Wheels For V36 Sedan
Unfortunately thats illegal. Come in DD, you're from SA - the only state more strict than VIC on mods - you would know that!
120 to 114 would require 4 new holes to be drilled - unless the centre was hidden by a cap it would look like ass. And I dunno if I'd want to be leaning on a wheel with a hub that looked like Swiss cheese :-p
You can wobble bolt/nut 112 to 114 - but if you HAD to go 114 to 120 - I'd only do it with bolt on adapters. Has been done - I have seen an s14 on 7 series rims.
I'm guessing based on your sig you have a spare set of rims, MFC05, and trying to make em fit?
There are plenty of CSL reps in correct patter thon .....
Edited by SMOKEYC34
  • Like 1
smokey, didnt know and dont care. i do it happily :)
and no, no extra holes. we get the original holes modded. non reversable.
120 to 114.3 requires just a slight oversize of bolt holes, and an offset sleeve to reduce the stud pcd. not visible at all.
merc 112 to 114.3 requires only reseating the stud taper. no insert. nothing visible at all.
Edited by Deep Dish V35
Smokey no i don't i am just wondering what wheels are on the market that are similar to the CSL type wheels
i just thought cos you have an e46 in your avatar pic.....there i go making assumption again.....
Enkei EKM3 are pretty close.
http://www.ebay.com/itm/Enkei-18-EKM3-18x7-5-5x114-3-38-Gunmetal-/221146701644?hash=item337d5edf4c&item=221146701644&pt=Motors_Car_Truck_Parts_Accessories&vxp=mtr
  • 1 year later...
  • 2 years later...
fitment for v36 skyline. stance offset.
Taken from g37 forum
225/45/19x10F +30 with -1.5 camber and 245/40/19x11R +25 with -3.2 camber. I have not done any fender work yet, I plan to pull the rear and roll the front
I think standard camber on this one
245/35/20
8.5 +24
285/30/20
10.5 +45
The rear shot is with a 10mm spacer so technically 10.5 +35 offset
  car couldn't clear rear 10.5+34s rear with 285s on an Eibach-like drop and -2.2 camber.
For reference, here are old pics of the 10.5+34 before swapping them out for +45s.
 Share
    • I am impressed with all this level of adjustment. I didn't expect all this possibility
    • Correct.  In the case of the 500kw dyno plot I showed you the car actually runs two boost control solenoids for boost control and a 5psi wastegate spring.  It allows me to control how much boost pressure is applied to both sides of the wastegate valve at any point and fairly accurately control boost target as a result. I've tuned it so that it's able to target anywhere from 5psi to 25psi depending on what's needed.  The target tables I've set up in that car are Gear vs RPM, so every gear has potential for a different boost (and torque) curve.   First and second gear have quite low boost targets, third gear actually has different target boost all the way through the rpm range as it's a stock RB25 gearbox - the boost targets have been chosen to maintain a peak of 600nm (what the owner has set as the maximum torque he's happy with putting through the stock 3rd gear) but it carries that to the rev limiter.   The boost curve to achieve that is something of a ramp up, then hold, then ramp up again and the power curve looks more like a flat line haha.
    • so you can decrease or increase the boost depending on the diet as you wish?     by acting on the wastegate?
    • That's torque and power, it's all from a single run.  The boost curve is "held back" from it's peak target in the 3500rpm to 5000rpm range from memory, so it ramps hard to something like 18psi then climbs more progressively to 23psi nearer 5000rpm.   It makes the torque (and power) ramp more "natural" and less hard on parts and traction, it doesn't feel artificially held back.
    • Here's the torque curves from the car I ramped boost up later in the rpm to allow a slightly wider useful power curve - the power curve is a bit weird shaped also thanks to the TVIS (or whatever they call it with the 4EFTE in this Starlet) which changes the volume of the intake manifold throughout the rpm range, but you can see that the green power curve actually holds later on with the extra boost... but looks almost more like the kind of thing you'd expect from a cam or exhaust change
