bubba Posted July 12, 2011 Share Posted July 12, 2011 the method he's describing (with disconnecting the air bleed blug and the 5 pumps on the pedal) put the car into a diagnostic/test mode and de-pressurise the transfer case. having said that though I thought there was some physical/mechanical (not hydraulic) pre-load in the 33 transfer case but maybe it is all hydraulic and is all removed doing the procedure outlined above. haven't bothered to play with 33s enough even when I owned them. It's all hydraulic, the problem with 33+ era is that when you pull the fuse you are just killing the computer, the pump is still supplying pressure to the transfer case. I've even tested this method on a hoist, put it in 2WD and put it in Drive (my car is auto), the front wheels don't even budge. Link to comment https://www.sau.com.au/forums/topic/327206-fitting-a-4wd-rwd-toggle-switch-to-an-r32/page/2/#findComment-5909113 Share on other sites More sharing options...
ido09s Posted July 12, 2011 Share Posted July 12, 2011 I dont disagree that it doesnt work, it was more the wear if it still had preload of some sort, which i thought it still had. The hoist is the ultimate test though and if the wheels dont budge it obviously disables the transfer case totally. I guess having worked for a workshop and being trusted with peoples pride and joy my boss didnt want to take any chances. Dropping the driveshaft was the safest way to tune the car and it totally eliminated ANY possibility of the front wheels kicking in Link to comment https://www.sau.com.au/forums/topic/327206-fitting-a-4wd-rwd-toggle-switch-to-an-r32/page/2/#findComment-5909142 Share on other sites More sharing options...
bubba Posted July 12, 2011 Share Posted July 12, 2011 I dont disagree that it doesnt work, it was more the wear if it still had preload of some sort, which i thought it still had. The hoist is the ultimate test though and if the wheels dont budge it obviously disables the transfer case totally. I guess having worked for a workshop and being trusted with peoples pride and joy my boss didnt want to take any chances. Dropping the driveshaft was the safest way to tune the car and it totally eliminated ANY possibility of the front wheels kicking in Yeah as for working on other peoples cars, I agree with your boss for the most part. After reading all the naysaying I was of the same opinion until one day when I was flicking through the 33GTR workshop manual and came across the short blurb about putting it in 2WD mode so I though I would give it a bash. Much to my happy surprise it worked and a big skid (single pegger ) ensued. So then I had to put an LSD and a switch in Link to comment https://www.sau.com.au/forums/topic/327206-fitting-a-4wd-rwd-toggle-switch-to-an-r32/page/2/#findComment-5909164 Share on other sites More sharing options...
Fryday13 Posted July 12, 2011 Share Posted July 12, 2011 Ok ill be honest im new to this whole thing so ive not to much idea whats going on, but from the brief words i looked at it wouldnt so much be a switch to toggle 4wd and rwd just a permanent change to rwd? Link to comment https://www.sau.com.au/forums/topic/327206-fitting-a-4wd-rwd-toggle-switch-to-an-r32/page/2/#findComment-5909169 Share on other sites More sharing options...
bubba Posted July 12, 2011 Share Posted July 12, 2011 It's a toggle switch.. requires a restart of the car to go between 4WD and 2WD More info in here: http://www.skylinesaustralia.com/forums/topic/345651-awd-to-rwd/page__st__60 Link to comment https://www.sau.com.au/forums/topic/327206-fitting-a-4wd-rwd-toggle-switch-to-an-r32/page/2/#findComment-5909352 Share on other sites More sharing options...
RBish Posted July 17, 2011 Share Posted July 17, 2011 i checked mine out and re soldered all the dodgy wiring and found that they cut the blue/white wire as advised, but they also cut the blue wire ???, it still works but the wires to switch are doubled up and looping around and bridging contacts.??? to fix this would i need a new fuse box or wiring loom? im thinking about taking it to a electrician to sort it out. how much would a electrician charge for something like this? Link to comment https://www.sau.com.au/forums/topic/327206-fitting-a-4wd-rwd-toggle-switch-to-an-r32/page/2/#findComment-5918383 Share on other sites More sharing options...
bubba Posted July 17, 2011 Share Posted July 17, 2011 Get a wiring diagram and figure it out yourself unless you're prepared to sell an arm, a leg and possibly your first born. Link to comment https://www.sau.com.au/forums/topic/327206-fitting-a-4wd-rwd-toggle-switch-to-an-r32/page/2/#findComment-5918678 Share on other sites More sharing options...
RBish Posted July 18, 2011 Share Posted July 18, 2011 yeah i spose i can cut all the shit wiring out, resolder the blue wire together, then join each eand of the blue/white wire to the switch Link to comment https://www.sau.com.au/forums/topic/327206-fitting-a-4wd-rwd-toggle-switch-to-an-r32/page/2/#findComment-5919093 Share on other sites More sharing options...
bubba Posted July 18, 2011 Share Posted July 18, 2011 As long as you can solder semi-decently, use heatshrink and can read a wiring diagram you should be able to nut it out without having to sell a kidney Link to comment https://www.sau.com.au/forums/topic/327206-fitting-a-4wd-rwd-toggle-switch-to-an-r32/page/2/#findComment-5919222 Share on other sites More sharing options...
RBish Posted July 18, 2011 Share Posted July 18, 2011 anyone know where i can get a wiring diagram? Link to comment https://www.sau.com.au/forums/topic/327206-fitting-a-4wd-rwd-toggle-switch-to-an-r32/page/2/#findComment-5919356 Share on other sites More sharing options...
bubba Posted July 18, 2011 Share Posted July 18, 2011 PM me your email address and I'll send one to you, it's slightly too large to attach to a post Link to comment https://www.sau.com.au/forums/topic/327206-fitting-a-4wd-rwd-toggle-switch-to-an-r32/page/2/#findComment-5919533 Share on other sites More sharing options...
RBish Posted July 18, 2011 Share Posted July 18, 2011 im going to get a solder iron, wires, switch and some solder tomorrow Link to comment https://www.sau.com.au/forums/topic/327206-fitting-a-4wd-rwd-toggle-switch-to-an-r32/page/2/#findComment-5919982 Share on other sites More sharing options...
photaii Posted December 3, 2011 Share Posted December 3, 2011 There are two blue and white wires in the same spot on mine?!? Link to comment https://www.sau.com.au/forums/topic/327206-fitting-a-4wd-rwd-toggle-switch-to-an-r32/page/2/#findComment-6137560 Share on other sites More sharing options...
owengts4 Posted April 19, 2012 Share Posted April 19, 2012 Hi all.my names Owen.I have a r32 gts4 rb20det and im having a problem with my 4wd.i wired a switch to the fuse in the engine bay for rwd.it was working great for the last two years until i changed my clutch.since then its stuck in rwd and 4wd light is on in the dash.i disconected the switch and put it all back to stock and its still in rwd and the light is still on.found this thread last night and though id stick this up and see if anyone can help me. thanks for reading. Owen Link to comment https://www.sau.com.au/forums/topic/327206-fitting-a-4wd-rwd-toggle-switch-to-an-r32/page/2/#findComment-6321987 Share on other sites More sharing options...
MJTru Posted July 11, 2014 Share Posted July 11, 2014 You may need to bleed up the system right. The only thing I can think of is you need to go through the bleed up procedures. Then the light should go off. Link to comment https://www.sau.com.au/forums/topic/327206-fitting-a-4wd-rwd-toggle-switch-to-an-r32/page/2/#findComment-7336714 Share on other sites More sharing options...
MJTru Posted July 11, 2014 Share Posted July 11, 2014 (edited) Hi all.my names Owen.I have a r32 gts4 rb20det and im having a problem with my 4wd.i wired a switch to the fuse in the engine bay for rwd.it was working great for the last two years until i changed my clutch.since then its stuck in rwd and 4wd light is on in the dash.i disconected the switch and put it all back to stock and its still in rwd and the light is still on.found this thread last night and though id stick this up and see if anyone can help me. thanks for reading. Owen Follow this link mate to bleed up the system. http://mobile.dudamobile.com/site/TheSkyLife?url=http%3A%2F%2Fwww.skylife4ever.com%2F2011%2F01%2Fbleeding-attesa.html%3Fm%3D1 Edited July 11, 2014 by MJTru Link to comment https://www.sau.com.au/forums/topic/327206-fitting-a-4wd-rwd-toggle-switch-to-an-r32/page/2/#findComment-7336717 Share on other sites More sharing options...
Mikesmad350Z Posted March 7, 2020 Share Posted March 7, 2020 On 01/07/2010 at 10:49 PM, Guest said: I searched but couldn't find a write up of how to install a 4wd-RWD toggle switch on the R32. So after finding one on another forum and doing this mod myself today, I thought i'd contribute a little and write up how I did it. It shouldn't take much longer than 20-30 minutes. If that... I did find conflicting information about the actual fuse location. Some sources say its in the engine bay fuse box, other sources say its on the interior fuse panel. Further research concluded to me that the engine bay fuse will remove 4wd only, while the interior fuse will remove 4wd and ABS/Anti-lock. Tools / equipment needed: - Phillips head screw driver - Wire stripper / cutter - 2 x lengths of wire for the switch (length will depend on where you put the switch, i used about 20-30cm for each wire) - 2 x Female connectors (for the switch) - 2 x Insulated wire connectors (to wire the switch in) - A switch (i got mine from supercheap auto, cost about $9 but there are cheaper ones there) 1) Remove the interior driver side plastic under neath the steering wheel area. 2) Locate the fuse panel and the 4WD fuse. It will be the red 10A fuse in the top left corner. Remove this fuse and start the car. The 4wd and Anti-lock dash lights should light up if you've taken the correct fuse out. 3) Turn the car off, replace the 10A fuse and remove the fuse panel. It is held in place with one screw in the left corner, and a plastic clip on the right side. 4) Behind the 4wd fuse, there is a blue wire with a white stripe. You will need to wire the switch into this wire so you can cut the circuit going to the 4wd fuse. 5) Cut the blue/white striped wire and connect one length of wire to each end. These will be wired to your switch. Connect the female connectors to the ends of these wires. 6) Work out the placement of the switch and run the wires to this location. I placed mine to the right of the steering wheel in one of the removable plastic bits. I had to drill a 12.5mm hole to fit the switch as per the instructions that came with it. 7) Connect the switch and test to see if it works. The dash lights should switch on and off and you should (i did anyway) hear an audible "woosh"... what i can only assume is the 4wd system depressurising and re-pressurising as the switch is turned on and off...(someone may need to verify this...) 8) Once you have it all working properly. Re-assemble the fuse panel and interior panels. 9) Enjoy I hope this info is correct. Of course, feel free to correct me on anything and i'll fix it up. Cheers, Mark I know this was awhile ago.....but I have 2 blue/white wires in same spot...I seen someone else posted this but never seen an answer is there an update? Link to comment https://www.sau.com.au/forums/topic/327206-fitting-a-4wd-rwd-toggle-switch-to-an-r32/page/2/#findComment-7926145 Share on other sites More sharing options...
Mikesmad350Z Posted March 7, 2020 Share Posted March 7, 2020 On 03/12/2011 at 2:14 AM, photaii said: There are two blue and white wires in the same spot on mine?!? I have same...what did you end up having to do? Thanks:-) Link to comment https://www.sau.com.au/forums/topic/327206-fitting-a-4wd-rwd-toggle-switch-to-an-r32/page/2/#findComment-7926146 Share on other sites More sharing options...
Mikesmad350Z Posted March 8, 2020 Share Posted March 8, 2020 On 03/12/2011 at 2:14 AM, photaii said: There are two blue and white wires in the same spot on mine?!? did you find out what that second wire was for? I have 2 wires on mine aswell Link to comment https://www.sau.com.au/forums/topic/327206-fitting-a-4wd-rwd-toggle-switch-to-an-r32/page/2/#findComment-7926170 Share on other sites More sharing options...
