  • Replies 45
i have sunline racing carbon fibre door trims going into mine,
i dont know if they make them for 4doors thought dude.
for ur car what i would be doing is basically stripping everything out from the doors, getting fixed lexan windows and just have an aluminium or carbon sheet of the door shell.
Edited by GUN_METAL_GTR32
Yeah I want to do this on my car as well but how do fixed lexan windows actually fit into the doors if everything is stripped out? Ie - where do they bolt on to?
Cheers,
Glen
Edited by xanavinismo
Cheers guys.
Was gonna go Carbon doors but to much of a head fu*k getting molds made/fixing if i crash etc.
Got a full Tarmac cage getting done in a couple of weeks.
I guess just stay away from the door latch area?
Cheers.
there is bugger all weight in the guts of the doors. The side intrusion bar is the only thing worth taking out. I've gutted a R32 door, and the window and mechanism weigh all of 1-2kg, and all the steel that was cut out was 1kg, they were a series one door. The only thing worth removing is the side intrusion bar (if you have one) as they are about 10kg per side on a two door, And if you gut them you need to still put some plates or steel cable back in to stop the door from sagging
I've started cutting and grinding the door, any tips to taking the intrusion bar out? I've made some slices in the steel tube but don't wanna cut to much cause I might end up through the door lol.
Cheers.
15kg without glass. The one I hacked ended up about 9KG
There was more steel to remove there is still a fair bit of double skin I could have swiss cheesed. MAybe another 1 KG.
Plastic fixed windows and a 0.6mm alloy door card wouldnt add too much back in.
Window winder weighed a tonne and so did the intrusion bar.
I still have to do this to my car yet :P
Pretty interested in how to fix the plastic windows in and maintain strength.
Edited by Tektrader69
Got any pics of the inside of your doors mate?
Did you have to put anything in the door to stop it sagging?
Cheers
Door was still plenty stiff as the outside skin still acts as a sheer web. JP might have some pics?
I think he went further after he got it. It was close to the weight of a glass door after he finished with it.
    • There's a fair chance that my bushes are Nismo, because I'm reasonably sure that when asked the question (when putting the subframe into the car in ~2012) "What bushes do you want to run?", I'm pretty sure I would have answered "The stiff ones!". I had to put some silicone grease onto the GKTech inserts I jammed into them last week, because the bushes were quite resistant to having something jammed up their jacksies. So, I reckon you'll be best off doing Nismo + inserts. And, if I'd known you had PU bushes in the subframe AND PU pineapples, I perhaps would have said earlier that that's probably not a good idea. The pineapples are only intended to work with the stock type bushes, because those have a crush tube (which is what makes it end up looking like there is sloppy space in there - but doesn't, because the crush tube does make contact steel to steel) and the pineapples live in the space between the subframe's outer tube and the lower washer/bracket. But the PU bushes don't leave the space in the same way that the stock format ones do, and they do end up fighting for space. Order some bushes and collars and get to it.
    • Thats the current state of the reo. Bit ew, but GTR Reo and supporting bars are $2000, and 2nd hand GTT ones are $1000... More engine disassembly. The good news is   Various LS weird sounds are apparently normal Everything coming out is in perfect condition The bad news is: Everything coming out is in perfect condition It looks like whoever assembled this engine ~25,000km ago was telling the truth with what's in it and how they did it. Even things I was unsure of like the timing chain - But it's a brand new double row timing chain, spaced perfectly. They even cut up the stock windage tray to keep it instead of being lazy and to work with the baffle. Cam, Heads, springs, LS7 lifters, Pushrods - All look new and have obviously been working perfectly. In other news, we removed the pineapples that were loaded below the superpro subframe bushes. They look a fair bit munted and have deformed the poly bushes that are 'above' them. I'm telling myself that now that there's space 'under' the bush between the little cup that bolts in... that having a pineapple wedged there was bad and basically made the rear end solid. The pineapple and the superpro bush are ... equally deformed (i.e they have deformed one another from being smashed together). We'll see how it goes with bushes only. I am sure this cope will fail and the answer will be to drop the subframe and put nismo rubber bushes in there instead. $400 worth of gaskets and ARP head bolts to replace perfectly new looking gaskets that absolutely weren't leaking  and were installed perfectly with great care - because god damnit.
    • Why bother? Keep them under 1bar and be happy, I had it for 10 years and never had an issue. once you go beyond that the budget blows out fast and then keeps on blowing out
    • I'd still recommend rebuilding the turbos too. That will eat up a lot of the budget especially if you aren't willing to put in the labor to R&R the turbos yourself but it's a huge risk to ignore it at this point.
    • Can't help it, its an illness.
