  • Replies 71
MMM so tempting. Couple questions on that.
What does the 100k service involve? Best place to go to for this ?
What would you guys / Girls fix on it and how?
Anything I should worry about ?
This car will be a 10 year car Im hoping.
100k will cost you around $1000, Boostworx is recommended.
Just give it a nice general clean up, get it detailed, clea the engine bay, the start picking at the thigs that shit you, like, i wat it lower / handle better, dont like these rims, i wanna go faster, etc.
No offence to any budding mechanics around here, but i wouldnt trust a major service to anyone but a recommended workshop. The R34 100k kit from Kudos is a lil over $500, so if you factor in labour and the incidentals, around 1000. Pitlane quoted me $1000.
No offence to any budding mechanicsd her aroune, but i wouldnt trust a major service to anyone but a recommended workshop. The R34 100k kit from Kudos is a lil over $500, so if you factor in labour and the incidentals, around 1000. Pitlane quoted me $1000.
I agree with you there, but as i don't know any mechanics (hoping to get to know a few here) I would go to a workshop. Just hope there isn't an MAJORS on it engine wise or could be a sad day.
On the topic of the engine. Is the RB25DET Neo 2.5 litre 6 cylinder turbo A nice solid powerful engine? Again sorry, not very knowledgeable in this area, just know what i like (aesthetics) :D
100,000k service includes complete fluid flush & change over (every fluid in the whole car), water pump, timing belt, spark plugs, all new filters, 100% car check over, and then the other stuff like rotor machine etc.
Ring up Sinergy Motorsports for a quote :D.
NEO25's are very decent, I would happily run 300+rwkw with a standard bottom end and cams etc providing the tune is nice n chunky :)
Yeah mine was only water pump and timing belt kit when i got boostworx to do it
Simon is running a neo in his drift car and getting like 330 rwkw with a metal head gasket he now has cams but wastegate fell over the last time they went to tune it
Give Martin Donon a call from Willall Racing or Shaun from Boostworx, if i remember ill chat to Martin today if i see him and come back this arvo with a quote
Boostworx - $1350, incl all oil (synthetic) and a dyno ecu touch up. Just got off the phone.
that is not a bad price to pay to have all the work done professionally.....with regards to big things being done to the car i prefer a reputable workshop doing it rather then some back yarder mechanic
Here are a few i found interstate i wouldnt mind getting some opinions on.
R34 GTT 1
R34 GTT 2
R34 GTT 3
R34 GTT 4
If anyone could find something closer that would be a bit easier too.
Victoria wouldnt be to bad as its not THAT far to drive back, but NSW ,may be a fair hike and $$ to drive back.
Would like:
Manual Transmission
under 100k on the clock would be nice too.
34 1 - ugly tail lights and rims, selling before 100k service it seems
34 2 - great base car for some light mods, looks the goods. i rate this one
34 3 - aids wing, but a good list of mods, good price
34 4 - front bar aids, but really cheap, id be checking this one mechanically. km's seem a lil low for a 98.
my opinions
my opinions
My opinion is ... don't forget you'll need a vehicle ID inspection when you bring it over. I like car 3 with the mods, but Regency will have a field day with it. Car 4, does have low (questionable) kms.
Car 3 gets my vote, as long as you got bits access to, to get the ID inspection done easy.
    • me too wasnt real happy and cost me a penny or 2 to replace
    • But there's the archetype for the name plate! Here's my view on that stupid T脺V ruleset. Buy a brand name aftermarket piece of equipment. In this case, the Mines front pipe we're talking about. Get it T脺V certified on the car. Damage the underside of it, say on a speed bump. Cut out the damaged section, replace with fresh metal. (For the sake of the argument only), continue doing that to the whole pipe until it is all gone, replaced with new metal. Is this grandfather's axe still the same front pipe? The design hasn't changed (much). The pipe walls are in the same places. The flanges are in the same places. It is functionally identical. How does this differ from a pipe that is ever so slightly different in fabrication (ie the number of welds in it, a few mm here and there in terms of where the pipes run, are joined, etc)? Anyone with 0.5% of a brain can see that there is absolutely no way that the performance (power, environmental aspects, noise, etc etc) of it can be any different than the genuine Mines pipe. Maybe even Mines made 2 versions of this design, with the same differences. How would anyone (say a T脺V inspector) ever be able to differentiate between them? And yet, they are so bloody anally retentive about this stuff. Mad. How upset would they be if you had the wrong spring washers on the flanges?
    • Sakura (cherry blossom) tree at the end of a path going through Kabutoyama Park in Nishinomiya, Japan. Taken with Sharp Aquos R8
    • After a fairly extensive search using Japanese terms and checking Minkara etc, I couldn't find anything even close to your front pipe in the photos. I'm no expert but the two pipes merge really close to the flange connected to the catalytic converter which is rather unique from what I've seen, which makes me think it's more than likely a custom front pipe. The welds and 'more pipe sections than usual for a brand name pipe' makes it seem like a custom one.  Here's some photos of an old Mine's front pipe. You can see that it's just 4 pipe sections as opposed to 6, and arguably looks more like a 'production' front pipe:
    • Wtb r33 low side s2 ac line
