Hi Fellas,
After reading a bunch of posts with you guys comparing how many K's you get per tank. I started thinking why the hell am I only getting around 400...
I am one of those unlucky V owners with the problem where I fill up my car full but it only goes to 3/4 full on my dial. When my empty light comes on im sitting on aroudn 350-400. But because im only getting 3/4 full on the dial. Does this mean I have a 1/4 tank left when my light comes on. 400 k's doesnt seem right compared to you guys getting 550-600.
I dont drive like a "hoon" and I do drive to work and back in traffic. But I dont see why I'm only getting 400.
Any comments would be helpful.
Thanks.
https://www.sau.com.au/forums/topic/327063-does-this-sound-right/
Regardless of what your fuel gauge displays, it would be much more logical to reset your trip meter next time you fill up so you get more accurate data.
Then when you fill up AFTER that, you'll know how much fuel you used and how many kilometres you drove.
That's much more useful information (eg 11L/100M) than "I get 400km on a tank".
You may find that you are only filling 60 litres of an 80 litre tank and are getting the same fuel economy as everyone else.
Sorry, I forgot to add. I don't have a trip computer. No factory screen.
:P
U don't need a trip computer to work it out. Fill her up full, reset odometer, drive, next time you refill, make note of how many litres u fill up, the divide litres/ km travelled n u get ur consumption.
Hi Fellas,
Thanks.
I don't think the 3/4 full tank means it's not full. My car does 600km/tank if 90% highway. 400-500km if 50% highway. My car sometimes also show 3/4 full, it's just the level sensor in the tank are dirty. It should be full if you fill the tank till the fuel nozzle click, sometimes I double click, just to make sure. There's another discussion in this forum about that.
Wouldn't it make more sense to fix your fuel gauge problem? :P
Our cars have a 76 Litre tank... in my post yesterday: http://www.skylinesaustralia.com/forums/Fu...on-t327122.html
With my current Tyre\Rim setup, On a full tank I average about 11 Litres per 100km when I am cruising on normal roads (no freeway driving).
If you do the maths, on a 76 litre tank I can expect to get about 690km per tank... again this is not Freeway driving.
Hope this helps.
I fill up as much as possible and it only goes up to 60L.
I have never been able to put in any more.
I tend to get 450-550km of a tank of normal driving.
this is about 50-50 highway and city.
same, although ive managed 64 litres. and best was 621kms on hwys 90% of the time. i think v35-paul has the highest figures because of geraldton to perth and vice versa.
Hey Tony,
Quick question. You fill ur car up immediately when the low fuel warning light is on? Perhaps that's the reason why it's only 60L?
Anyway, an average of 500km for 60L is not too bad at all I guess.
My little Mazda 6 tends to go around 600km for a full tank and I usually fill around 55L in it. Considering the extra performance in a v35, i guess it's a good trade-off!
Nah mate. I fill up at the local shell 90% of the time so unless im absolutely down, i go there.
The light usually comes on for about 50-70ks.
When i was coming back from Syd, i got 702ks, had the light on for about 90min whilst i shat myself alot!
still only got to put in just over 59l.
im a gt8 btw if that helps at all.
    • Surely the merged entity will be called "Honda" given the relative company values. I've got to be honest, I don't understand how merging 2 companies that missed EVs (despite Nissan making the first mass produced one) will solve their problems
    • If you haven't bought the ECU yet, I would strongly consider buying a modern ECU. Yes it is very easy to setup and tune, however it is lacking many of the features of a modern ECU. The pro plug in is something like 10 or 12 years old now? Can't remember exactly but it is very dated now. In that time the Elite was released and now we have the Nexus platform.  I would strongly consider not buying the ECU that is 3 generations old now (especially as it isn't a cheap ECU!).
    • Im happy for it as long as it means reanult gets the boot
    • Sorry I should have been more clear with the previous post.  The block is a sanding block - picture something like this https://motorguard.com/product/motor-guard-bgr161-bgr16-1-rigid-psa-sanding-block-2-5-8-x-16/ The guide coat is the paint It's two separate things I was talking about, there is no "block guide coat".
    • Maybe more accurately, you aren't just dulling the existing paint, you are giving the new paint something to 'grab on to'. By sanding the existing paint, you're creating a bunch of pores for the new paint to hook on to.  You can lay new paint over existing paint without sanding it, might last a year or two then sad times. The paint will peal/flake off in huge chunks. By sanding it, the new paint is able to hang onto it and won't flake off.  Depends on the primer you are using. When you buy your paint, as the paint supplier what grit of sand paper to use before you lay down the primer.  Use whatever you like as a guide coat. Pick a colour that really stands out in contrast to the paint. So say your sanding/painting a currently white car, using a black guide coat would work well. You very lightly lay the black guide coat down, then as you sand the car with the large block, all the high spots and low spots will stand out as the black paint is sanded off (or isn't sanded off).  When you buy your paint, hit up your supplier for recommendations for what paint to use for a guide coat if you're unsure what would work well with your setup.
