Driving On Suspended Rego?
drive_guy
 Share
NO demerit points and $597 is the fine for Unregistered. No need to state the obvious why there is NO leeway for people driving unregistered cars. Lately I have been catching lots of people driving unregistered cars with permit clearly outside the conditions. I think a lot of car yards/sellers don't explain that permits strictly to get car to and from place of repair for RWC and registration.
The funniest I have had is someone delivering pizzas in this situation as car yard told him OK to drive. They (car yard) also put down wrong engine and Vin number on permit too. There are some dodgy people out there for sure!
did you still give him a fine?
Edited by DAS KAMU
Yes I fined him and didn't let him drive further. Every check we do is recorded and If it shows I checked an unregistered car and didn't fine driver I could end up in LOTS of trouble and become civilly liable if I let them drive and end up in collision.
End of the day it's driver's responsibility to know road rules and drive registered vehicle. It's CLEARLY written on the permits what the conditions are. As it's been discussed number of times that unregistered car is NOT covered for TAC insurance etc. I chased up with Vic Roads about the car yard to investigate them further too.
understood
 Share
    • Great info @tidi0x  Will definitely be handy for others and maybe me if I decide to keep the shit box H pattern.
    • Bumping this up one last time.... I wanted to follow up on the clutch slave issue. I realized that what the issue comes down to is the pocket is flat milled, and the cylinder does not want rest flat. So in order to mount it correctly you will need to make a spacer for the fingers so the cylinder is floating. I took two plates of aluminum, drilled some holes and was good. I did still need to make the relief cuts in the bell housing, as even with the spacer the bleed section still interferes. The OE bell housing the mounting holes are raised from the housing.
    • If the event in USA goes ahead will be interesting as it seems the rules will get more cars over here. Apparently the track is laguna seca too. Yeah s15, if I get a the lower dash trims, centre console and change front cross member to standard LCA position will fit clubsprint. See how rules are as i would rather do complete widebody than a bolt on flare to run the 295 with proper clearance.
    • If the car is legal height I can't see it being an issue. Found a thread on reddit that might offer some insight.   I got a ticket from a copper in QLD for my S15 being too low. They had this wheel thing on a stick that they put under the car and it hit my exhaust. Anyhow went to an exhaust shop to get the exhaust tucked up/hung a little higher and I wound the coilovers up a smidge. Don't think I even had to go back to the police station unlike when I got defected for having a carbon bonnet when I brought the S15 from the ACT to QLD and had to replace it and then rock up at a police station and have a yougish female officer who knew nothing about cars confirm that I had changed bonnets. Should have just painted the carbon bonnet yellow to match the rest of the car lol
    • Id like to race in the US i think alot of those track would suit me   For the s15? Youd be stuck between club sprint and the new Open Am wouldnt you depending on how much interior you have left in
