BMW rims are 5x120 PCD so nope.
These are some similar rims though which are 5x114.3
19 x 9.5 BE GTS-AV
http://evojm27.wordpress.com/2012/08/26/speed-style-hector-torres-jrs-06-mazdaspeed-6/
Unfortunately thats illegal. Come in DD, you're from SA - the only state more strict than VIC on mods - you would know that!
120 to 114 would require 4 new holes to be drilled - unless the centre was hidden by a cap it would look like ass. And I dunno if I'd want to be leaning on a wheel with a hub that looked like Swiss cheese :-p
You can wobble bolt/nut 112 to 114 - but if you HAD to go 114 to 120 - I'd only do it with bolt on adapters. Has been done - I have seen an s14 on 7 series rims.
I'm guessing based on your sig you have a spare set of rims, MFC05, and trying to make em fit?
There are plenty of CSL reps in correct patter thon .....
Edited by SMOKEYC34
smokey, didnt know and dont care. i do it happily :)
and no, no extra holes. we get the original holes modded. non reversable.
120 to 114.3 requires just a slight oversize of bolt holes, and an offset sleeve to reduce the stud pcd. not visible at all.
merc 112 to 114.3 requires only reseating the stud taper. no insert. nothing visible at all.
Edited by Deep Dish V35
Smokey no i don't i am just wondering what wheels are on the market that are similar to the CSL type wheels
  • 1 year later...
The US equipped Infintis have some decent looking factory wheels.
For anyone looking for some inspiration here's a link in the g37 forums with some tastefully modded Gs
http://www.myg37.com/forums/g37-sedan/231177-show-off-your-sedans-156.html
Edited by MFC05
  • Like 1
  • 2 years later...
fitment for v36 skyline. stance offset.
Taken from g37 forum
225/45/19x10F +30 with -1.5 camber and 245/40/19x11R +25 with -3.2 camber. I have not done any fender work yet, I plan to pull the rear and roll the front
    • I mean the other day I had to walk someone through diagnosing why their timing belt was walking off the cam gears. At least one of the issues was a bent tensioner stud. Local mechanics have found runout on the CAS mechanism causing weird failures. I'm also no saint here I've documented some of the things I've had to learn the hard way. Something I discovered recently is that my CA emissions catalytic converters weren't even welded correctly to align the downpipe to the main cat and they tossed the support bracket that goes from the transfer case to the downpipe to support everything there. I spend a lot of time chasing down these decidedly unsexy problems and the net effect is it feels like I never actually get to the original objective (flex fuel, VCAM, oil control, cooling, etc).
    • At times with how you make everything sound, all I imagine Americans doing when they see a gtr is standing there looking at it and bashing it with a gun like how a caveman would with a club and hoping it fixes itself
    • I think this is just a product of how the US market works for this stuff. Shops are expensive and there's no real way of knowing what kind of results you're going to get, people don't really have the institutional knowledge. I have heard too much at this point to really put faith in anybody "full service" except maybe DSport and they aren't really a full service kind of shop. If you go to the right place I have no doubt they'll get it right for you. Some locals have set it up right but the cost really is nuts and even now they're still fighting issues. And you know I'm a crazy person who thinks things like twin scroll, relatively short low-mount cast headers, PCV recirc to intake, recirculating BOV, right-sized for ~400 whp, MAF load, validating all of that to a standard comparable to OEM test programs, etc are relevant. For what it's worth, multiple local owners at this point have been stuck in a perpetual cycle of blowing a motor -> getting someone to rebuild it -> some missed detail causes the bearings to wipe and spin just outside of break-in mileage or drop valves or some other catastrophe -> cycle repeats. I usually only find out about this because I'm perpetually helping random friends with diagnosing car troubles, Skyline or otherwise. The single turbo stuff if I'm honest is mostly secondary, it just doesn't seem to achieve the numbers in the ~2000-3000 rpm region that I would expect given the results I've seen here or in Motive's videos. I don't really know what we're missing here in the US to be causing this. Lots of people like to emphasize the necessity of finishing the project first and foremost, but I'm not made of money and I can't afford to be trashing a 15k+ USD engine build with any regularity. Or spending my relatively limited garage time these days unable to triangulate problems because too much was changed all at once. Also, even if it isn't a catastrophic failure I would consider spending the cost of single turbo conversion with nothing to show for it to be pretty bad.
    • The water pump is know to leak as well. So if the coolant is low checking that first as well as hoses.
    • Reading your posts Josh, sometimes I feel like I've gone in a time machine back to the 90's when everyone was doe-eyed and figuring things out for the first time.  I've lost track of how many single turbo GTR's I've seen on track that haven't burnt down lol. Everything has been figured out a long time ago. These things are at the point now where its essentially turn-key to go single turbo.
