Gtr Exhaust Upgrade
s15guy
 Share
Picking up my new white 2010 GTR on Monday (very excited)
Tested their silver one a week ago (huge grin factor). Very subdued on the sound department.
First thing on my agenda a top quality exhaust upgrade (power, sound, lighter)
With so many out there HKS, AMUSE e.t.c is there a top 3 in peoples minds?
What consideration do I need to give? e.g. Y pipe, straight pipe e.t.c
Are there GTR 35 owners here who have upgraded a full dual exhaust system and which and why did you choose the one you have?
Cheers
I am also looking to change the exhaust. Does anyone know anything about the Stillen cat back system. A bloke from Tassie I met said he put one on his R35 and he reckons it sounds awesome. Does anyone know if Nissan voids the new car warranty if you mod the exhaust (cat back only).
your whole car warranty cannot be voided by a single mod. advice on the forums and internet is not worth much in a dealership or in the law courts but in general if the non-genuine part can be identified as the cause for the problem under warranty claim (eg: turbocharger problem or something even slightly related to the exhaust) then nissan may not honour your warranty, even if it is BS.
if your aircon stops working or a suspension component fails of course nissan would find it hard to refuse warranty for the sake of a midpipe.
I would say you would be very unlucky to have a midpipe or catback cause a problem that will void a warranty claim but it is conceivable so do so at your own risk.
I might add though that you would be hard pressed to find an R35 on this forum without at least a midpipe these days!
Do you need to do a retune if you do a midpipe. I was led to believe that no retune is required if you only change the catback system.
you dont need to do a retune, but a COBB stage 2 or Mail order tune form Willall or similar will maximise the benefits. Once you reflash the ECU however nissan will start flapping their arms more than with just the midpipe/catback.
For those that live in SE Qld the Mercury guys have the COBB tuning software to provide custom tunes. otherwise people have had good success with Martins Willall mailorder tune. A custom tune will give you just that little bit extra in most cases from what
I have been told.
 Share
    • Much less twat-tastic. CF wheels are too garish for civilised use.
    • From there, as the manual says....assembly is the reverse of disassembly, no tricks worth mentioning Much better (for me)
    • In my case, the standard wheel I had was in good condition but the buttons had more wear, so I swapped them across from the original wheel from the car. The plastic rear cover is held on by 4 tabs, and once the wiring is removed you can get access to 2 screws on each side the hold the buttons in From there I just swapped the wiring over. What was interesting is the standard style wheel is 2.0kg but the carbon fibre one is 50% heavier at 2.9kg. It even has a weight inside the wheel at the top to make up for some sort of imbalance in the design. weird
    • Once the airbag is off, to remove the steering wheel.... Undo the 2 plugs into the clock spring, and the horn connector from it's clip. Hit the 19mm nut with a rattle gun (preferably) or if you don't' have one, you probably want an assistant to hold the wheel in place while you use a breaker bar to undo the nut Then, screw the nut back on 3 turns, and pull the wheel sharply towards you. If that doesn't work hit it medium force with a rubber mallet on either side, or possible behind if you can get there. If that all fails (it shouldn't!) you might need a steering wheel puller
    • So, to next task....the carbon fibre steering wheel was either an expensive factory option or a chinesium special. Either way, I don't like either the flat bottom or thick ring style, so it had to go So...to remove the steering wheel.... First, disconnect battery negative and stomp on the brake pedal for a few seconds. Then, remove the small circular covers on each side of the wheel's rear surround to uncover the airbag clips. You need to push something like a flat bladed screw driver through, to push the steel clip inwards and pull the side of the airbag forward. Once you've done the easy side, same on the centre console side. You can see the tab you are shooting for circled in red Then, disconnect the horn spade connector and for the yellow airbag plug you need to get something small under the black locking tab to pop it out, then the connector releases......airbag is off
