  • Replies 71
MMM so tempting. Couple questions on that.
What does the 100k service involve? Best place to go to for this ?
What would you guys / Girls fix on it and how?
Anything I should worry about ?
This car will be a 10 year car Im hoping.
100k will cost you around $1000, Boostworx is recommended.
Just give it a nice general clean up, get it detailed, clea the engine bay, the start picking at the thigs that shit you, like, i wat it lower / handle better, dont like these rims, i wanna go faster, etc.
No offence to any budding mechanics around here, but i wouldnt trust a major service to anyone but a recommended workshop. The R34 100k kit from Kudos is a lil over $500, so if you factor in labour and the incidentals, around 1000. Pitlane quoted me $1000.
No offence to any budding mechanicsd her aroune, but i wouldnt trust a major service to anyone but a recommended workshop. The R34 100k kit from Kudos is a lil over $500, so if you factor in labour and the incidentals, around 1000. Pitlane quoted me $1000.
I agree with you there, but as i don't know any mechanics (hoping to get to know a few here) I would go to a workshop. Just hope there isn't an MAJORS on it engine wise or could be a sad day.
On the topic of the engine. Is the RB25DET Neo 2.5 litre 6 cylinder turbo A nice solid powerful engine? Again sorry, not very knowledgeable in this area, just know what i like (aesthetics) :D
100,000k service includes complete fluid flush & change over (every fluid in the whole car), water pump, timing belt, spark plugs, all new filters, 100% car check over, and then the other stuff like rotor machine etc.
Ring up Sinergy Motorsports for a quote :D.
NEO25's are very decent, I would happily run 300+rwkw with a standard bottom end and cams etc providing the tune is nice n chunky :)
Yeah mine was only water pump and timing belt kit when i got boostworx to do it
Simon is running a neo in his drift car and getting like 330 rwkw with a metal head gasket he now has cams but wastegate fell over the last time they went to tune it
Give Martin Donon a call from Willall Racing or Shaun from Boostworx, if i remember ill chat to Martin today if i see him and come back this arvo with a quote
Boostworx - $1350, incl all oil (synthetic) and a dyno ecu touch up. Just got off the phone.
that is not a bad price to pay to have all the work done professionally.....with regards to big things being done to the car i prefer a reputable workshop doing it rather then some back yarder mechanic
Here are a few i found interstate i wouldnt mind getting some opinions on.
R34 GTT 1
R34 GTT 2
R34 GTT 3
R34 GTT 4
If anyone could find something closer that would be a bit easier too.
Victoria wouldnt be to bad as its not THAT far to drive back, but NSW ,may be a fair hike and $$ to drive back.
Would like:
Manual Transmission
under 100k on the clock would be nice too.
34 1 - ugly tail lights and rims, selling before 100k service it seems
34 2 - great base car for some light mods, looks the goods. i rate this one
34 3 - aids wing, but a good list of mods, good price
34 4 - front bar aids, but really cheap, id be checking this one mechanically. km's seem a lil low for a 98.
my opinions
my opinions
My opinion is ... don't forget you'll need a vehicle ID inspection when you bring it over. I like car 3 with the mods, but Regency will have a field day with it. Car 4, does have low (questionable) kms.
Car 3 gets my vote, as long as you got bits access to, to get the ID inspection done easy.
    • Yeah so when you turn key to IGN the fuel pump should run for a few seconds. If you find the fuel pump relay (and have a multimeter, and a second person) to can check the relay inputs.  One trigger pin should be either fully earthed  The other trigger pin should get 12v from the ECU for say 3 seconds when you turn key to IGN, and at all times that key is at START (note, I said this from memory, it may be the other way around, ie one pin always has IGN 12v and the earth has continuity to earth when you turn the key) One Pin should have a good battery voltage The last pin goes to the fuel pump + Also note that if the power to the relay is good, and the relay is working, it is worth checking the pump has a good earth too. There is a computer in the standard system that increases the earth resistance to slow down the pump when not required, pretty old school and it may have failed
    • All this talk about fuel and fancy ECUs, meanwhile my poor old R32 has neither.... When the ignition is turned on, should there be power running o the fuel pump constantly or just for the few seconds it usually takes to prime the pump? About to go have another look at it, have watched some YouTube vids on how to use a  multimeter and looked at some wiring diagrams but really have NFI what I'm looking for because electricity is invisible
    • Yuh....but weren't all the supertourers, except maybe the Audis, FWD? I don't recall any of the others being AWD.
    • They ran them in Oz Super Tourers too https://www.supertouringregister.com/register/vehicle/212/ (I'm so old I remember racing with Matthew Fox) They ran them in Oz Super Tourers too https://www.supertouringregister.com/register/vehicle/212/ (I'm so old I remember racing with Matthew Fox)
    • Inspiration: https://www.nissan-global.com/EN/HERITAGE_COLLECTION/Primera_GT.html
