hey all i have some r32 gtr parts for sale car had 120 000kms
Rb26 block suit rebore (stock bore at the moment) $650
rb26 short nose crank suit polish or machine $300
rb26 stock rods good upgrade for rb25 $250
or $1000 complete bottom end
rb26 head complete (cams valves springs ) good condition just needs a clean maby a machine and valve stem seals was working well no problems $1250
more parts to come (-7 turbos a bunch of aftermarket cams stock recalibrated afms cleaned injectors ect)
located in brisbane will post if needed
sms me on 0402774241 or pm me will do better price for bulk buy
ooo got poncams?
im still measuring them there all ground from nissan blanks but i think they all have a smaller base cyrcle ill let u know ( but no pons)
what sort of weight is a 26 crank? (i'm in canberra) do you know if it'll fit in a 20? i am unsure of what "short nose" means,
thank you
sorry it's the part that drives the oil pump it's not the long drive it's the short I think it will fit the 20 I think that's how they make a rb24 and weight I'm nt sure farly heavy but should be able to post it
I posted a crank through aussie post, it's about 21 kgs when wrapped- the very nice guy at the post office made an exception for me, don't see why it shouldn't be the same for anyone else.
Yer very tru thanks mate for the info
I am willing to let the whole lot go for 1600 head and all just no covers or sump or manafolds need it all gone asap guys or will swap foe a rb25 power cc and z32 Afm and a little cash so throw up some swap offers Of u want it and don't have cash
sent you a text about afms but got no reply.. what are you asking for a pair of afms suit rb26?
Hey mate sorry I didn't get a SMS at all afm's I recently spent a fortune geting my afm's and everything re calabrated to perfection it was about 400 for the afm's make me a offer send me a pm or SMS on 0402774241
  • 1 month later...
Rb26 block suit rebore (stock bore at the moment) $400 price drop
rb26 short nose crank suit polish or machine sold
rb26 head complete (cams valves springs ) good condition just needs a clean maby a machine and valve stem seals was working well no problems $1000 Price drop
all needs to go soon can email me on [email protected]
Just wondering if you still have the RB26 head for sale? If so, what condition is it in, and does it come with the inlet manifold/throttle bodies etc?
i still have the head for sale it is in great condition just requires the usual clean up it came of a perfectly good running engine
it dosnt come with the intake ore exhaust manafold if u are interested throw me a offer thanks for your interest
    • Wow that's a steal, you've done well there.
    • Exterior LEDs R34 2Dr R34 4Dr Position Lamp T10 T10 Winker front T20S T20S side T10 T10 rear T20S S25S150 Anti-hyfla relay TYPE3 TYPE3 tail T10 T20W Stop Lamps T20W T20W High Mount T16 T16 back T16 T20S number T10 T10 trunk T10 T10 Interior LED Item No.     Map Lamp BA9S single-sided     Room Lamps T10×31     Trunk Lamp T10     meter Early T6.5 pedestal     final T6.5 pedestal     NISMO T6.5 pedestal     Liquid crystal section T6.5 pedestal     Winker T6.5 pedestal     High Beam T6.5 pedestal     3 SERIES METER Early T6.5 pedestal     final T6.5 pedestal     NISMO T6.5 pedestal     air conditioner Early Liquid Crystal T3     Late LCD T4.2 Short     button T4.2 Middle     Hazard SW T3 Pedestal Short     Keyring T5     Cigar Socket T5
    • Howdy all,   I had my rb25det S2 rebuilt and finally started it today but have run into a few issues  Engine sounds like a a diesel easiest way to summarise like small ticking, gets louder when revs are slightly adjusted  The engine builder repainted the engine cover leaving no where for me to go off with lining up the CAS so have it as central as possible so not sure it that could be affecting it?, changed the gearbox fluid too but won’t seem to go into gear when running, and only 1 to 4 when off having a hard time finding 5th and reverse anyone got any ideas or a base for me to start off? much appreciated
    • Well, no. It's an 023, which is pretty similar to an 040. Although it is hard to tell from the specs, as given.
    • Hmm. Maybe the (other thing I forgot about!) Haltech removes at least some, if not all, of the problem I described. I guess there is still the possibility of getting it wrong if the AC is set up/wired up for the Haltech as if it was in an R34 (simply because it's on a Neo), and that's playing foul with the R32 AC computer.
