reason why the R34 calipers are taller is because they use bigger rotors...
i think you have been jipt in the calipers.. sounds like there not r33 ones..
x 2
i'm convinced that they are z32 callipers
Chasing pads for our S2 Stagea! I want to keep std calipers. I jacked wagon up yesterday, took a couple wheels off and traced around pards & measured and rotors. I was on bendix website up until not long ago and from what I could find pad sizes match J30 Infiniti, front (db1398) and rear (db1399). Can anybody share or compare part numbers???
I was thinking Of buying those brakes
there advertised as r33gtst
if they definately are roo,I'll take them provided I can trial fit before I pay
When I know for sure what they are, I'll let you know.
EBC do pads for S2 Stagea, chuckie should have the part number, if not I'll ring my mate at RDA and get them.
Actually, they're probably in the big brake upgrade thread.
qfm make them too
its all in the brake thread
gslralleysports (or somthing like that) who is a sponsor on here do the qfm ones for a god price, get the hpx ones - better than bendix ultimates minus the dust
i think the hub to mounting point dimensions are all the same from r32 to r34
if you wanted to run a different rotor with the stock calliper then you would have to get custom brackets made because i think they run slightly different offsets for the disk
i'd either get high performance pads or r34 brakes tho, brackets are annoying
if you need measurements tho, i've still got my stock s2 brakes in the shed
So it looks like S2 must have stagea specific front discs and calipers if all dog bones are the same offset. That kills that idea!!
Is anybody making dog bones to suit S2 stagea, std caliper over r33 gtst rotor????
Anybody know who sells a/market dog bones?
WHY 33GTST rotor,
Series 2 use different rotor .
We're working on a solution, I'd like 33gtr sized rotors with stock calipers on my wagon..
Okay. So after doing some searching on the net I've come to the conclusion that any GTR (R32, R33 & R34) brakes will fit and be a nice upgrade... However you need the matching calipers and rotors. Meaning you can't mix and match the Stagea stock setup with any of the GTR setups.
Can anyone confirm this?
I can get R32 GTR calipers, rotors and lines for $700 but I want to know for a fact they're going to fit first...
series 1 stagea - use anything off an r32 or r33 (r32 gtr was only 296mm x 32mm and r33 gtst was also 296mm but x 30mm)
series 2 stagea - use r34 gtt brakes (310mm x 30mm, stock brake lines can be used with the removal of the olive fitting in the calliper) or r34 gtr brakes (324mm x 32)
The Fit ,Just need to MOD BOLT size,14mm not 12mm With RAF (ruff as f_ck) Spacer :P .
    • Back in January, I noticed my car felt noticeably weak. I had the injectors cleaned, which seemed to solve the problem -- until now. Recently, the car suddenly lost power again while driving. Suspecting the injectors, I brought it to the mechanic. He recommended replacing them entirely, saying the current ones were getting unreliable and fiddly to work with. I could not find a direct replacement for my current injectors. The closest match I found were 440cc injectors. This led me to look into the possibility of upgrading -- and of course, that would mean remapping the ECU. From my research I found: The OEM Part numbers are 16600-72L20 and 16600-72L21 Both the RB20DE and RB20DET use the same 270cc injectors. There are much better options out there over the old OEM injectors. Nistune could be a viable tuning option. While the RB20DE isn’t explicitly listed on their site, the ECU is essentially the same as the GTS-T version - just with a different map. The ECU code on mine is listed as supported. One concern is finding a tuner who works with Nistune. Aftermarket ECU like Haltech and Link, but this would be the most expensive choice (and possibly overkill for a mostly stock RB20DE) I admit that I am very new to the tuning scene and would appreciate any insight or recommendations regarding this.   These are some SAU links where I got some of my information from for reference: https://www.sau.com.au/forums/topic/380324-rb20de-injectors/ https://www.sau.com.au/forums/topic/477396-factory-270cc-injectors/
    • The inspectors are not forensic by any means but if you forge your documents and/or badgings on vehicle parts and are found out, the consequences are just far bigger than if you just run illegal parts. And their job quite literally is to cross reference what parts you got installed and what your papers say you got. Something as silly as your suspension being 1mm too low will fail you. Nonetheless I asked if someone knew the damn pipe and I certainly did not ask for smartassery or underhanded comments, no idea why you need to be told this. Great way to waste both our time.
    • As useful as you explaining what forgery is... But then again, I wasn't aware your inspectors were also forensic experts and inspect nameplates on each component to confirm everything is original. They must inspect roughly 3 cars a year at that rate. You're right though, my comment doesn't help you in anyway, so I'll go talk to my wall now. Cheers.
    • Say that to the guy that is going to fail your inspection or tow your car for illegal exhaust modifications. If you have anything else useful to say, please go tell your wall.
    • You must be fun at parties.
