I have found a way around the injector / afm maxing out problem so its time for a turbo upgrade.
The Budget: $3000 + fitting bits and pieces ( I will fit myself )
[i:7acb06bd56][u:7acb06bd56]The options so far:[/u:7acb06bd56][/i:7acb06bd56]
HKS GT2835 - 52Trim with .68 a/r (400hp)
What else do you guys reccomed, I need to know th eentire cost so don't tell me X turbo for $2700 only to discover it is external gated.
This is a serious enquiry and will happen later this year.
https://www.sau.com.au/forums/topic/327-time-for-turbo-upgrade/
cam I would hiflow your vg30 turbo and put an external gate on it. you can get a 60-1 front wheel and a bigger exhaust wheel and it will rock the external gate will give you more control and you wont need a custom manifold.
or go td0 6 20 g they are a great combo but a biggish vg 30 is really good if you want more power just go a t4 with a roller bearing center.
cheers
meggala
the 2835's are laggy.
  • 3 weeks later...
Yes it is possible, there are many ways to do itb ut if you are going to the expense of a turbo and ex/gate then you probably have the money for a new manifold ($1000) unless of course you pick one up super cheap.
JMS did this on theier Onevia and simply had a block welded onto the flange on the stock manifold with the wastegate coming up off this and the turbo bolted on.
Cam
    • I have to put something here in order to post the photos. From what I could gather there's more enthusiasm for modified cars now than there has been for years. There were probably more younger people there than older (me included lol) which was a good sign.  It did seem like the record least amount of representation of the 90's era hero cars on display though. Like maybe one or two examples of S-chassis Nissans, and maybe 3 or 4 R-chassis. By comparison there were a lot of Civics from that era but in all there were about 10 - 12 EG/EK Civic Type R.  Euro exotics are always there in large numbers, led by Liberty Walk...... say what you will about kids using markers to scribble on a Ferrari F40, it did seem like a stunt to infuriate Ferrari enthusiasts, or Ferrari itself. I wonder if there's something more to it. Either way LBWK have done some heinous things to a Lamborghini Miura this time. They should stop now.
    • Engines and drivelines are not war stoppers for me mate, busted arse bodies and un-obtainium parts and panels are though Both cheap Brumbies I looked at had trashed tubs and a fair bit of rust
    • Stock O2 sensors are narrowband. They're useless once you're away from stoich. IE, useless for what you're trying to do. 10:1 will read the same as 14:1 from the stock O2 sensors. That is, they'll read rich. The same level of rich.
    • I agree once misfires happen it's basically worthless, but the hope is you can see what's happening in the run up to that.
    • You should totally get a Brumby, and then come pick up the Subaru Liberty GTB I have here. EJ25 Turbo, 6 speed manual from the sti (just no dccd), and the good rear diff. Drop all that into a Brumby and go have fun!
