Right so I have picked up a set of Volks for my R32 GTST, 17 X 8 up the front and 17 X 9 on the rear, both @ +45 offset.
I have dummy fitted the fronts and they JUST sit within the guards...quite nicely I might add, and all signs point the the rears sitting inside too. Problem is they currently dont have rubber so I couldnt really tell.
This isnt my problem though, Im searching for some rubber for the rears and have come across some mixed answers from tyre shops, some will fit the rubber (245 I think) and have no problem at all fitting and adjusting everything, while other places wont due to the size and offset of the rims being illegal aparently.
So I though I would come to some experts and get some more info on the matter.
Also these arnt just small shops with different views on the matter, they are well known. Bob Jane, Tyre Power...etc
Edited by Lucy The Skyline
you might want to start here:
http://www.rta.nsw.gov.au/registration/dow.../vsi09_rev4.pdf
they could be hesitant about the increase in width or the offset. and you have to make sure you overall rolling diameter is close or your speedo will be out.
Going from 16's to 17's shouldnt make a huge difference, and my speedo is enthusistatic anyway so getting used to the new reading wont be hard. I will find the max numbers on the plate in the morning.
And joey I agree more than you could believe...
On the Vicroads website (probably the same in other states):
http://www.vicroads.vic.gov.au/NR/rdonlyre...8340/0/VSI8.pdf
- Replacement wheels cannot be more than 25mm (1") wider than the widest wheels specified by the manufacturer for that vehicle series
- Wheel / tyre combo not more than 15mm larger diameter than the largest tyre specified by the manufacturer for that vehicle series
So depending on the standard rim for a GT-R, which I think is only 7", 9" is outside the Vicroads guidelines for replacement wheels.
standard rim for r32 gtr is 8" wide, so 9" would be legal.. just. but then the gtr has wider guards so its debate-able whether the gts-t would be judged based on gtr standards.
use this tool to work out your correct tyre sizes. the industry standard generally aims to keep the rolling diameter of the tyre within 2.5% (but the closer the better) of the oem tyre so as not to disrupt the speedo reading to far, however this is only relevant for the drive wheels. r32 gts-t oem tyre is 205/55/16 so in your case 245/40/17 is the best fit. as for the fronts, probably 225s or 235s would be good
    • Just one more post to show the final result and the original "janky" solution for a laugh. Everything feels really tight and no wobbling at all, very pleased 🙂
    • After drying a few days, time to put her back together
    • The hot exhaust light will come on not from just the cat being blocked, but it's just a temp sensor, and it's designed to warn you to not do things like park in long grass.   If you've been pushing the motor a bit, it can cause the light to come on.   Second if the cat is rattling, I'd suspect it's not blocked, but instead falling apart inside.   The easiest "fix" until you can get a cat put back in, is to unbolt your one, bash the rest of the insides out, and then bolt it back in.   For a daily driver/street car, I am in agreeance of put a cat in the car. If it were race car I wouldn't care if it were removed.
    • No worries at all 🫡 I think the most satisfying things to make are the little bits that are just impossible to find or they're no longer manufactured. Generally I always try to replace parts with OEM wherever possible. This little project is also great because it'll never see the light of day, but strengthen these brackets so it's not just relying on the little standard screws in the headlight plastic. As soon as I saw the standard brackets and screws I thought, "well I'm not going to install with just the screws, the plastic tabs will just snap off". It's crazy how expensive everything has become yeah. But I suppose that's supply and demand; granted it's a lot easier to get brand new genuine parts these days which is fantastic 😊, I don't have to get totally reamed at the local Nissan dealer ha ha We sure are lucky we have all these manufacturers making parts these days, a few really great Australian companies too like Platinum Racing Products and Fit Mint Automotive, what a time to be alive ❤️ . I've got my eye on the RB26 head by PRP as mine has a very fine hairline crack, so that'll need to be addressed some time in the future. If you have any requests or odd things to make feel free to let me know and I can have a crack at making replacement parts ✌️
