Jamez,
still sourcing the pic for you. However just noticed, mine only lists 15" & 16" tyres?? GTR's come stock with 17"?? WTF
Merli:
Can't see the pics, could you make them any BIGGER
HAHAHAHAHAHAHAHAHAHAH!!!!
I wanted to make sure they were big enough for James to print out :)
and it's only 1600x1200... I can post a 3008 x 2000 version if you want :D:(:P
Here's a placard James... looks like I need to speak to Dean again too - my tyres (very common on GTRs) aren't listed; 255/40/17 (Falken Azenis, 94ZR)
I don't want to get done for something as pedantic as a tyre size that's unlisted, especially when they're a safe tyre, rated for high-speed use, when there's people out there running on retreads.
Thanks guys.
Spoke to Police on Friday evening - they're happy for me to replace my tyre placard with one like Merli's (I got from UPI). Do good to know my car can go from defective to fine - by changing a sticker.
So dumb. Such a waste of time...
Anyhoo. Something to be wary of.
Thanks again all for your help.
I'll be sending a letter to the Police and VicRoads regarding this. Will keep you posted.
James
yep, i went through this during rego inspection. Tyre placard said 17" tyres on all four corners but I'd fitted 16s.
The guy said, "either change the tyres or the placard". I changed the placard so it said 16s on all corners and it passed. I was dumbfounded.
I'm thinking of moving up to 17s, so lucky I still have the old placard. This is all VERY strange.
I haven't read all the posts, so what I am about to say may have already been said.
Anyway, I got some new tyres recently. On the manufacturer's info sheet, it stated that load indexes for the Z-speed-rated versons of the particular tyre model were for information purposes only.
I am reading into that that Z-speed-rated tyres do not really have a load index, and therefore as long as you have a Z-speed-rated tyre, then that is sufficient.
Once again, we have a case of people who are neither trained nor qualified in the determination of the roadworthiness of a motor vehicle making decisions on whether or not a vehicle is or is not roadworthy. But then someone has to do it, I suppose.
I'm not really concerned about that, so much as the inconsistency of it all. How is it right that I should be able to make my tyre specs legal simply by changing a 50c tyre placard that I could whip up on my laser printer? Similarly, the tyres on my R33 might not be legal on the next R33 I see.
It's not localised to our Jap imports either - a friend who imports Mustangs from the US has the same issue.
    • For once a good news  It needed to be adjusted by that one nut and it is ok  At least something was easy But thank you very much for help. But a small issue is now(gearbox) that when the car is stationary you can hear "clinking" from gearbox so some of the bearing is 100% not that happy... It goes away once you push clutch so it is 100% gearbox. Just if you know...what that bearing could be? It sounding like "spun bearing" but it is louder.
    • Yeah, that's fine**. But the numbers you came up with are just wrong. Try it for yourself. Put in any voltage from the possible range and see what result you get. You get nonsense. ** When I say "fine", I mean, it's still shit. The very simple linear formula (slope & intercept) is shit for a sensor with a non-linear response. This is the curve, from your data above. Look at the CURVE! It's only really linear between about 30 and 90 °C. And if you used only that range to define a curve, it would be great. But you would go more and more wrong as you went to higher temps. And that is why the slope & intercept found when you use 50 and 150 as the end points is so bad halfway between those points. The real curve is a long way below the linear curve which just zips straight between the end points, like this one. You could probably use the same slope and a lower intercept, to move that straight line down, and spread the error out. But you would 5-10°C off in a lot of places. You'd need to say what temperature range you really wanted to be most right - say, 100 to 130, and plop the line closest to teh real curve in that region, which would make it quite wrong down at the lower temperatures. Let me just say that HPTuners are not being realistic in only allowing for a simple linear curve.
    • I feel I should re-iterate. The above picture is the only option available in the software and the blurb from HP Tuners I quoted earlier is the only way to add data to it and that's the description they offer as to how to figure it out. The only fields available is the blank box after (Input/ ) and the box right before = Output. Those are the only numbers that can be entered.
    • No, your formula is arse backwards. Mine is totally different to yours, and is the one I said was bang on at 50 and 150. I'll put your data into Excel (actually it already is, chart it and fit a linear fit to it, aiming to make it evenly wrong across the whole span. But not now. Other things to do first.
    • God damnit. The only option I actually have in the software is the one that is screenshotted. I am glad that I at least got it right... for those two points. Would it actually change anything if I chose/used 80C and 120C as the two points instead? My brain wants to imagine the formula put into HPtuners would be the same equation, otherwise none of this makes sense to me, unless: 1) The formula you put into VCM Scanner/HPTuners is always linear 2) The two points/input pairs are only arbitrary to choose (as the documentation implies) IF the actual scaling of the sensor is linear. then 3) If the scaling is not linear, the two points you choose matter a great deal, because the formula will draw a line between those two points only.
