  funkymonkey said:
collective nouns are only used for herding animals, and other that in the case of R33's which are aking to rather obese cows, I don't see how you can apply m to cars.
From a grammatical standpoint anyways...
I don't think so mate. Can you herd a gang of wankers?
I'm voting for Battery so far.
  • Replies 72
'plethora'
'menagerie'
r31's could be called a 'museum' or an 'antique collection', although they probably wouldn't quite fit in with the 'antique' tag, I think you have to be worth something to be called an antique.............lol
hello tridentt1 50v, i was just wondering why you picking on the lil R31? my R31 is a 1990 model, my boyfriends R33 is a 1994 model.... how does being four years older make it an antique.... imo it doesnt matter what age your skyline is.. its still a skyline! :):(
    • GTSboy, thank you again. i’ve been reading all the other SAU RB25 vacuum line threads and you have the utmost patience for people asking “where do my vacuum lines go”. it’s appreciated. i did also enlist a few other RB guys local to me.  i would like to run 5 to 4. turbo pressure side to wastegate actuator. i would like to run 3 to 1. power steering air valve line to intercooler outlet. (this is how it was previously). i was told 2 is the bleed port for the boost solenoid - which i’m not running - so should be capped.   anyone see any problems with that?
    • So yes. All of them. Something like 98% of all fuel in the USA has 10% ethanol: https://afdc.energy.gov/fuels/ethanol-fuel-basics It's labelled as like, AKI, 87, 91, 93 with an E10 or E5 or E15 label on the pump. At a certain point, it's not just "E10" instead of 91. It is 91, 95, 98, and all of them have 10% Ethanol in them. You can also get E85 and E30 which is why you do see some people rolling around with E30 tunes in them.
    • Thanks for the response. This is an 04 EP3 Type R. JDM spec. Fairly certain they're just basic BC racing coils. I do plan to keep as the ride quality on stock I've been told is pretty meh given Sydney roads. If I were to go down that avenue, does NSW require them to be a certain spec (close to original) etc?
    • Should have asked what is the car?
    • I've had two super conflicting experiences with blue slips. My 30 year old E39 waltzed through with no issues but my brother in law was knocked back on 12 y/o 3 series due to wiper blades and some cracking in a control arm bush.  What kind of coil overs? Do you want to keep them after?  If it was me I'd get some dirt cheap shocks and springs from eBay or scumtree. Not ideal but will get you over the line and might even be less than $1k.
