I was looking at purchasing a gt2835pro S kit for mt rb25det neo, upon ordering it they told me its not made anymore and they can send me a gt2835kai, which i assume you dont get a dumppipe. Just not sure what else is differnt with the kit for the turbo itslef?? any help?? cheers
https://www.sau.com.au/forums/topic/327087-gt2835pro-s-vs-gt2835kai/
on the HKS website it still says it comes as a kit, but I think the Kai version is now using the twin scroll version...
slight power increase going by what the translated HKs page says...
I have a used HKS2835pros turbo for sale with exhaust flange if your interested
The 2835 has always confused me slightly, its seems so close to the GT-RS that its place in the market isn't really required? They share the same compressor wheel, with a slightly bigger rear housing correct? Obviously HKS's graph proves the difference between the kits is minimal, to say the least.
I would actually say by looking at the graph that the GT-RS is redundant...
But also the difference between the pros and kai is pretty much nothing in performance, the kai should whistle like a bitch with that front cover though
The Pro S is close to the RS, but seems to have a marginally bigger top end. It is squeezing in between the RS and the 3037 in the HKS range. All three have been around now for quite a few years.
The Pro is the difference, external WG etc etc.
Not sure if you can still get the Pro now though?
I agree, judging by the graph the GT-RS should be dead in the water.
  • 3 weeks later...
As far as I know no one is doing a "T3" flanged twin scroll twin integral gate turbo so far .
I doubt this situation will last forever since Mitsy has done so well with turbos like this , except in their own flange pattern . Actually HKS is now doing a bolt on BB TS TIG turbo for the Evos 4-9 and its supposed to be a nice if expensive unit .
It looks to me like Garrett is being left behind with wheel designs and trims and it remains to be seen if they'll do anything about it . Slightly larger wheels and or smaller trims is working better for the other turbocharger manufacturers and when you throw in TS turbine housings and port shrouded compressor housings they can be wider ranging things .
A .
You wouldn't happen to know if there's any difference in specs? Externally it just looks like there's anti surge slots, and that's about it!
Assuming you are friends with the OP, did the KAI come with a dump or is it an OEM bolt up scenario?
    • Holy hell! That is absolutely stunning! Great work!!!
    • It does when you start adding everything else in. But it's not just compute. It's the logic. Getting your timing right (I'm not meaning ignition timing for the engine). Making sure of your memory mappings, seeing your interrupts. Microcontroller devices only have so much capacity. For the most part, you want all those timers and interrupts in use on your engine control, which means you're left with less than ideal methods for timing and management of other control functions.   Let's put it this way, my job is all about building custom hardware, that goes into cars, and integrates with them. We're also waiting on a media confirmation from SpaceX too fora world first we've just completed with them in NZ too. It's not just the little toys I play with. But you know, you can think and believe what you want.
