Hi all up for sale is a list of left over R32 Skyline parts and RB20 parts that all have to go.
All parts are out of a 1993 R32 Skyline that only had 86 xxxkm on the clock.
Clutch Fan $30
RB20 Stock Turbo with oil and water lines $300
Coil Packs with brackets $80
Water pump pulley $15
Fly wheel (Manual) $40
5 speed gearbox with shifter $450
Tail shaft (Manual) $50
Air con ompressor $40
Air on compressor braket and adj pulley $10
Starter Motor $40
Crank angle sensor $30
Cross over pipe (intake) $30
Brake Booster $30
Rear brakes calipers and disc rotors all $60
Power steering pump $40
Gear box exhaust bracket $20
Windscreen wiper motor $20
Throttle body with sensors $20
Whole Intake plenum with sensors $30
Fuel rail with injectors $40
Rear middle seat belt $10
Electric sunroof switch with light $40
Indicator stalk unit $40
Passenger side electric mirror (black) $50
Drivers window Regulator $70
Interior light $10
Fuel door (black) $30
Need all this gone. PM or contact me on Sam 0415126075
Located in Ashfield (Sydney)
Postage can be organised at buyers expense.
Cheers
Edited by Nissan r32
https://www.sau.com.au/forums/topic/327240-r32-rb20-skyline-parts/
Hi mate would like to buy the rear rotors, i will be in sydney next weekend could you text me your number, mine is 0447461636.
Is the gearbox in good conditions? does it change nice? i would like to buy the box as well will u take 300 for it and i will pick that up also next weekend.
Cheers
Dale
Edited by DR31FT
Hey mate, got the heater hoses? Got pics if you need.
Hi mate
Sorry I don't. You should be able to find universal ones at a spare parts shop brand new. Just take yours
with you so they can match them up. Thats what I did.
Cheers Sam
    • IMG_8641.mov     She doesn’t sound the best but starts with out using any gas now. I just ran some injector cleaner through her. started roughly the first time after adding it but gave it the beans slowly upto 4k, Must have cleaned a few cobwebs out. another step in the right direction for the sub
    • Sadly I can confirm if you are actually seeking to drift, you will quite easily spin up one wheel. Even if you're going in a straight line. I am not entirely sure of the metrics/terminology here but there's only a certain amount that the helical will actually spin both wheels. I've seen it on video with my own car where two lines of smoke switch over to just one after you really get in to it. Unlike with a clutch diff where you can keep your foot planted until the car regains grip, in my experience with the helical you want to be utilizing traction control allowing LIMITED slip or lifting (partially) when you start to spin up both tyres with a Nissan helical. Which makes them pretty sub optimal for drifting duty. That said... this is probably a helical on numbers alone. Just put the Kazz in
    • Let's just fix the problem by f**king the rest of the gearbox.
    • Unlikely, as per Greg's post. This is not helical diff behaviour unless one wheel is up off the ground. Shimming what? You don't "shim" a mechanical LSD. Probably not in the sense that you have heard of people "shimming" a diff. And the process that Nissan f**kwits call "shimming" a diff involves super-preloading a VLSD cartridge against the side of the diff to create a friction/wear point (in a place that it wasn't supposed to have one) to make the sloppy, useless, viscous diff into a hybrid viscous/mech abortion. In case it isn't clear, I consider the process to be stupid. Nike.
    • How much does the shifter move when the car is in gear with the engine off? If it is more than about 1cm you need to replace your shifter bush. Your shifts will just get crunchier, not faster, with a short shifter unless you also rebuild the whole box
