Nightcrawler has suggested we do a private drag day, i.e. hire the AIR track. John (Munro) has given us the basic details, $3500 all up to hire the track including track preparation, timing equipment, officials, fire/ambo etc.
So, to start the ball rolling, who's keen to give it a go. We'll need a decent # of cars to keep the costs down, how many we can get, or have, in total I don't know?
We'll invite the LS1 guys, WRX, & a few others... To make sure we get a good turnout & a fun day.
I know there's a lot of info we still need to find out (dates, times, numbers, costs & so on..) but a show of hands is a start @ least!
One small point to remember! - As there is currently no street meets @ AIR (until @ least December!) the only other way to get a crack @ a genuine timeslip, is interstate! Well, AFAIK?
Bug's has offered to cook some scones & make tea for anyone @ whatever event we decide to have, jolly good show I say, mighty sporting of you ol' chap! :shake: :D:
1. - whatsisname wave.gif I'm in!
2. - NitRaTe
3. - Drift Spec
4. - RevsPerMin
5. - Clint32 - maybe
6. - Munro
7. - Bugalugs
8. - MattR
9. - Nightcrawler
10. - Sil8ty
11. - (_W.4.S.P._)
https://www.sau.com.au/forums/topic/3270-track-day-hire-air-for-a-drag-day/
I think you guys will get a shock when you find out how much quicker your cars are when you can actually get traction.It's great
taking off sideways with smoke beltching from the tyres but you wait till you check out the push in the back you'll get from hooking
up on a prepared track! Sure - you can hire the track out for $80 for the day(only one car on the track at a time) but no lights,no ambo, no insurance,no fire crew, dusty track(& I mean dusty!),no timing equipment = no value for me.I'd rather thrash in the hills where the road is not covered in gravel,dust,&crap.
If you want to have fun doing burnouts, fanging round the bowl, &
see what time your car can actually do down the Quarter Mile then a properly organised Track day will be very productive.
Numbers will not be a problem 'cause if we are short I know lots of comp cars that will come out. The only hitch with this is once all
the comp guys hear about it we will have too many cars and it wont be 'our' day.It costs $50 to race at a street drags(when there is one!) and you have to line up for ages.The whole point of this idea is that for a little more $ we can have a 'private' test & tune day where we set the agenda,do our own thing, & practice how to Drag Race without the pressure of thousands of people looking on.We can even have a burnout comp???
If it does'nt pan out it does'nt matter - but it would be fun would'nt it?
In the meantime - what about an Arvo Cruise in the hills?
GTRing, my favourite pastime.
:burnout:
I think the main diff between the $800 job and $3500 one to me is that with the latter we can walk away with printouts that tells our reaction time, sixty foot time, elapse time and mph/kmh.
It will be good to have prove on paper that our cars can do the times rather than just estimating that it can do so and so.
Ivan.
I'd be up for a few laps/drags. Any idea of dates? if we can make it later in the year (late spring?) we'd probably have more luck with weather, and get more people to come along.:burnout:
Just a quick note: this wouldn't effect the skyline guys, but I doubt some of the LS1 guys will be in for drags or laps. I've been informed that cars still under manufacturer warranty risk losing the warranty on their car if it raced in any way.
Bit of a bugger for peeps with new cars. I think JAFFA is giving the drag opportunity a miss for this reason. ;)
I reckon the day cruise through the victor hills would be a rocker :mad:
Still... a track day would be damn cool! :D
GFXman
    • Can you log IAT? Whilst WTA coolers have their place, doing any sort of sustained run is not one of them There are fixes that slow down the heat soak, like ice boxes, which don't last that long, and interchillers, which are fairly expensive, up grades to the WTA cooling radiator, which may require a bigger pump, and upgrades to the reservoir size,  and upgrades to the cooling fans, but, it all still heat soaks, and takes ages to come down in hot weather  For a turbo, that isn't locked into WTA like my PD blower is, can you not possibly swap to a nice air to air intercooler????, it would be better for sustained runs then, and have alot less things that could go wrong in my opinion
    • So, the other thing I've sorted is a baseline dyno run up at Unigroup's new location. The auto trans was a little unco-operative by both shifting down when the throttle was floored on the dyno (so Mark had to ramp it up more slowly than in a manual) and also by shifting up at 6,000 even in sports mode instead of the indicated redline of 7,000 Still, on a hot day it made 240rwkw at 16psi which seems about right for 300kw (400hp) through an auto at the wheels.  The shape of the curve is not quite right because it was not full throttle to about 4,500 to stop it kicking down, but until I can get a tune on the auto trans control this was the best we could do.....full boost will be well below 5,000 once that is sorted, I'll get some data logs when I can to confirm For comparison, the R32 made 255 at 12psi (at 4,500) on the same dyno with tune, n1 turbos, cam gears, big exhaust but otherwise all standard so the v37 is likely a little better out of the box. One thing that is very clear is that the standard water to air intercoolers are not up to sustained use at full throttle in warm ambient temps. After about 5 runs (so only a few minutes full throttle), it was pulling boost and timing and dropping 10-15% power. Unfortunately I didn't get that printout and the Unigroup guys are away at the moment, will try and get hold of it on their return. So, looks like a healthy engine to start modifying and the only real area of concern is the w2a heat exchangers which the aftermarket has plenty of solutions for
    • I maintain it actually looked really nice in person. So much so that I thought "No, this is illegal" but there it was, clear as day. I think we can easily call the wing and wheels/height to be transformative. Not saying it's better than the GR Whatever, or the 86, or the WRX STI or anything of that sort (the internet says it all bolts up so you can buy best of all worlds?) but it's still at least a thing and not nearly AS bad as people say.
    • That's less offensive than the previous gen.....except for all that ugly black tupperware around the edges. Blerck!
    • I leant out the window recently and took a picture of this new WRX. It looked real damn fine in person. It's faster around a track (stock) than a (stock) GR Yaris. It's much more practical despite being heavier. It's significantly cheaper. This gen tunes really well, much better than others. .... I think they're probably a lot better than people expect.
