hi fellas, got an apexi power fc D-Jetro, map sensors and loom,splitfire coil packs series 1, full wiring loom and ignitor up for grabs. i paid shitloads for these goodies about a month ago so get a bargain. there just like new and still got receipts from when i bought them off nengun. havent been in the car for a month. ive got them running in the car so you no there working, if you would like to have a look or inquire ring chris on 0416552977. i wont remove from vehicle till payments received. im asking $2000 for the lot. i dont really want to seperate. reason for selling is im getting a wolfv500 so i can run more than one map on the track. thanks
hi fellas, got an apexi power fc D-Jetro, map sensors and loom,splitfire coil packs series 1, full wiring loom and ignitor up for grabs. i paid shitloads for these goodies about a month ago so get a bargain. there just like new and still got receipts from when i bought them off nengun. havent been in the car for a month. ive got them running in the car so you no there working, if you would like to have a look or inquire ring chris on 0416552977. i wont remove from vehicle till payments received. im asking $1900 for the lot. i dont really want to seperate. reason for selling is im getting a wolfv500 so i can run more than one map on the track. thanks
Willing to trade anything for just the power fc it will go on a 33gtr ?????? Don't need the coils already have them
hey buddy, im willing to seperate the power fc once my auction is over on ebay. if no one bids on it ill seperate all items. thanks
hi mate, ill want round $1450 for the d-jetro. thats with hand controller and map sensors and map sensor loom. only in car for a month. i cant really afford to do any trades ive got another computer i got to pay for. thanks
    • I have a VALCON if anyone wants it, I have no idea why you'd want to have VVT specifically broken out of the ECU as opposed to running it off the FCON/whatever standalone you have.
    • Hi Yes we're a bit optimistic we might get something out of sealing up the two pipes of the external wastegate and reactivating the stock one. I believe the orginal stock wastegate was tack welded shut. It doesn't budge and visually looks closed and sealed. The car has noticeably more lag so it could be at least part of the problem, maybe all. It's definately one of the key changes made since last tune. And it's one that's more difficult to fully understand and measure, not like for instance timing or cylinder compression.  Thanks for that feedback, we'll let you know how this progresses. Fingers crossed.   Regards Rob
    • Transplanting the vvt from a 25neo into an rb26?
    • Well, I was going to say, "Is the wastegate set up so that it is not leaking?" That's actually a different thing to what you're asking about. In theory, if you have allowed the two halves of the manifold to commmunicate (more than the stock manifold does - which is at least a little bit) then the negative effect should be apparent in delayed spool, not in outrigth power. OK, maybe just maybe, a badly set up twin scroll wastegate "crosstalk" might kill the top end, although it's hard to see how. What is happening with the original wastegate in the turbo? is it sealed off properly. If it's left flapping in the breeze, it will f**k everything up. If it is still there, and can be returned to service, I'd be capping off the external (presuming the two halves can and will be isolated from each other after doing so) and have a go with just the stock wastegate. I have an internal wastegate in my highflowed rear housing. The bigger opening and flapper should be fine to >250 rwkW. So there's not exactly a pressing reason to have the external. Done right, an external will give better results. Done wrong, it might just be possible to have worse results. Report back!
