Laser is obviously better, however pretty expensive for higher quality/yeild/colour/speed.
Ink jet is of course a cheaper option, but you can still get some pretty good quality prints out of them, just you have to change or refill cartrdiges more often and are sometimes a little more costly.
It really depends on your budget and what sort/style of printing you are doing and the amount of printing you are going to be doing with the printer.
Edit: FYI - you probably should have posted this thead in: http://www.skylinesaustralia.com/forums/PC...ussion-f16.html
Edited by erderr
Home use I would recommend just going with inkjet :) as laser isn't really worth it unless you do a tonne of printing or need the quality.
Plus, you can normally buy refill kits where you can refill the inks that save you about 30%-50% by reusing the cartridges.
Np, I work in IT, so this is part of my day job. :P
