The 255/40 and 285/35 are within a .5" difference which should be fine for the AWD.
I'm not AWD but i am running those same tire specs on my car. Wheels are 19x10.5 +43 all around with a 5mm spacer up front to clear the arms.
  • Like 1
After adding a 5mm spacer: 245/40-19x9.5 +35
So what have I learned.... I think the following is a perfect set-up for the V36 skyline rwd sedan;
Front: 245 or 255/40-19x9.5 +35 (possibly a 245/40-19x9.0 +35)
Rear: 285/35-19x10.5 +45
Edited by R377
Here is a sedan w/370 z wheels. Specs on the 370z wheels are:
front - 19x9, +47 offset
rear - 19x10, +30 offset
He is running a 20mm spacer on the front so the offset is essentially a 27mm.
The rear tires stick out because they have 295/40 tires. 275/35 would be perfect.
370z wheels are made by Rays and are 6-7lbs lighter than coupe wheels made by Enkei
Front:
Wheels: 19"x8.5". Cast aluminum. Made for Nissan/Infiniti by Enkei. Weight: 26.5 lbs. Bolt pattern 114.3 x 5 Offset +43
Rear:
Wheels: 19"x9". Cast aluminum. Made for Nissan/Infiniti byEnkei. Weight: 27.5 lbs. Bolt pattern 114.3 x 5. Offset +45
Girls can roll too.  Natalie was previously rolling on Vossen VVS-CV7s in Matte Graphite Machined in 20x9 20x10.5 +32/45 on 255/35/20 285/30/20. g37 sedan Vossen v36 skyline sedan
Natalie changed her setup to 20x10.5 +45 all around with Vossen VVS-CV7s in Silver Polished wrapped in 255/30/20 Nitto tires. I have a 5mm Akata Spacer front and back to prevent rubbing against the control arm in the front while giving some poke to the back
    • Interesting, I haven't read about the issue with oil getting into the speedo in the cluster before. I'll have to take more notice with mine. The speedo on my R32's when I've run factory diff and tyre size have never been accurate as far as I can remember. The non Type-M GTS-t did come with 15" 5 stud wheels and smaller brakes, but that's less than 5% of them.
    • Good to hear the condenser you picked up off my brother worked all good. Do you think there could be an issue with your AC compressor itself or the clutch on it then? I don't know a lot about them so I can't really help but keen to hear what it ends up being. Keep the build thread going man, it's nice to look back on over time.
    • This is a story of my life things, I learned eventually (thanks to someone calling me out) that my enthusiasm for discussing and sharing ideas that it came across as arrogance and I'm like... WTF?!    One thing I'm pretty sure I justifiably pride myself on is knowing that everyone will have things they can teach you, and you're always going to find out that something you think you know turns out wrong - you just don't know what it is until you get there.   Just the bursting enthusiasm that comes with ADHD when you hit something that gives you dopamine dumps can come across like you think everyone else is wrong or don't matter. But yeah, I'm a software engineer by trade and also do tuning in weekends and 100% have long had a reputation for  quickly making connections when resolving problems or forming solutions that I've sometimes had to take people form a long walk from start to end to explain how I ended up where I did when it's seemed "too simple" when I've stated my initial case, and had the "WTF" type reaction when they've realised how much was actually considered haha.   My reward is that I get all the curly problems thrown at me.
    • Wives never seem to find things funny. Especially when they're trying to sleep, and you've found the new funniest thing ever. I've never seen someone be able to get try and be cranky with me, while they're holding back fits of laughter... 😛   Also, I tell mine it's payback anyway. She has BiPolar. So the household can get quite emotionally wild at times 😛
    • I'm not up to date on the latest, but for basic modifications like pod filter, lower springs etc you can get a modification permit at the time of inspection.  For more serious modifications you will need engineering.  Intercoolers used to fall into the mod permit rule but its been a long while since i looked it up.   Either way you will be able to get it registered, just a case of $300 vs $3k .
