The other day I was on the M4. Was cruising at about 100 - 110km/hr. Had to suddenly break hard and the car does not stay straight when braking. The car must be braking harder on one side or something. What should I do? How should I diagnose and fix this issue? The brakes were fully rebuilt at 100000km. The car is now at 118000km. Could the brake pads be worn? Could the brake system need bleeding?
Slowing down slowly is fine. Slowing down hard at speeds like 80km/h the car slows fine. Its just greater speeds.
Hmm it could be the alignment. I had the wheels balanced a while back and they checked the alignment and it was a teeny bit off but they suggested not to pay for them to recalibrate it over that. Recently, though, I had the old gel filled castor bushes changed to solid aluminium castor rods.
It can't be the suspension as I suspected I had a suspension issue in the past but had it checked out by pedders. They done a full inspection and said my suspension is in top notch condition and very firm.
How often would I need to change the brake pads?
My gut feel is that if it were brakes you would feel it at normal speeds. The fact you are only experiencing it under hard braking makes me think it's wheel movement somehow... Ie either suspension or tyre deformation?
Toe out will sometimes mAke the car feel twitchy under hard brakes also..
im going with toe out or incorrect alignment in another way.
from what i understand you had your suspension checked and then replaced the bushes afterwards? if thats the case it could have moved.
    • If you haven't bought the ECU yet, I would strongly consider buying a modern ECU. Yes it is very easy to setup and tune, however it is lacking many of the features of a modern ECU. The pro plug in is something like 10 or 12 years old now? Can't remember exactly but it is very dated now. In that time the Elite was released and now we have the Nexus platform.  I would strongly consider not buying the ECU that is 3 generations old now (especially as it isn't a cheap ECU!).
    • Im happy for it as long as it means reanult gets the boot
    • Sorry I should have been more clear with the previous post.  The block is a sanding block - picture something like this https://motorguard.com/product/motor-guard-bgr161-bgr16-1-rigid-psa-sanding-block-2-5-8-x-16/ The guide coat is the paint It's two separate things I was talking about, there is no "block guide coat".
    • Maybe more accurately, you aren't just dulling the existing paint, you are giving the new paint something to 'grab on to'. By sanding the existing paint, you're creating a bunch of pores for the new paint to hook on to.  You can lay new paint over existing paint without sanding it, might last a year or two then sad times. The paint will peal/flake off in huge chunks. By sanding it, the new paint is able to hang onto it and won't flake off.  Depends on the primer you are using. When you buy your paint, as the paint supplier what grit of sand paper to use before you lay down the primer.  Use whatever you like as a guide coat. Pick a colour that really stands out in contrast to the paint. So say your sanding/painting a currently white car, using a black guide coat would work well. You very lightly lay the black guide coat down, then as you sand the car with the large block, all the high spots and low spots will stand out as the black paint is sanded off (or isn't sanded off).  When you buy your paint, hit up your supplier for recommendations for what paint to use for a guide coat if you're unsure what would work well with your setup.
    • Cheers thanks for the help mate I’ll see how we go with that one
