Hi Guys,
Some finance issues sees this car back on the market!
Grab yourself a bargain - my loss is your gain!
I have decided to keep a few bits for my new car so i can now reduce the price!
You can have it for $33K rolling on R34 GTR rims :D
Motor
Trust 264deg easy street cams
Trust springs and cam gears
Trust Metal Head Gasket
Arias Pistons and Eagle rods
Nismo bearings, Oil Pump and Water Pump
Head fully recon'd and lifters set for the cams
Fully balanced
Block and crank crack tested
Block acid dipped, decked etc
Crank linished
Motor is 4 track days old (car since being in OZ has not been driven on street - A/C and Stereo still present)
OS giken Triple plate clutch
Standard gear box
Support
Twin Turbo Trust T517z
Trust Hard piping Kit
Trust Intercooler
Trust Intake plenum
Trust Greddy radiator
HKS Fuel Rail Kit
HKS 1000cc Injectors
Sard Fuel Reg
Sard Fuel Cell
Sard Twin pumps
Twin Nitrous bottles
Purge
HKS oil Cooler
Tomei Sump Baffles
Aero and Susp
Ganador Mirrors
Sard GT dry carbon wing
coilovers
Electronics
Haltech E11 v2 current tune on E85 spinning NOW 383awkw @ 22 PSI (25/06/10 @JEM)
Defi gauges
HKS boost controller
Field ETS tourqe split
Wheels and Brakes
Top Sercret LE37's 18x10.5 +12
285/30/18 Yokohama ADO8's (75% tread)
Brembo F40 Front Kit
Includes 2 piece Rotors Braided lines Etc
Ferodo 3000, EBC yellow stuff
Brembo rear
Random
Ganador mirrors
Special Tail Lights
Upgraded to S3 Xenon Light
Bride Drivers seat
Sabelt Harness
awesome package bargain at that price
quote name='HKS26T' date='30 Jun 2010, 08:47 PM' post='5321679']
Hi Guys,
You can have it for $33K rolling on R34 GTR rims :rolleyes:
Motor
Fully balanced
Crank linished
Standard gear box
Support
Trust Intercooler
Trust Intake plenum
HKS Fuel Rail Kit
Sard Fuel Reg
Sard Fuel Cell
Sard Twin pumps
Purge
HKS oil Cooler
Tomei Sump Baffles
Aero and Susp
Ganador Mirrors
coilovers
Electronics
Defi gauges
Wheels and Brakes
Brembo rear
Random
Ganador mirrors
Special Tail Lights
Bride Drivers seat
Sabelt Harness
Is she complied? I only ask as I can't see a plate.
eheh It wasnt when this engine bay photo was taken, it was towed to the track this day, good spot! :ninja:
but definately is and street registered :ermm:
Edited by HKS26T
Thanks Guys :( back to 6 she goes :mad: ppl might get the wrong idea.
Lots on interest, but no takers!!!
Would be a real shame if i had to de-mod the car - There is plenty of value in this!
So capitalise on my losses and take this off me!!!!!!!!!
I notice the spec list says it's on the gas. - Was that power made with the gas or just E85 no gas? - Was the car ever tuned on 98?
I also read that you were keeping some bits from the car, Whats the current spec list?
Regaurdless, still a truely impressive car...
Any pics as the car stands today?
    • Ok glad you clarified on the frenchy’s options , I was worried about if my oem hoses would fit the new compressor or not if I just bought the bracket/compressor kit ,  didn’t realize they also sold a larger full conversion kit. Hmm may just go oem in that case then to make it easy only because I plan to sell this car to upgrade to a 32 GTR or 34 GTT.
    • Sorry Duncan, I didn't get a notification for the replies.  Thanks for responding!  It's a full Android device, but does allow you to use CarPlay/AA as well.  This is the one I bought from NaviRS on AliExpress: https://www.aliexpress.com/item/1005006368602668.html?spm=a2g0o.order_list.order_list_main.111.59aa1802JDzQ0E - the 2K 8G-256G CAM variant but it seems to have gone up by £170 since I bought it!  My purchase was £307.14.   It's not the fastest thing in the world but performs perfectly adequately.  It stays on standby unless I disconnect the battery and let it power down, then it's just a fairly standard Android bootup time from cold.  The DSP Equaliser is very nice and made the standard stereo system sound pretty decent compared to the stock screen.  Perhaps I can take a video of it when I get a sec. It *allegedly* supports the reverse camera, but I'm yet to get that working.  It has options for reverse cam (a camera unit can be bought separately) or 360 cameras (also bought separately).  To be fair it doesn't seem to detect that the shifter was put into reverse but I'm working on a theory about this as well.  At the moment I'm going without which is a bit annoying considering the car is an absolute canal barge but so far I haven't caused any damage I'll grab a picture of the wire I'm missing later today when I can get outside.  My theory, by the by, is that not only is the head unit different, but the CANBUS network has different signals for the different years.  I think this because I have a spare AC panel from a newer Infiniti G37 (as opposed to my Nissan panel) which wouldn't control anything except the volume when I had it wired up with the stock system.  I'm going to throw it back in and see if the screen will respond to it.  I've just ordered an arduino CANBUS module so I can have a look at the signals going around the car and see if I can spot anything.  I'm thinking if I can work out what it's expecting vs what it's getting I might be able to translate and relay the signal back but so far just a theory anyway. I also found this on my travels, so far the only one that specifically matches my car: https://www.aliexpress.com/item/1005002822934280.html?spm=a2g0s.imconversation.0.0.33433e5fgttovi If you look at the picture of the before, it has the card reader slot, and the picture of the head unit is exactly the same as the one pictured in my original post.  I asked if they sell the cables separately but sadly they won't.  I didn't want to just buy this one because it's a super old Android version and only dual core - likely slow as hell.
