hey all,
my v36 sedan is currently at the compliance workshop so it won't be long now - yay!
in the mean time, i am trying to organise some new rims. it's a my2007 type sp so the stock rims are 18x7.5 (FR) and 18x8.5 (RR). my questions are:
- any ideas what i could go comfortably up to?
- will 20s be too large? are tyres easility available?
- how wide can i go?
- will i need different widths to match? eg 8.5 fronts and 9.5 rears
any help would be appreciated. actual experience would be even better.
thanks for reading.
...sykryd
https://www.sau.com.au/forums/topic/326927-wheels-for-v36-sedan/
20's are fine. Yes they are easily available.
i went for a 20X9.5 +15 front 20X10.5 +18 rear on my coupe, which is *very* aggressive offset.
widths, sizing, and offset is all dependant on how you want the car to sit.
IMO the "stance" (offset & widths) is just as important as actual wheel design choice.
check out http://www.rimtuck.com and searching for a infiniti g37 sedan for some sizing / pics.
Edited by loz-tuned
thanks for the link. thats a great looking website. i couldn't find anything under g37 sedan, but i did find a couple of 19s under g35 sedan.
your set up must look awesome. i can't believe how wide you've gone - 2inches over (my) stock!! i'd love to see some pics if you have them. also, do you have a (4 door) sedan or the coupe?
  • 1 month later...
hey all,
thanks for reading.
...sykryd
Sorry bit of topic dont the 2007 SP models come with 19 standard? mine did but its now causing me problems now with complaince, for some reason they were complanced with 18s.
sedan or coupe? coupes come in stock 19s, sedans come in stock 18s. mine is a sedan.
who is doing your compliance? if they are stock rims, i don't see how it would have any compliance issues. might be harder to get the right tyre placard.
got pics of your rims/car?
Hi all I have 22s on mine 2008 v36 SP. I am looking for anyone who has the Stock 19s as I sold mine to the shop when I got the 22s. I am interested in a swap for the 22s aswell, Just really want to 19s back.
If anyone is interested pls PM me and we can come to some sort of deal
Cheers
    • @joshuaho96 Hmm considering the drama you've seen/experienced, have you looked into getting a built complete long motor shipped from Australia?  Considering the AUD is basically monopoly money when compared to the USD, at a glance this seems like a good option?
    • Bloody Skylines, they put you through the bloody wringer! Stick at it! Stunning drag strip BTW! Where is it? Can see part of the name on the slip and probably should just Google it!
    • I mean the other day I had to walk someone through diagnosing why their timing belt was walking off the cam gears. At least one of the issues was a bent tensioner stud. Local mechanics have found runout on the CAS mechanism causing weird failures. I'm also no saint here I've documented some of the things I've had to learn the hard way. Something I discovered recently is that my CA emissions catalytic converters weren't even welded correctly to align the downpipe to the main cat and they tossed the support bracket that goes from the transfer case to the downpipe to support everything there. I spend a lot of time chasing down these decidedly unsexy problems and the net effect is it feels like I never actually get to the original objective (flex fuel, VCAM, oil control, cooling, etc).
    • At times with how you make everything sound, all I imagine Americans doing when they see a gtr is standing there looking at it and bashing it with a gun like how a caveman would with a club and hoping it fixes itself
    • I think this is just a product of how the US market works for this stuff. Shops are expensive and there's no real way of knowing what kind of results you're going to get, people don't really have the institutional knowledge. I have heard too much at this point to really put faith in anybody "full service" except maybe DSport and they aren't really a full service kind of shop. If you go to the right place I have no doubt they'll get it right for you. Some locals have set it up right but the cost really is nuts and even now they're still fighting issues. And you know I'm a crazy person who thinks things like twin scroll, relatively short low-mount cast headers, PCV recirc to intake, recirculating BOV, right-sized for ~400 whp, MAF load, validating all of that to a standard comparable to OEM test programs, etc are relevant. For what it's worth, multiple local owners at this point have been stuck in a perpetual cycle of blowing a motor -> getting someone to rebuild it -> some missed detail causes the bearings to wipe and spin just outside of break-in mileage or drop valves or some other catastrophe -> cycle repeats. I usually only find out about this because I'm perpetually helping random friends with diagnosing car troubles, Skyline or otherwise. The single turbo stuff if I'm honest is mostly secondary, it just doesn't seem to achieve the numbers in the ~2000-3000 rpm region that I would expect given the results I've seen here or in Motive's videos. I don't really know what we're missing here in the US to be causing this. Lots of people like to emphasize the necessity of finishing the project first and foremost, but I'm not made of money and I can't afford to be trashing a 15k+ USD engine build with any regularity. Or spending my relatively limited garage time these days unable to triangulate problems because too much was changed all at once. Also, even if it isn't a catastrophic failure I would consider spending the cost of single turbo conversion with nothing to show for it to be pretty bad.
