i will probably do the engine first unless some thing lands on my lap at the right price lol heres afew pics of when i first got the car
gettin a wash
the car still looks more or less the same just afew scrapes on it now ahhhhh bloody cornish headges lol
https://www.sau.com.au/forums/topic/326881-my-litlle-project-r33-gtst/
looks good
thought of doing any little things here and there to make it just that bit better, like cleaning front lights( getting rid of yellow ) .painting the black plastics all of the car making them look new again
dash LED's
as time whent by i started sourcing a few parts
hks bov on a hard pipe i thought i would blank off the std recic
home made recerc blanking plate
i bought a secondhand apexi air filter
this is when a saw that i had a apexi afm B)
then i put in my head unit and crappy boost gauge just to keep a eye on things
ave put some dls mids and tweets in the front doors with a full skins kit
got a alpine 12" sub and amp in boot only 350 watts got given a blown up 1500w alpine amp will cost me 120 to get it fixed then will have to find some speekers so i can have some bad ass bass
some more goodies to put on
hks ajustable actuator
hid lights
one thing that used to wind m up was that my interior light would turn off as soon as the door shut
so i fugued out this light stays on for ten secs after my door has been shut
ran a wire up from this to the map reading light and connected the two LEDs left over from my dash conversion
this is what it looks like at night a nice subtle light
in the day
with the other light on
this is only temp at the mo will mount the LEDs in there properly on the week end
me other mod a festoon 31mm 4 led light for the light in the middle of the car
in and working
well bright now with the defuser back on
both light together
clocks minus the plastic cover
you have to take the rev bit out and take the mmg gauge off
new dials going on
i put all the faces on the dials then realized i didn't have anything to stick the new faces down with so it was off to the shops minus a dash and clocks that was a bit weired lol right then got no pics of it going in because it was getting dark so ive got the dials in and wired up will be off in a moe to put it all back together this is how they look
right a few more bits done
got these changing all the bulbs behind the clocks to LEDs
the difference between the whits LEDs and the yellow stock clock bulbs
did this mod as well so the dipped head lights stay on when the main beam is on
got this oil cooler to fit soon and a gtr style grill
    • They see me rollin' they hatin'....... Took me most of the day to make the necessary mods to the mounts to make them fit the car.  Fortunately I was able to just use the mounts that came with the rotisserie. The rear ones are really secure, the front I feel i might reinforce a bit more as it doesn't seem like enough attachment to the vehicle. I'm sure it's fine but better to be safe than (extremely...) sorry.  I drilled and tapped thread into additional M12 holes to each car mount where it attaches to the rotisserie as an extra fail-safe. Without them the side to side movement is just restricted by the allen head pinch bolts, nothing actually goes though the beam. Does now! I still need to adjust the rotisserie to get the car centred in terms of centre of gravity. If it's too high or too low relative to the rotational centre line of the car, it will be like a turtle and roll onto its back or as it currently sits, I dont think I'd be able to rotate it as it sits as it needs to lift the whole car up as it rotates. Ain't happening... I'm going to be nervous as hell the first time I go to spin it on its side...
    • Oh yes done this when the window started flopping around.  Turns out the guides that run along the rail chanel had crumbed way. Took off the door card and pulled out the window mech, then the window, which you have to pull out through the top. As said unbolt the guide rail and don't spend 30 minutes getting frustrated trying to find a way to slide it out upwards cause that don't frigging work. Drop it down and out through the door hole. All I did to repair it was slice some 10mm clear plastic tube, vertically, then screw it to the guide rail both sides. This tubing rolls inward on both sides and leaves a gap wide enough to hold the window. To finish all I did was lube the plastic tube with olive oil and Bob's your uncle . . . well if he has the operation he can be your Aunt ! !  10 bucks in plastic tube and another 5 minute job done again . . . . YEH BULLSH#T ! My love for Skylines knows no bounds !
    • So was there a solution to this problem? I’m having this issue now.
    • not expensive, just irreplaceable if you don't go sub 60 at wakie in that thing people will start talking
    • I haven't replaced that, but I have had the doors apart on the r32 a couple of times The door skin will be held on by a combination of clips and bolts, just take it slowly and make sure all the sneaky hidden bolts are out Once the skin is off you should be able to pop that piece off pretty easily, looks like there are only 2 bolts holding it on
