Gav's car with similar spec to yours pumped out around 560 at the very least. Then he added e85 conversion.. so a theoretical guess would be around the 600+ mark.
I think you should get a 14mm rail conversion and some 14mm injectors for less price than the hks ones, plus you can then go e85 later for that extra ~10% in power increase just from a retune.. Cheapest investment/performance ratio for sure..
I am not looking to smashing numbers with this engine.
I want it to last for 5-6 years, without having to worry about it.
500 -525 at the wheels will be more than enough.
Plus I bought Gav's old injectors hahhaha
hasn't he done some really hard km's on his motor since it was built, 3+ years ago? If its tuned well, surely it'd last if the engine is built properly.
E85 should increase torque over the entire range, sounds fun indeed for track.
May as well go hard and enjoy it haha
Edited by s2d4
I'm also in the middle of doing a 2.8L also although I used Pauter rods same as Gav and my crank came from the UK.
So who are you using for your engine builder and machinist?
R
Ant at X-Speed is building the motor.
Machinist is via LF, Ant's recommendation
Who's LF?
Ants going to build it, that will deff be a machine. With Ant doing it must around 30K+ easy.
Hope to see more pics. Are you doing any modifications to the STD gearbox, brakes, clutch etc?
What compression are you going for?
Turbo configuration? Have you decided on a cam duration and lift yet?
R
Hey Mike,
Yes the 2.8L bug finally got you too. Good choice in acquiring the HKS Step 2 kit, combined with -5s should make for some real fun!
Hmm... E85? I wonder what Racepace can do with E85 tune in my car.... Instant 105 increase in power across the whole rev range with proper tune and same hardware, sound too good to be true.... need to do more research.
Cheers
Matt
Who's LF?
R
Probably LF Performance.
No matter who builds the engine it's going to cost and Ant is the man in Perth when it comes to these engines. Do it once and do it properly!!
Rob have you still not built your thing yet?? I remember talking to you back in 2007 and though you were pretty close then.
He is using -5's.
Hey John,
Few things in between have got in the way of my build. Also My car is getting a bare metal respray as well, so its taken a while to get all the rubbers together etc etc etc
Even getting R34 GTR dump pipes have proven to be near on impossible. So at the moment trying to coordinate rebuild on motor and shell respray.
Anyways I will subscribe to this build to see how it progress's.
Rob
He is using -5's.
Pity you weren't paying attention to the for sales forum a few weeks back, I had a spare set.
Hey John,
Rob
  • 3 weeks later...
    • Got you mate. Check your email!
    • I see you've never had to push start your own car... You could save some weight right now...
    • Sounds good.  I don't 100% understand what your getting at here. When you say, "I keep seeing YouTube videos where people have new paint and primer land on the old clearcoat that isn't even dulled down" do you mean this - there is a panel with factory paint, without any prep work, they paint the entire panel with primer, then colour then clear?  If that's what you mean, sure it will "stick" for a year, 2 years, maybe 3 years? Who knows. But at some stage it will flake off and when it does it's going to come off in huge chunks and look horrific.  Of course read your technical data sheet for your paint, but generally speaking, you can apply primer to a scuffed/prepped clear coat. Generally speaking, I wouldn't do this. I would scuff/prep the clear and then lay colour then clear. Adding the primer to these steps just adds cost and time. It will stick to the clear coat provided it has been appropriately scuffed/prepped first.  When you say, "but the new paint is landing on the old clearcoat" I am imagining someone not masking up the car and just letting overspray go wherever it wants. Surely this isn't what you mean?  So I'll assume the following scenario - there is a small scratch. The person manages to somehow fill the scratch and now has a perfectly flat surface. They then spray colour and clear over this small masked off section of the car. Is this what you mean? If this is the case, yes the new paint will eventually flake off in X number of years time.  The easy solution is to scuff/prep all of the paint that hasn't been masked off in the repair area then lay the paint.  So you want to prep the surface, lay primer, then lay filler, then lay primer, then colour, then clear?  Life seems so much simpler if you prep, fill, primer, colour then clear.  There are very few reasons to go to bare metal. Chasing rust is a good example of why you'd go to bare metal.  A simple dent, there is no way in hell I'm going to bare metal for that repair. I've got enough on my plate without creating extra work for myself lol.
    • Hi, Got the membership renewal email but haven't acted yet.  I need to change my address first. So if somebody can email me so I can change it that would be good.
