Hey Leon
How much them tires cost ya delivered as i want a set for me GTR, also i have the same R3C Clutch solid center as you got they are a brilliant clutch not hard to use at all around town, but very hard on gearboxes as my brother found out in my car... looks like a collapsed input bearing.
Cheers
Benny
atleast a bearing is an easy fix. Benny I sent you a pm on the prices I got. When can I come round and check out your drag gtr? I feel like im dirty, I have an R33 too now... could go fishing sometime haha It really is like a boat in the garage next to my r32
  • 5 weeks later...
I started to make a Torque Plate for torque boring and honing last night. I only got as far as decking the top down a bit to reduce the bulkyness of it.. Basically held it down to the mill with some t-blocks and cap screws through the spark plug holes. Hopefully tonight I'll have time to bore the cylinders out.. I was going to do it in the lathe on a face plate but its about 50mm too big to reach the cyls 1 and 6 in the lathe so I might do the lot in the mill with a fly cutter... Made it look like it snowed :(
Jono I didn't finish the torque plate last shift, it was real busy because of the rain, everything was breaking down so I actually had to work. I bored out 3 holes, and realised the machined surface I dialed off were actually not in the center, I sort of assumed the spark plug would be in the centre, but its not, its about 3mm off centre :( so now I have to decide whether to sleeve it, build it up with a double pulse alloy mig or scrap it and just find a alloy plate I can do it, but id like something atleast 40mm thick, and not sure we have any lying around. Here are some pics..
I bolted it down to the table
Then I used a finger dial to dial up off a machined surface where the spark plug goes... turns out it wasn't centre, and my night shift drowsyness didn't notice, and being half slack to do the job i didn't bother measuring. Using the finger dials was easy to get the head setup within 0.01mm or 0.0004"
Then the final result which is just crap, Im so pissed off haha but I will work something out
Edited by choku_dori
Also purchased some JJR R33 rear traction rods and Toe rods yesterday. Also rang driftshop about some D-project tie rods. Waiting for them to get back to me. If anyone has any good quality tie rods and extra lock rose joint ends with adjustable bump steer please let me know, I'm keen for some even if they are second hand.
Still been slack, gotta call nissan and order a shitload of shims for the diff to set the preload and backlash in diff before that can go in, and still gotta brace the rear cradle and paint it, then I can setup the rear end and fit the GTR guards to get the 11.5" wheels sitting nice :(
  • 1 month later...
hey man, I'm going for similar wheel width on my 32. I've already got a rear half of a gtr shell so I'll get the guards off that but I have been wondering how to make them even further out, very interested to see how you've done it. Also I was thinking about using a 33 subframe for a while.. but I decided not to as it would make it even harder to fit wide wheels, just wondering why you chose to put the wider subframe in when you're tryna fit wider wheels.
Cheers,
Grant
Cheers,
Grant
Hey,
Im thinking of machining up a steel roller to go on the guard roller in place of the original nylon one, and heat the guard with the oxy and flare it out with the steel wheel on guard roller... if that fails and it looks terrible ill use small over flares... dont really want to though.
Im using the r33 cradle to get it up closer to the chassis and better geometry on the arms. I have a complete spare cradle with diff and all if your interested..
Cheers
    • I would paint match the whole thing to avoid unwanted attention  I had a similar bonnet, paint matched, on my old R33 GTST, but mine was a fibreglass jobbie made by Blitz in QLD, they work extremely well for radiator efficiency and under bonnet temps
    • Does anyone run this kit with factory plenum? Does the adapter and bosch tb fit under factory strut brace? I wanted to get this setup before going forward facing manifold. Thanks
    • small update time, after always wanting a "cool" looking bonnet for my car and always struggling to find one for the series 2 that i liked and wasn't an insane amount of money. Saw one i liked on RHDjapan from D-speed in Japan the price was very good for a carbon bonnet so good infact i was a little unsure how much i trusted it, decided to bite the bullet and with the help of jesse streeter in not long at all it was at my door. Once it was delivered i ran in from work and quickly unboxed it and to my surprise the quality was actually pretty good i quickly removed the old bonnet and placed on the new one to test it out and even the fitment wasnt too bad at all. Then decided to paint the little grille in the bonnet black to stop it sticking out so much.   I decided to not mess around with the hood latch and just install some aero catch hood pins, having never installed them before did some YouTube university classes and i was good to go. fair to say it is not a fun job at all from making brackets so the pins sit nicely and actually cutting through the bonnet but also being very scared of cutting the holes too big it took wayyyy longer than i would like to admit but finally got it there. Then it was time for a quick test drive to ensure the latches actually worked and thankfully the bonnet looked very stable. I still think paint matching the bonnet and leaving just the part that sticks up as carbon would help make it all look alot neater as im not sure how i feel about all that carbon on a very fridge white car but will leave it as is and see how i feel with time.
    • I think it's bound to happen, you finally get it all perfect, and bam, something will happen. I took a while to get a Commodore rear quarter repaired where a P Plater clipped it. Two days after getting it back, Sarah wiped it out on a concrete pillar in an underground car park... This is why I take forever to repair them, it stretches how long until it gets bent again... 😛
    • Nah, not really responsible for that little fiasco, but I'm still pissed at myself for writing off my 86, or when I reversed my VX into a pole just before selling it, but, meh, 5hit happens to stuff, all it takes is a slight distraction, and life is full of distractions, and "dooh" moments
