  • Replies 45
Has anyone had experience with the Bee-R carbon door cards?
Pricey but they look good quality. I am a little concerned they won't sit as flat as a simple aluminium skin, and might somewhat dictate side intrusion options for my cage builder. They look to have a similar shape to the factory 32 skin just without the armrest, pocket and speaker.
http://www.rhdjapan.com/bee-r-carbon-inner...-s15-ae86-54999
Yeah tell me about it - any local alternatives that you know of? I am sure I could sink the $1200 odd bucks somewhere else a little more useful.
Saw your beast out at racepace the other week - one of it not best looking GTSt around :)
Do you guys have cages? I do in mine and door trims just don't fit any more. I padded the intrusion bar and glued a soft backed carpet to the door.
A week or two off putting a full cage in. Stock trims definitely won't fit with side intrusion once its in!
I was looking at getting them when my car was in the panel shop, the price is each, so very expensive! :) IF someone can get a pair at that price then they are a little more attractive
thats not very expensive mate.
mine are worth over 2 grand
sunline racing japan mate.
there getting fitted shortly as soon as my carbon doors arrive :D
still have a nice streetable look to them as well, unlike the bee r ones
Edited by GUN_METAL_GTR32
They do look nice - they are definitely aimed at street cars though - far more intricate than the Bee-R ones which are aimed at caged cars.
The bottom of the sunline ones will interfere with cage side intrustion. My car is going dedicated tarmac rally and won't see the road so I want something basic and flat that won't interfere - Bee-R are the closest I have found in carbon short of just screwing a carbon or aluminium skin on to the door. $1.2k probably better spent on important things like tyres - saying that I will prob still get the Bee-R ones :)
Can't see the point of carbon door cards, may as well buy carbon doors and put in a thin aluminium skin or carbon fibre sheet.
Only thing is racing regs - tarmac rally panel modifications generally not allowed so have to run the standard doors. Carbon fibre sheet might be the go though.
Cool if you have 2k to spend on door cards, but in my books there is no way i can justify that amount of money to run door cards. Hell get some thin alcantara ro look alike material and just glue it to a raw door inner. Hell, way cheaper and lighter and more clearance....also give you the raw race car rattles :D
Cheers, its because I have not been around to bash it off tyres or set it on fire at the track the past two years :)
i have carbon doors on the way with a couple other body parts
my car is caged and they fit with my stock door cards so i dont see why these wont fit with it.
thats fair enuff i guess, but each to there own i like carbon lol
Thats all ive managed to do so far. Dont really know how far to cut. :whistling:
You can go a lot further than that around the edges. even to the point of putting the door handle on the skin and cutting the steel away.
Also swiss cheese the end on the latch side.
It is a dedicated track car isnt it ??
  • 3 weeks later...
    • There's a fair chance that my bushes are Nismo, because I'm reasonably sure that when asked the question (when putting the subframe into the car in ~2012) "What bushes do you want to run?", I'm pretty sure I would have answered "The stiff ones!". I had to put some silicone grease onto the GKTech inserts I jammed into them last week, because the bushes were quite resistant to having something jammed up their jacksies. So, I reckon you'll be best off doing Nismo + inserts. And, if I'd known you had PU bushes in the subframe AND PU pineapples, I perhaps would have said earlier that that's probably not a good idea. The pineapples are only intended to work with the stock type bushes, because those have a crush tube (which is what makes it end up looking like there is sloppy space in there - but doesn't, because the crush tube does make contact steel to steel) and the pineapples live in the space between the subframe's outer tube and the lower washer/bracket. But the PU bushes don't leave the space in the same way that the stock format ones do, and they do end up fighting for space. Order some bushes and collars and get to it.
    • Thats the current state of the reo. Bit ew, but GTR Reo and supporting bars are $2000, and 2nd hand GTT ones are $1000... More engine disassembly. The good news is   Various LS weird sounds are apparently normal Everything coming out is in perfect condition The bad news is: Everything coming out is in perfect condition It looks like whoever assembled this engine ~25,000km ago was telling the truth with what's in it and how they did it. Even things I was unsure of like the timing chain - But it's a brand new double row timing chain, spaced perfectly. They even cut up the stock windage tray to keep it instead of being lazy and to work with the baffle. Cam, Heads, springs, LS7 lifters, Pushrods - All look new and have obviously been working perfectly. In other news, we removed the pineapples that were loaded below the superpro subframe bushes. They look a fair bit munted and have deformed the poly bushes that are 'above' them. I'm telling myself that now that there's space 'under' the bush between the little cup that bolts in... that having a pineapple wedged there was bad and basically made the rear end solid. The pineapple and the superpro bush are ... equally deformed (i.e they have deformed one another from being smashed together). We'll see how it goes with bushes only. I am sure this cope will fail and the answer will be to drop the subframe and put nismo rubber bushes in there instead. $400 worth of gaskets and ARP head bolts to replace perfectly new looking gaskets that absolutely weren't leaking  and were installed perfectly with great care - because god damnit.
    • Why bother? Keep them under 1bar and be happy, I had it for 10 years and never had an issue. once you go beyond that the budget blows out fast and then keeps on blowing out
    • I'd still recommend rebuilding the turbos too. That will eat up a lot of the budget especially if you aren't willing to put in the labor to R&R the turbos yourself but it's a huge risk to ignore it at this point.
    • Can't help it, its an illness.
