Ok guys I know this is probably a stupid question, but forgive me for my ignorance. Does the r32 gtst have a hole in the left inner guard, underneath the battery? I'm pretty sure that it was made for the fmic. Qld transport giving me a hard time saying that "I need to restore it to original manufacturer standards". Which makes no sense to me.
Any thought thoughts? previous experience with this
https://www.sau.com.au/forums/topic/327049-stupid-question/
I would start by moving your battery to the right hand side like everyone elses.
And no there is not supposed to be a hole there.....and no the guy at QLD transport doesn't know what the f**k he is talking about because it has nothing to do with structural strength and does not effect the roadworthiness of the vehicle. Tell him to re-educate himself
https://www.sau.com.au/forums/topic/327049-stupid-question/#findComment-5322582
back in the day i thought all aftermarket fmic setups where illegal.
now im seeing alot of mechanics pass rwc in vic legit , providing its not structural or important part of vehicle from safety aspect
heading to brisbane in 1 week ... any1 have pointers ? dodgey rwc :P hook me up!
do i only need rwc ? or present the vehicle also?
r32gtr huge exhaust =/
https://www.sau.com.au/forums/topic/327049-stupid-question/#findComment-5323520
Sorry I meant right hand side...lol If you stand in front of the car it becomes the left side....hahaha
That's what I thought Dan
My sister had to see Qld Transport to get a number of "defects" approved after an officer pulled her over in her R32Gtst. The front mount intercooler pipe came into the engine bay in the same spot as the GTR. As an engineer I simply prepared a letter for her essentially stating what has already been said. It will have neglible structural impact on the car. The fact that the GTRs have a hole in this location and on the passenger side there are more penetrations for the intercooler piping says it all really.
When I had my RB30DET mod plate prepared, the approving facility included the front mount intercooler installation as part of the description for the modifications.
Edited by BH_SLO32
https://www.sau.com.au/forums/topic/327049-stupid-question/#findComment-5323619
they will say it has to be engineered (mod plated)
o.p. take your car to an engineer and get the hole mod plated
there is no code for a hole in a non-structural area. The only thing you can do is put it under 'Chassis Mod' but it's not the correct code for it.
And yes, before you ask...I have the code of practice here
https://www.sau.com.au/forums/topic/327049-stupid-question/#findComment-5332798
Can anyone recommend an engineer, around GC or brissy that's not going to charge me a arm and a leg for their signature.
I need the hole certified once I get it reinforced.
Andrew - 0402293256 and tell him Daniel from Elite Racing sent you as he normally doesn't deal with public
https://www.sau.com.au/forums/topic/327049-stupid-question/#findComment-5341877
    • Yeah well per the video it took 15s for the stock unit to start up....even if I give it a few seconds discount for starting that is at least 12 sec before you get a reverse camera if you are trying to leave a park.  The android unit is way faster, but 2016 for the stock unit is a long time ago in consumer electronics
    • Yea that’s why I said ima test them with multimeter and see the reads.
    • Only at idle. Isn’t a problem when rev it seems.
    • @Haggerty This seems silly to ask, but are you confident in your ability to tune the Haltech?
    • Next on the to-do list was an oil and filter change. Nothing exciting to add here except the oil filter is in a really stupid place (facing the engine mount/subframe/steering rack). GReddy do a relocation kit which puts it towards the gearbox, I would have preferred towards the front but there's obviously a lot more stuff there. Something I'll have to look at for the next service perhaps. First time using Valvoline oil, although I can't see it being any different to most other brands Nice... The oil filter location... At least the subframe wont rust any time soon I picked up a genuine fuel filter, this is part of the fuel pump assembly inside the fuel tank. Access can be found underneath the rear seat, you'll see this triangular cover Remove the 3x plastic 10mm nuts and lift the cover up, pushing the rubber grommet through The yellow fuel line clips push out in opposite directions, remove these completely. The two moulded fuel lines can now pull upwards to disconnect, along with the wire electrical plug. There's 8x 8mm bolts that secure the black retaining ring. The fuel pump assembly is now ready to lift out. Be mindful of the fuel hose on the side, the hose clamp on mine was catching the hose preventing it from lifting up The fuel pump/filter has an upper and lower section held on by 4 pressure clips. These did take a little bit of force, it sounded like the plastic tabs were going to break but they didn't (don't worry!) The lower section helps mount the fuel pump, there's a circular rubber gasket/grommet/seal thing on the bottom where the sock is. Undo the hose clip on the short fuel hose on the side to disconnect it from the 3 way distribution pipe to be able to lift the upper half away. Don't forget to unplug the fuel pump too! There's a few rubber O rings that will need transferring to the new filter housing, I show these in the video at the bottom of this write up. Reassembly is the reverse Here's a photo of the new filter installed, you'll be able to see where the tabs are more clearing against the yellow OEM plastic Once the assembly is re-installed, I turned the engine over a few times to help build up fuel pressure. I did panic when the car stopped turning over but I could hear the fuel pump making a noise. It eventually started and has been fine since. Found my 'lucky' coin underneath the rear seat too The Youtube video can be seen here: https://www.youtube.com/watch?v=uLJ65pmQt44&t=6s
