hi guys.
i have just moved from melbourne to adelaide. i have to get a regular service for my skyline. which place can u people suggest?
i live at prospect and work in the city, so any place nearby would be great for me.
also i noticed today that my rpm meter is flicking off big time. it used to work properly before. today i noticed that it justs flicks back-and-forth big time even for a small push of the accelerator.
hope someone can help me out.
https://www.sau.com.au/forums/topic/327288-new-to-adelaide/
hi guys.
BAD/dirty ground on the sensor connection most likely , unless you have hacked into the ECU harness, then look at that connection for loose wires ?
https://www.sau.com.au/forums/topic/327288-new-to-adelaide/#findComment-5326167
they seem to do awesome work for me everytime.....so its a +1 for me but might be a wee bit out of your way
boostworx do really good tunes and know what theyre on about
my preferred mechanical workshop is literally a street over, so I get mechanics done at Road & Track but get the nistune done by Shaun @ boostworx - I asked pete from PLMS who he would recommend for nistune specific tuning and he said shaun, and he was able to diagnose a fundamental error in the TDC setting on the stock cams.
Between the two workshops, you cannot go wrong
-D
https://www.sau.com.au/forums/topic/327288-new-to-adelaide/#findComment-5326464
a big negative on boost works.. :ninja: going to last like 10 mins i know but worth it to save a sucker his time, car and money!
driving home after my 100k service to the 260.... sorry mate the work experience guy looked after ur car...
snapped BRAND new water pump
smashed radiator
spark plugs were done up very tight by hand.... could just get them off....
stilt brake fluid all over the brembos
i learnt the hard way to stop being lazy... save ur money mate... go speak to ur local repco and get them to sort you out
https://www.sau.com.au/forums/topic/327288-new-to-adelaide/#findComment-5330267
how do you snap a water pump :P
and what did Shaun do for you about it
big deal things happen its how the workshop fixes things after they realise some thing has happened
i had brake lines fitted @ boostworx one of there former mechanics put them on and when car hit the road line was touching rim i cut 1 line Shaun couldn't be more apologetic and sent me to JIS to get a new line and it got sorted there and then same day
https://www.sau.com.au/forums/topic/327288-new-to-adelaide/#findComment-5330329
another +1 for boostworx.
Its not that far from Prospect - I'm at Enfield and its only a 5min drive.
I've only had good experiences - prices are good, they explain everything, and are passionate about imports.
https://www.sau.com.au/forums/topic/327288-new-to-adelaide/#findComment-5330489
True Steve........I've been around long enough to know that EVERY workshop has a horror story, BUT, it's how they handle you after the event.
Don't judge a workshop by their demeanour when everything is going honky dory, judge them when their backs are up against the wall......something my Dad used to tell me about the test of a person's true character.
https://www.sau.com.au/forums/topic/327288-new-to-adelaide/#findComment-5330508
a big negative on boost works.. :ph34r: going to last like 10 mins i know but worth it to save a sucker his time, car and money!
smashed radiator
another -1 for boostworx. they told my wife that the ticking noise in her CA was just normal sounds that you get in the head, over time. "don't worry about it" they said.
it was a piece of the piston floating around the chamber with a bit of the top ring... fortunately we moved to QLD about a month later. unfortuantely, we drove the sil up. it got us to qld, but that was about it.
Edited by pyro-ns
https://www.sau.com.au/forums/topic/327288-new-to-adelaide/#findComment-5332494
As Steve and Sled have said.
Shit happens to the best of people. It's how they fix the problem.
I'm going to Push Morpowa. Simon and the guys there are great.
There more up your area also.
Morpowa
Also recommend Simon from Morpowa, my R34 used to run like a dream when I collected it after every service. He knows his shit.
https://www.sau.com.au/forums/topic/327288-new-to-adelaide/#findComment-5333404
ive gone to quite a few different places to get things done to my cars and theres a huge list of who id never use again.
but ive been really happy with smooth garage and willall racing.
prices are good, service is good and they both know what their doing!
https://www.sau.com.au/forums/topic/327288-new-to-adelaide/#findComment-5333714
wel they didn't f**ken handle me very well all Boostworx said to me was "we just blew your motor on the dyno by leaning out piston 6 and blew the ringlands, you can come pick your car up now"
NO APOLOGY at all especillay after i had just spent over $10,000 there!!!!!!!!!!!!!
-10000000000000
https://www.sau.com.au/forums/topic/327288-new-to-adelaide/#findComment-5334511
    • From when I was looking at getting the 86 engineered for the turbo, the joint said to put in a few euro 5 or 6 cats, then tune the car on a nice clean E85 tune When I was looking at a turbo for the MX5, it was basically the same thing, a couple of cats and a nice clean tune Although, it will depend on the year of the Jeep IRT emmisions standards required, and what mods are done, especially if it has a newer engine installed that requires a higher Euro
    • Yeah - but it's not actually that easy. There are limits for HC, CO, NOx and particulates. Particulates shouldn't be a concern in any petrol engine unless trying to comply to the very latest Euro standard. But getting a tune right so that all the others stay within limits AT THE SAME TIME is not a trivial exercise. You couldn't possibly get it right by just guessing at the tuner's dyno, unless he had a 4 gas analyser up the pipe, which is not often the case these days. It used to be. Every decent shop that did "tune ups" (as opposed to tuning) would have a 4 gas analsyer. Perhaps there's still quite a few of them around these days. But most "tuners" are only watching O2 and power readings.
    • Slight segway but the most expensive part of the whole thing which I would have thought would only be required for an engine size/type swap, not a VIV test, is emissions testing.  That's when you get into the big bucks.  I can't remember the exact price now but I got quotes for the GT-R based on swapping to RB30 (not that anyone bothers doing it legally anymore...) and it was around $4500 just for that alone.  The guy that does them manipulates the tune on the vehicle to make sure it passes.  The cheaper option is to book into Kangan Batman Tafe (I think that's where it was) and hire their tester.  Allegedly you're not allowed in there with the car though so not in a position to tweak anything to make sure the vehicle passes.  I'm sure in this day and age of ultra tuneable ECU's you could get the tuner to program a special efficiency (clean) tune that emits the lowest amount of particulates possible that would pass the test.  It might only make 50kW's but as long as it passed who cares!
    • I'm sure he has left signs, or, he is looking down, laughing That's my cunning plan for when I leave, lots of half finished projects, with no rhyme or reason of where I was actually up to, just to keep everyone on their toes
    • Does that price include the rack time to straighten the frame and body and replacement of parts and paint, as well as the noise and emmisions testing  The last engineering certificate I had done, albeit about 15 years ago, was around $1000 for a few inspections and the certificate
