Sup. Just like my cat thread, I need some advice.
I was wondering if you guys have had much experience with the HPI exhaust products, specifically the bellmouth dump pipes for the rb26.
After a few quality probs with some exhaust products I purchased, and some info I've found on here re: split dumps - I've decided to go back to stock manifolds, with bellmouth dumps.
I've been told by JJ's that these dumps are very high quality - and I'm told they are manufactured in Japan.
Thanks in advance for any advice. I'm sure a few people must have these fitted, were the welds good? Decent thickness? Noise levels?
https://www.sau.com.au/forums/topic/327120-hpi-dump-pipes/
Just to complete my thread. I received these ones today from JJ's. The welds are practically immaculate. There is no excess weld, dags, or loose steel in these. Compared to the .. other product, these are mint. Cost 900 odd (from a trusted company), overnight delivery, thick steel. The only gripe I have is they don't have provisions to mount the old shrouds, but that's a small niggle about a very good product.
Will be fitting them with new -5's this weekend. Might come back once more in a few months to add whether they've lasted or not (which I think they will :D)
https://www.sau.com.au/forums/topic/327120-hpi-dump-pipes/#findComment-5329231
  • 3 weeks later...
the current hpi ones are definately better than the current tomai ones.
hpi is a fantastic brand, a lil exxy but the quality that i have seen first hand is top notch
the x force are good too though a bit cheaper too
https://www.sau.com.au/forums/topic/327120-hpi-dump-pipes/#findComment-5357686
I've been researching a fair bit regarding replacement dump pipes for my GTR. It seems as though the single bell units offer better performance gains making them a worthwhile upgrade than the dual channel variants.
I have noticed that these enlarged single dumps that are say, a foot in length cost upwards of $860 for a pair.... I know they are stainless but that is a fair bit in comparison to some of the other split dumps that exist.
So i guess what I'm asking is, are there any similar brands offering bell dumps for say $600??
Thanks
https://www.sau.com.au/forums/topic/327120-hpi-dump-pipes/#findComment-5358082
Don't bother with the split designs (HKS and every person and their dog who has copied this design like CES, XForce etc have done, and just about every Chinese knockoff, autobahn888 etc), the split is just too short to be worthwhile. Also bear in mind at the bare minimum, the rear turbo (or front if I've got it backwards) has to be removed to fit new dumps, unless you are making over 350kw I would stick to stockers.
If you have your heart set on bellmouth dumps, wait abit for the australia dollar <-> japanese yen to get better and you could import a pair (HPI, Tomei etc) for just alittle over $600
https://www.sau.com.au/forums/topic/327120-hpi-dump-pipes/#findComment-5358396
Thanks lance, i gathered that would be the case. I'm looking at upgrading turbo's so i considered looking at doing the dumps aswell. Really curious as to why other manufacturers (locals) haven't had a go at putting together a decent bell dump.
https://www.sau.com.au/forums/topic/327120-hpi-dump-pipes/#findComment-5358638
I am pretty sure the HPI dumps are quality items. I was trying to bid for some on yahoo auctions but they just got to expensive.
You get get some tomei ones these days for around $700-$800.
I ended buying some 2nd hand ces race pipes. They are a split pipe design but they are similar to the trust front pipe system, not just short dumps.
Anyway let us know how you go with the -5's. I have a pair of these also waiting to go on.
https://www.sau.com.au/forums/topic/327120-hpi-dump-pipes/#findComment-5359085
Thanks
One of the reasons the split dumps are cheaper is because when you look at them, the pipes are the same diameter from one end to the other. This is a simple case of bending the pipes to the right angles, and welding away. The bell mouth adds complexity to manufacturing, which adds to the cost. You aren't getting "ripped off" paying extra for the bell mouths since they cost more to manufacture.
From what I've read, the split dumps will give you boost creep on upgraded turbos. On a side note with the splits they usually come with a "divider" that sits in the turbo's exhaust housing to split the gasses. Well my -5's have sort of a divider in them already, and it's got a vein cut in it (I assume for better backpressure/wastegate gasses control) so I wouldn't be using the"divider" that came with the pipe. And besides the ones that come on the dump pipes aren't the same shape as the one's that come with the -5's. Steer clear all together with the splits.
Basically, I went through this a few weeks ago with the same things in mind. I didn't want to spend $800+ on dumps, but now I have, and I know I've made the best decision. (bar looking for 33/43 dumps for my 32)
https://www.sau.com.au/forums/topic/327120-hpi-dump-pipes/#findComment-5361930
    • Porous blocks are a known issue on something like a Porsche M96, it's not really something I've ever heard of on an RB26. It's possible what people thought was a "porous block" was really a cracked block that they just didn't spot the crack on.
    • This is a controversial subject really, the whole power vs fun thing I mean And this is the main reason I got back into a MX5 Of the last few notable daily cars I've owned whilst I have frequented SAU R33 GTS-t: fun, but because I'm a idiot I modified well past a reliable fun car and ended up hating it, although that was my fault because I tried to have a daily cruiser and race car all in one, the family called it the sometimes car, because sometimes it was working, sometimes it was broken, gladly sold it NB MX5: brilliant car, thrashed the Bejebus out of it, but, again, was stupid and deleted the air con, power steering and stripped the interior out, whilst still fun, and reliable, and super cheap on consumables, it was not a fun place to be going on long cruises, I did love it, but basically every family member hated going anywhere in it, sadly sold it 2015 WRX STI: soulless thing that looked like your average Kia sedan and had that horrible boxer engine with glass ringlands, the family did like it though, that thing was one of my stupidest purchases and I still regret it 2017 Toyota 86: 😪 if I didn't crash it, I would probably still have it, it was a fun little thing, even with that horrible boxer engine, the family did like it, the only reason I didn't get another 86, or, BRZ was the boxer engine, I should have learnt after owning the STI, but I'm a idiot VX SS: great cruiser, fits the whole family, and was fast as.....in a straight line, but a big fat thing, so no enjoyment throwing it around corners, the family was unimpressed with the whole boganness of if, but they did admit it was a comfy place to sit on long cruises As for the NC, I feel it is perfect for what I want, or need out of of a car, whether I'm cruising the Hwy, back roads, twisties or peak hour traffic, the Mrs doesn't mind driving it either, or cruising in it as well, although she does bump her head of the roof nearly every time she gets in, which is farking hilarious, and the kids love taking it for a thrash as well So basically, I've had constantly more fun, and way less headache and heartache, both on the track and on the street, in low powered cars,  go figure.....LOL One thing though, the Mrs has stated that the cams have made the exhaust sound much louder, which they have, but it doesn't bother me, in fact, I actually like it, but, to negate any future comments from the Minister for War and Finances I may look at some changes to the rear muffler set-up to drop the volume down a tad to appease her when we are out and about in it
    • You will need to extend the turbo inlet pipe somehow, which could/might be done with silicone/rubber pipe, but might need steelwork, depending on your intake. And you will need to change the pipework on the outlet in teh same way, but this is more likely to need steelwork.
    • I see... Any idea how much fab work is required? I note the Hygear megathread but its like 900 pages
    • I should try the experiment you're talking about, the throttle switch is still there carried over from the R32 and it's still all wired up but after I did the whole intake manifold refurb and had to recalibrate the TPS I managed to somehow get the idle switch reporting activation at 0.22V, then when I adjusted it to 0.45V for idle it decided the engine was permanently no longer idling which caused some very weird behavior, closed loop idle was disabled so it would basically be at the whims of the cold start valve and whatever the base timing table was at. Then just unplugging/replugging the TPS with the ECU live caused it to relearn the idle TPS position and decide 0.45V was idle. Presumably there's nothing in the TPS that allows for the throttle switch to "recalibrate" like that, not easily at least.
