Hay guys,
I guess im wondering if anyone else has shit radio reception and what can be done to improve it.. Its generally pretty fine around the city but has some areas where its completely crap and as soon as you get past around the 50km mark from the city the radio becomes non existant.
When i bought the car it had a jap radio it it which only had a very narrow band and it was really bad so i put my aussie cd player in and that made it marginally better but its still crap.
Is anyone else having this same problem and what have you done about it?
Stu
https://www.sau.com.au/forums/topic/327311-terrible-radio-reception/
Hay guys,
Stu
just make sure you connected power to the antenna amplifiers when you installed new head unit, from memory it is the wire linked to the antenna plug behind the head unit.
Does it need positive 12v power to that plug? that would probably explain why my radio is so shit!!
  • 4 weeks later...
nothing to buy, factors amplifiers are hidden away behind rear door, your power wire will be there.
I finally deciced to try this power amplifier thing and i cant seem to find the wire. At the back of the loom where the aerial plugs into the back of the stereo i have to plugs, one smaller than the other. The bigger one plugs into the back of the stereo. I follow that back and it goes to a black socket type join, i follow it back further and it goes to a white plug with one wire coming from it, that wire goes straight back into the main loom. Im pretty clueless when it comes to car electrics. Can u please help?
Thanks
Stuart
Ill send you some pics either this arvo or tomorrow.
While on the top of Radio Reception, I've still got the factory m35 A/V set-up but what I'm wondering is what will I pick-up in the way of Digital Radio with the Hawk Ranger III once installed?
I will mostly be in the Blacktown / Granville regions.
OK, blue wire is my antenna power from my head unit (so amps on come on ONLY when i select radio). This goes to the white wire (bottom arrow), which in turn feeds 12V to yellow black wire (top arrow) and on to amps. You may have had your wires cut, so may not have original block like mine.
pretty sure it is cabin temperature sensor, plugs into dash, left and below of steering wheel where the sensor is, the job of this pipe is to draw air past the sensor when the air con is on. If you dont have climate control, mighten have this sensor.
AFAIK it has climate control. The A/C unit is the same as RS. It has the temp sensor mounted behind the front bar but only has dash sensor on pass. side of dash.
The part the pipe fits to in the pic is not there.
Thanks all sorted. Its still not 100% but what can you expect when you live on a mountain. Its alot better than its ever been. At least it doesnt drop out all together. Thank you very much
    • This has clearly gone off on quite a tangent but the suggestion was "go standalone because you probably aren't going to stop at just exhaust + a mild tune and manual boost controller", not "buy a standalone purely for a boost controller". If the scope does in fact stop creeping at an EBC then sure, buy an EVC7 or Profec or whatever else people like to run and stop there. And I have yet to see any kind of aftermarket boost control that is more complicated than a PID controller with some accounting for edge cases. Control system theory is an incredibly vast field yet somehow we always end up back at some variant of a PID controller, maybe with some work done to linearize things. I have done quite a lot, but I don't care to indulge in those pissing matches, hence posting primary sources. I deal with people quite frequently that scream and shout about how their opinion matters more because they've shipped more x or y, it doesn't change the reality of the data they're trying to disagree with. Arguing that the source material is wrong is an entirely separate point and while my experience obviously doesn't matter here I've rarely seen factory service manuals be incorrect about something. It's not some random poorly documented internal software tool that is constantly being patched to barely work. It's also not that hard to just read the Japanese and double check translations either. Especially in automotive parts most of it is loanwords anyways.
    • If you are keeping the current calipers you need to keep the current disc as the spacing of the caliper determines the disc diameter. Have you trial fitted the GTS brakes fit on a GTSt hub or is this forward planning? There could be differences in caliper mount spacing, backing plate and even hub shape that could cause an issue.
    • Hi there I have a r33 gts with 4 stud small brakes, I'm going to convert to 5 stud but keep the small brakes, what size rotor would I need?
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
