Hey guys
My R32 GTSt has been sitting for around 6-7 mounths.
I will be doing the main service things on the weekend, e,g: oil change, plugs an so on.
Just wondering if there is any un-thought of things i should check whilst doing a service to make sure its long sit hasent stuffed anything.
Thanks.
https://www.sau.com.au/forums/topic/327164-sit-skyline-sit/
Hey guys
Thanks.
dont know how newer cars go but with older cars after sitting for 6 months wirh out been started periodicly you would expect your crank berings to be compressed and your rear main seal would start leaking but as i said it was common with old cars !! newer enginers may have found a way to avoid this .
but im sure someone on here will say im wrong etherway it happend to me with a holden gemini
https://www.sau.com.au/forums/topic/327164-sit-skyline-sit/#findComment-5324052
I always ran the car each week for about 20min and went for little drives round the back yard lol.
So hopefully she just needs a good service.
In that case, I think you've just answered your own Q.
Now you can prepare :D to clean it up > join the ACT convoy (just up the Hume) > R32 21st Birthday Cruise from Penrith to Katoomba in Oct + Private screening of '92 Bathurst 1000 @ Edge Cinema :)
https://www.sau.com.au/forums/topic/327164-sit-skyline-sit/#findComment-5324659
    • The nature of my commute has changed. Way back then it was traffic lights all the way, for ~28km. It sucked. When they finally stitched the expressway together I can do a good 15+km of it at a steady 80-100 with no stopping. That alone has gotten me down to flat 10s. Prior to that it was mid-high 10s. I can't remember the delta that I saw when I got the idle down. It was only ~150 rpm, because the idle speed was never terrible, but for the delta in consumption to be noticeable it would have had to have been at least 0.2-0.3 L/100km - which is not to be sneezed at when it comes for absolute free.
    • If you're claiming the issues are not skyline specific, then either the USA is living in the 90s / early 2000s, OR you have the issue of "survivor bias". Which is you're mainly hearing and listening to those with terrible experiences, and haven't found the guys who have cars with good decent builds and no problems. It happens in AU too, that plenty of people keep having issues, and they keep going to the workshops that are known to be shit "because I read on the internet". Even worse, are those who keep posting on the internet as though they know for a fact what something is, when they've never touched/looked at said item in their life, and again are making assumptions, based on something they read, or because it's a certain way in other cars. It's even funnier when those same people debate the facts with the people who've lived and breathed this stuff for over 15 years. Example, I've had someone tell me you can't do something with a Skyline, because they read it on the internet, except I can tell they're wrong, as I did that exact thing back in 2008 with my Skyline.
    • The funniest part I saw, was someone would bitch and moan on FB about something, Andy would be the one to respond, asking for more info, if he could contact them, what the engine setup is, what their config file was, and 95% of the responses were people just going "der! It doesn't work" and Andy going "What doesn't work?" And then going "The firmware!" And they'd go around in circles as no one could ever give information, and Haltech couldn't fault things on the bench, (especially when people wouldn't give any specifics).   Many moons ago, when Andy was back at e420c stage, he reached out to me, and asked me to test different plug and play looms for him (already had an e420c in the car on his V1 PNP loom). And he kept asking me, as I was competent enough to be able to give him some specific feedback on what was/wasn't working, how to replicate the faults etc, and work through things with him. Most people are terrible at answering the questions they're asked, or being able to provide quality feedback other than "it doesn't work".
    • I say it often, none of this stuff is really Skyline-specific per se. But in general there's not a lot of people who actually know what they're doing. A lot of people charging like they do. Agile software development probably isn't the greatest idea for an engine controller.
    • Incidentally, I also put v3 of the tune on the car and did an oil change from 5w20 to 5w40 to see how it affected oil pressure in the mid to high end. I'm still happier with the thicker oil and will stick with it, but clearly the system is happy with 55psi even if I'm not! It's well within the service manual specs...but they are very open
